Question about Watts Onan Portable Generator - 4000 , Model# 5500
Wiring problem on a 5GF-LDE SILENT TYPE GENERATOR
I have a 5gf-lde generator(china origin, silent type) and recently replaced the fuel tank guage in it which involved removing the casing,Whilst doing this I wragged off a few wires of its electric control circuit board (IT IS NOT A DIGITAL READOUT TYPE, IT IS ANALOG AND THIS CIRCUIT BOARD IS FASTENED ON TO THE REAR OF THE VOLTMETER) namely a red positive wire coming from the 12volt side from the alternator,a yellow wire going to the oil preasure switch which stops the machine from running if the oil level goes to low and a brown wire which is connected to an led which lights up when the oil switch is active giving a visual indication of low oil.Can you help in resolving just where the wires should be reconnected to
    Master:
  • 265 Answers
We hold parts for your Generator and have a whole Help Center dedicated to helping people fix their Portable Generators. If the answer is not there, we have Generator Engineers who can help. Check it out on our site. https://www.generatorguru.com/5gf-lde/
Parts Spares for Generators and Small Engine Machinery
wiring problem on a 5GF-LDE SILENT TYPE GENERATOR - image-2fwsrbehqcya13uxwt41l5dc-5-0.jpg
Posted on Aug 19, 2019
    Sergeant:
  • 290 Answers
5 Suggested Answers
6ya staff
SOURCE:
Sheldon Dedek
  • 909 Answers
SOURCE: Onan Marquis Gold 5500 on
A1 controller could be suspect, http://www.flightsystems.com/ can get you going with board cheaper than OEM, last longer too.
Does the generator shut down immediately after you let go of the start switch? If so, you are looking at oil pressure / level fault. Check oil level and sending unit. If generator continues to run for a few seconds and then shuts down, that is due to no or low AC voltage being produced and shutdown occurs. Shutdown for AC usually indicates an open winding or damaged voltage regulator.
Posted on Aug 25, 2009
Anonymous
  • 21 Answers
SOURCE: where do the four wires coming out of the right
Hello
Is it a 220 volt generator? If so then the green is ground, the white is neutral and the other two are hot wires. Do you have more information?
John
Posted on Jan 07, 2010
lindsay836
lindsay836
  • 677 Answers
SOURCE: I have a 1988 honey motorhome with a 5.0 cck onan
It is a wire to let the charging system know what voltage/amps, is being devoloped. It has a diode to check the voltage one way.
Take a volt meter. Put it on OHMS. You should read only one way, if not replace it.
Posted on Mar 02, 2010
kel1guy2002
Kelly
  • 3740 Answers
SOURCE: My Onan Emerald Advantage 5500
Hi and welcome to FixYa, I am Kelly
I can probably help you figure out where the wire goes if I had an idea of where this wire originates.
There are 2 wires connected to the side of the fuel pump I think either one of those 2 wires is the one your missing or the
Here is the start sequence for just the starter:
Sequence of Events:
Battery + pos) at PI-6, Battery - (neg) at P1-8.
Operator pushes start button at AI.
B+ from PI-2 to start solenoid
(S terminal).
Solenoid contacts close send B+ to
starter.
This is the ignition:
Sequence of Events:
Operator pushes start button on AI.
Safeties are bypassed.
B+ from P3-3 to ignition coil.
Breaker points open/close path to
ground.
High voltage jumps spark plug gap.
B+ supplied to fuel pump from PI-2.
This is the ignition / running:
Sequence of Events:
I. Engine starts, oil pressure causes
LOPKO to close sending ground
signal to P3-4.
AC from generator B1 -B2 winding
enter board at P1-1 and P1-7.
These two inputs cause the control
to switch from start mode to run
mode.
Starter automatically disengages.
Field flash automatically removed.
Start switch released.
Safeties enabled.
Bl-B2 powers choke heater (Hl).
Fuel Pump power now from P3-6
through R7.
The fuel pump power for run is from P3 pin 6 though resistor R7 to the fuel pump. THIS may be the wire that was damaged. However... a broken wire from the low oil pressure switch (located under the oil filter covered by metal cover) or... no AC output sensed on the control board due to a broken wire to P1-1 or P1-7 it will never switch to the run mode.
