Question about Samsung Digimax D53 Digital Camera
Camera wont turn on unless i take the batteries out
I have a samsung digimax D53 , recently it wouldnt power on even with lithium batterys, i tried changing the batters , but it o nly comes on when i close the battery case. when i try to power it off via the power button it does nothing .
When i try to take pictures it shuts off. the camera has been well looked after, i've had it barely a year. My last camera by samsung lasted 8 years.
    Problem Solver:
  • 5 Answers
I tried alkaline batteries in this camera and it would only work for a few pictures, then it would go unstable and do unpredictable things. The lithium batterys also caused problems like the ones you described. As a last resort I found that there was a ni-mh battery for this camera. I could not find this accessory. I purchase some batteries and charger then installed them into camera. reset the camera using the reset function, then tested camera. It now works correctly and consistantly takes good pictures. If the camera does not work with the ni-mh batteries it might be damaged or bad.
Posted on Apr 06, 2008
6ya staff
SOURCE:
Camera has charged batteries. at first when i turned on power...nothing happened...then...later...i pressed power again and it came to life. the lens popped out and i took a bunch of pics and reviewed...
@ alan o'brien, Samsung D53 digimax draws a lot of current from the battery thus, you need to replace your batteries with a HIGHER current ratings, sufficient enough to run the motor. This miniature motor inside the D53 camera drives the reduction gears functions, to extend and retract the mechanical lens. During this processes it is drawing a lot of current from the battery. In order to conserve and prolong battery power avoid zooming in and out, utilize the function speed 50-400 and manually adjust aperture to minimize the unnecessary use of flash. In other words, go manual mode. Here's the battery specs. 2800ma NiMH rechargeable battery. Refer and follow manufacturers recharging instructions for best result. Do not leave batteries inside the camera even when not in use because the circuit inside is still on the standby mode and not necessarily off. Hope i have satisfy your curiosity. If you can, kindly share with me some of your best photo taken from your D53 digimax. Thank you.
Sep 22, 2013 | Samsung Digimax D53 Digital Camera
Tip
Short battery life with AAs or camera won't even power up on new batteries?
Many digital cameras (eg Samsung D53, Nikon 2100) have extremely poor battery life with alkaline batteries (under 20 shots!). Sometimes they won't even take a single picture.
Try using rechargeable batteries or "oxyride" disposable batteries. They perform infinately better.
on Nov 09, 2007 | Samsung Digimax D53 Digital Camera
Samsung Digimax D53 wont turn on at all brand new batteries and still wont turn on
Make sure that you have the correct battery type installed, and that the batteries are fresh/fully charged. If the problem persists, you may have corrosion on the battery contacts inside that camera that is preventing full battery power from flowing to the camera. Remove the batteries and wipe the inside camera contacts firmly with a dry cloth (heavy corrosion may require cleaning with a wire brush, steel wool, or sand paper). Remove any residue that may have fallen into the battery compartment during cleaning, then wipe both ends of the batteries and reinstall them in the camera. This cleaning solves the problem about 90% of the time, and I hope it works for you.
Sep 12, 2009 | Samsung Digimax D53 Digital Camera
Samsung Digimax D53 Camera says low battery but just replaced with brand new ones. Camera beeps and shuts down immediately.
For digital cameras you should use either Rechargeable(whith high Ampere) or high performance alkaline batteries (ie. Lithium Duracel or Enegizer) normal alkaline batteries will not be able to charge the Flash. If you are useing high performance batteries then it is sadly your camera which is faulty. repairing it you could but it is cheaper to get a new camera.
/SciPhinx
Jul 22, 2009 | Samsung Digimax D53 Digital Camera
My samsung want turn on
Hello!!
Try hard resetting once.. remove the batteries and press the power button for few seconds and later start up the camera .. let me know if it works !!
Thank you!!!
Jan 12, 2009 | Samsung Digimax D53 Digital Camera
D53 camera will not fully turn on...help??
If you've tried the suggestions for similar problems on here - use NiMH or lithium batteries (not alkalines), then it may be a warantee job. Afraid I don't have any other suggestions.
Sep 05, 2008 | Samsung Digimax D53 Digital Camera
Broken Camera
It''s the battery..you need to buy rechargable batteries or lithium batteries. These batteries are specialied made for digital cameras. The lense is shutting off and or stuck because there isnt enough power/energy from the batteries. This is also a COMMON problem in these specific models! You can buy recharge batteies wityh the chrager and like 4 aa batteries for around $20.00 at wal-mart..Energizer is a nice one that plugs right into your wall outlet to recharge. My camera Samsung diximax D53 Works great now taht O realized it was teh batteries..No vody told em, and it doesnt specify which batterios to use in teh camera manual..at least I dont think..I even thought the camera came with regular alkaline batteries ( the ones taht wont work fior this camera)?
Jun 18, 2008 | Samsung Digimax D53 Digital Camera
Wont show the screen
You cant use regular batteries on these cameras. I have the same one., you need to buy rechargeable batteries or lithium batteries, both are stronger,but more costly than your regular alkaline batteries. This will defrinatly fix the problem..I am 100% positive,.They sell recharg- able batteries ar walmart for like $20.00 taht comes with 4 aa batteries and the pulg in charger.
May 15, 2008 | Samsung Digimax D53 Digital Camera
Samsung Digimax D53; 5.0 megapixels
Mind did the same thing. Try taking out the memory card. If it works after that, you'll have to buy a new memory card.
Oct 16, 2007 | Samsung Digimax D53 Digital Camera
Samsung Digimax D53 Digital Camera Logo
44 people viewed this question
Top Samsung Cameras Experts
FIKRET UNALIR
FIKRET UNALIR
Level 1 Expert
Anthony Ward
Anthony Ward
Are you a Samsung Camera Expert? Answer questions, earn points and help others
