Question about Sony BRAVIA KDL-52W4100 52 in. LCD HDTV
I just bought a Sony Bravia KL-32L5000 yesterday. I hooked it up and watched tv for about 15 mins when all of sudden the picture cuts to horizontal lines all across and the tv makes a screeching noise like a cat has been run over. I tried the next day a few times and would have a perfect picture and sounds but for only 5 minutes and the same thing would happen. I'm taking it back but I was wondering what would cause this? I have tried several 75 ohm cables.
    Top Expert:
  • Sony Master
  • 53,745 Answers
It is a board problem
have it repaired under warranty or replaced under warranty
Posted on Jun 17, 2017
SOURCE:
circuitcity
  • 137 Answers
SOURCE: Sony BRAVIA KDL46S2010 Sound and Pix not in sync - in HDTV channels only
This is a software issue with both the TV manufacture and the cable box provider. This will only be fixed when the cable company and TV manufacture sit down and work out their problem. Some cable company has taken the first step by updating cable boxes with different software.
Best regards
CircuitCity
Posted on Dec 07, 2007
SOURCE: Sony Bravia KDL52XBR5 picture blanks out using HDMI port
We had the same problem. Called Sony and they advised there was a "Software Mismatch" and suggest using a newer set top box. I'm just going to use the component. You would think they could resolve this with a firmware flash or something. Hope this helped.
Posted on Feb 27, 2008
SOURCE: clicking noise sony bravia kdl-40v3000
http://forum.ecoustics.com/bbs/messages/2/176039.html <-- Check that out.
Also I have a Sony Bravia and it clicks while it is on as well. I read that forum and some people said to disconnect the cable box for 10 sec. and then some said it was the heat from the summer.. i don't know.. I just turned my tv off and then back on and it stoped. I read this is happening with all kinds of TVs....
Posted on May 23, 2008
SOURCE: The TV has horizontal lines across about 5 inches
Horizontal lines are relatively rare problem in LCD TVs.
The likely problematic areas are:
1) The LCD itself (the micro ICs embedded into the LCD panel structure); that doesn't sound likely based on what you say, but it's not completely impossible. The bad news is it's mostly uncurable.
2) The power board A-1511-322-D G5
Power boards may sometimes cause problems with display, although rarely causing horizontal lines.
I wouldn't start looking here either, but it is certainly a problem to consider.
3) Main board 1-876-561-13 R1506072C
Slightly more possible and yet not quite likely. A high operating temperature and bad SMD soldering process may cause some soldering contacts on the main board to behave differently when the board is cold versus when it heats up. It is very common and may have all kinds of different effects on the TV and the screen.
One way to check for that is with a regular dryer..the process is explained in many other solutions at fixya and around the net, so I wouldn't repeat it here...but it takes time and patience.
4) The most likely place to start with is the T-Con / LCD controller
404652ASNC6LV4.1 M139.
I'd first replace that and see if the problem goes away.
5) There's a very minor chance that the LVDS cable that connects the main board with the T-Con does not make good contact initially and changes that as a result of getting hot. It's easy to just touch and move it lightly when the TV is still cold to see if it has an effect on the picture.
Sorry I couldn't just nail it for you, but that's the nature of the repair businss :-)
Bobby, www.coppelltvrepair.com
Posted on Mar 15, 2010
SOURCE: Sony BRAVIA sound cuts in & out
Does this problem happen alot at night? email me at adamnorrad@gmail.com i might know what it is. Im dealing with the same issue
Posted on Apr 04, 2010
Bravia kdl-32l5000. Why does it have a red screen?
Color circuits are messed up and need repair.
Mar 05, 2016 | Sony Televison & Video
Sony model kdl-32l5000 only works by unplugging and plugging back after about 5 minutes
power supply may need recap try with a hair dryer when tv in stanby to heat a bit without unplug it if after heat it will start?
Sep 14, 2014 | Sony Bravia L-series Kdl-32l5000 32-inch...
Horizontal lines flickering at the bottom of screen...... SONYbrvia KDL-32L 5000
Hi Freddy Pagan
I like your Sony TV is defective that it cannot be fix again, better call the Customer Support to replace your Sony TV.
I hope my solution may help you.
Thanks for using Fixya...;-)
May 06, 2014 | Sony Bravia L-series Kdl-32l5000 32-inch...
Have horizontal lines across the screen and some
Yeah we have the same exact problem here. Defective TV....ours would correct itself after 30 mins, but now it's blurry all the time. I'm never dropping 2K on a SONY tv again.
Aug 01, 2010 | Sony Bravia KDL-46VL130 TV
My LCD tv's menu screen keeps popping up and won't stop.
Since it is brand new then should be OK.
Please return it to store and get another TV.
Feb 24, 2009 | Sony BRAVIA KDL-32S2000 32 in. LCD HDTV
Sony bravia kdl-46v2500
TRY A DVD PLAYER TO VERIFY IF IT COULD BE THE SAT.BOX OR MAYBE TV COLOR ADJUSTMENTS.JOE TV
Dec 30, 2007 | Sony BRAVIA KDL-40V2500 40 in. LCD HDTV
Sony Bravia XBR 40" LCD
First, HORIZONTAL CENTER.
1) Press MENU.
2) Scroll to SETTINGS.
3) Scroll to SCREEN.
4) Go to HORIZONTAL CENTER. Move the picture to the right. Hopefully, the line will go away. Otherwise, there is a problem with the pixels or the signal processor. Call 1-800-222-SONY. Or, http://eservice.sony.com. Have a high-limit credit card handy for out of warranty repairs. Sorry about that.
Aug 27, 2007 | Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
No picture and no sound,
Something shorted and shut your set down. Most likely the high voltage transformer shorted which also shorted the horizontal output transistor. Stargazer
Aug 01, 2007 | Sony FD Trinitron WEGA KV-27FS100 27" TV
Sony BRAVIA KDL-52W4100 52 in. LCD HDTV Logo
193 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Steve Allison
Steve Allison
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