Your going to have to do pin to termination point readings one wire at a time. More in next post... (30 minutes or less)
Kelly
Posted on Aug 01, 2011
Missing wire of generator falcon 5GF-LDE from regulator to wich place ,so battery not charging
cant answer that one
5 kva diesel generator ....
needs a volt meter and or electrician to
ask why wire is disconnected
check regulator isnt faulty
and identify the right wire from its regulator to the right connection
Sep 20, 2016 | Cars & Trucks
FUEL GAUGE READS FULL WHEN EMPTY AND EMPTY WHEN FULL
Did this get replaced recently?
Fuel level senders typically work by changing the resistance (and therefore current) depending on the fuel level determined by the position of the float mechanism in the tank. Since the guage you are describing is working exactly opposit to as intended, is it possible that an incorrect sender was installed, or, if there are 2 terminals on the guage, have the wires been switched so that the current is going through the wrong way?
Apr 03, 2015 | 2000 GMC Yukon
Wiring diagram of fuel gauge for toyota corolla 2006 - frozen fuel gauge
It is the sending unit, usually the veryable resister and arm. Remove and replace sending unit. It is , unfortunately, located inside of the fuel tank. To confirm gage operation reverse wiring to the guage and it will reverse the guage, confirming tha the gauge.is ok.
Sep 09, 2014 | 2006 Toyota Corolla
98 gmc jimmy fuel guage not working
No issues with the fuel guage that I know of , but you can follow the basic troubleshooting guidelines. Starting with the wiring disconnect at the fuel tank for a bad connector or bad connection. Only other connection would be up to the instrument cluster in the vehicle. Only replaceable items would be the guage or the sending unit in the fuel tank. You can disconnect the return line circuit or connector at the at the gas tank and jump a wire to the ground the that feeds the gauge and see if the guage moves, but don't and i repeat don't hold to long because the guage will go over hard over and could damage the guage. If the guage moved and I would suspect a bad float on the sending unit or a bad sending unit, either case the fuel pump assy would have to come out for repairs.
Jul 02, 2014 | 1997 GMC Jimmy
Fuel guage problems
check float in tank 4 movement shake tank u should hear it move . if u hear it check wires
Dec 31, 2013 | John Deere 650 750 850 655 755 855 955 670...
GAS GAGE WANT STOP READING EMPTY WHEN GAS IS IN IT
To confirm if the fault is with the Rheostat float within the fuel tank or the fuel guage in the dashbboard, you can remove the wiring to the fuel tank float. If the guage reading changes- to full- then the guage is good and the fault can be a jammed rheostat which can be removed from the tank and replaced after draining the tank. The guage can be tested on the outside with a ground wiring to the plate of the fittings and as the float is moved the guage must show a change in reading. if not the voltage must be measured to confirm the working of the guage.
Oct 19, 2011 | 2001 Buick Century
Generator starts but gives no 220 volt electric
This is a frequency issue 50 hertz for Europe, 60 hertz in US. It's speed related. Faster RPM for 60 Hz
If you need further help, I’m available over the phone at https://www.6ya.com/expert/craig_3fa289bf857b1a3c
Jun 26, 2009 | Coleman Powermate Premium Plus 6250W...
New fuel pump now gas gauge does not work
remove the pump from the tank and your float should be going the sam direction as the tank not cross ways in the tank this will fix fuel guage
Jun 23, 2009 | 1995 Dodge Dakota
Pontiac 2003 Sunfire Gas Guage doesn't work
Your needle moving from empty to full and then back to empty indicates that it is trying to set itself (most cars do this each time they are started). So, yes, there seems to be a problem with the sending unit that feeds information to your gas guage. Prior to cracking open your fuel tank, you might try tracking the wires from the back of your guage as far as you can towards the tank. Then track the wires from your tank as far as you can toward the guage. Watch for damaged wires and/or loose connections as you go.
Jan 29, 2009 | 2003 Pontiac Sunfire
97 Silhouette Fuel guage not working correctly
drop fuel tank. if guage moves all around its probably the fuel level sensor on fuel pump assembly in the fuel tank. If the guage stay's in one spot its the guage , replace instrument cluster assembly. you can take just the glass off the cluster and move the fuel guage needle and it will work (if stuck) but for how long? The wires to the guage come from the sending unit to the power train control module to the instrument cluster. pray its not in the wiring.
Sep 14, 2008 | 2000 Oldsmobile Silhouette
Watts Onan Portable Generator - 4000 , Model# 5500 Logo
553 people viewed this question
Top Watts Electrical Supplies Experts
Sheldon Dedek
rlev_7
Level 1 Expert
Norman Worley
Are you a Watts Electrical Supply Expert? Answer questions, earn points and help others
