Question about Samsung DLP HL-P5663W 56" TV
What is causing white spots on my 56inch DLP Samsung Television. It started with on spot 2 days ago and now there is 15
  • Samsung Master
  • 610 Answers
The dlp chip needs to be replaced. samsung will cover the cost of the part and labor. call 1-800-samsung to set up service.
Posted on Dec 28, 2009
  • Samsung Master
  • 3,803 Answers
Restore Deleted Data from Samsung
Here I'll introduce you Android ToolKit - Android data recovery to restore deleted data from Samsung, which has been widely accepted as the best recovery tool to recover deleted data from Samsung Android phone selectively. By using this tool, all deleted contacts, messages, call history, videos, photos, documents, WhatsApp messages, and more will be deeply scanned and recovered from your Android device. You are allowed to preview the data before recovery.
Additionally, this program enables to extract data from broken Android device, backup & restore Android on computer safely. Compatible with almost all Android models, such as, Samsung (Galaxy Note 9/8/5/4, Galaxy S10/S9/S8/S7/S6), HTC, Lenovo, Huawei, Google Pixel, LG, Sony, OPPO, OnePlus, ZTE, Xiaomi, etc,.
LEARN MORE
Posted on Sep 12, 2019
SOURCE:
Why is there white dots appearing on my expensive 61 inch samsung. First it was 2 dots 5 days ago now there are 5 spots and counting.
It sounds like the mirror array is playing up. Maybe caused, as it is mechanical, by dust.
If it is still under warranty, I would have it looked at, if not request a Samsung Authorised DLP Technician takes a look for you. If you are in Europe Samsung may look at it with a view to helping when it comes to repair cost.
Good luck
Dec 14, 2010 | Samsung DLP HL-P4663W 46" Rear Projection...
White spots are just emerging on my 46inch
There seems to be an issue with your DMD board, which is the on in charge of the pixelation. What you can do to confirm if it's indeed the DMD board, is the following: GO to the menu on the TV and if the dots show in the menu, it's your DMD board, but if they don't the issue might be with one of your Video Boards.
Dec 10, 2009 | Samsung DLP HL-P4663W 46" Rear Projection...
I have white dots appearing on my samsung dlp.
If the white spots are appearing in different spots or "Moving" it is the DMD board beginning to fail. Samsung DLPs seem to have a lot of DMD board failures. I would expect it to completely fail in the next couple months.
If there are only a couple small white spots that never go away it could be a mirror that is seized on the chip, but it's far more likely that the DMD board is going bad.
Aug 10, 2009 | Samsung DLP HL-P4663W 46" Rear Projection...
White spots
You seem to have an issue either with the video board or the dmd board, do the next thing, with the Tv on go to your service menu, is the white spots are still there, it's most probable that your dmd board is failing, if not, the issue is with your video board.
Jul 08, 2009 | Samsung DLP HL-P4663W 46" Rear Projection...
Samsung DLP with white spots
Hello rockel, As the commercial goes, "It's the mirrors" and that is exactly what it is. The DMD (digital micromirror device) DLP chip that is the problem. The areas that are white are due to stuck or malfunctioning mirrors. This will only get more pronounced as time goes on. The fix is to replace the DLP chip and or module. I would advise that you get a qualified TV technician to do this. I hope this helps Thank you, Shuttle83 http://www.electron-age-technologies-llc.com
Jun 11, 2009 | Samsung DLP HL-P4663W 46" Rear Projection...
Numerous white spots on Smasung DLP TV
same problem for me ... check out this thread on AVSforums about it.
I have the same exact tv as you and had the same problem. I took it to a repair shop who told me I needed a new DMD chip and that it would be 850 to fix. I used the information in thread above to get the part number and bought the chip on ebay for under 200. Here is a link to the listing CHIP
People have had good success. I will be replacing mine tomorrow.
Feb 26, 2009 | Samsung HLS4676S Television
White spots on screen and growing every day
If these spots are small, they are likely the visual effect of a failing DLP chip. When some of the tiny mirrored surfaces on the chip stop moving, this is the result. This is not something you can fix yourself. A Samsung authorized service center will charge $400-$500 to replace it for you.
michtech
Feb 18, 2009 | Samsung DLP HL-P4663W 46" Rear Projection...
BAD LIGHT ENGINE call UED 1-800-648-6657
Feb 15, 2009 | Samsung HL-S4266W 42" HDTV
See link below for "field of stars" fix:
http://www.avsforum.com/avs-vb/showthread.php?t=1107926
Worked a charm on my 50" Samsung DLP. Read thread carefully as there are 2 different version of the DMD chip you will need to replace. I ended up fixing mine for less than $165!
Chuck
Feb 07, 2009 | Samsung DLP HL-P4663W 46" Rear Projection...
Samsung DLP HL-P5663W 56" TV Logo
724 people viewed this question
Jerry Greenberg
Jerry Greenberg
Ekse
