Question about Sony DSR-80 DV/Mini DV VCR
Error 20-911 and yhe casette is half inside - Sony DSR-80 DV/Mini DV VCR
  • Anonymous Jan 31, 2010
    Hello !
    Thanks for your advicde.
    The port. cover or dorr ....whereyou insert the tape and then showing the yellow part that the casette is inside is holding the casette so fixed and do not move anywhere.... I hope you understand what I mean.
    regards
    Olle
    New Friend:
Hi, i have a error code 20-911 on my sony pdw1500, how can i solve it ?
Posted on Jun 13, 2019
    Genius:
  • 1,689 Answers
This is the emergency eject / error code 20-911, the manual has this method to solve the issue and have it manually eject
pressing 3 or 4 keys simultaneously; and "left arrow + menu" to get a maintenance menu, then "service", then "manual eject"
Posted on Feb 01, 2010
  • 10,515 Answers
This Error refers to Tape Jam.Just take off the top of the deck, unscrew additional screws if necessary, then take the tape out. Try not to break anything.
Once done, it would fix the issue.
Let me know, if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Posted on Jan 30, 2010
6ya staff
SOURCE:
Car casette player won't accept cassettes. I put a cassette in and it spits it right back out.
Your casette player must have something lodged in it that's why it spits the casette tape back out. If you are able to, try dislodging the player from your dashboard. Shake it and if there's something noisy inside, chances are that's your culprit. Try to get it out by shaking the player while keeping the casette tape door open - like getting coins from a piggy bank. :)
Hope this helps!
Fix14
Jun 16, 2010 | Car Audio & Video
The rear door on my 1995 gmc safari will not open yhe handle seems to be ok i think that the linkage came disconnected in any case how can i get the door open
You have to remove the door panel from the inside. Is this the handle on the left door or the right door and does it have full doors or half doors and a hatch glass.
Sep 01, 2009 | GMC Safari Cars & Trucks
It does not eject the tape,it gives out error c3211
Reel of the cassette must be stuck inside. open the top cover and have a look inside. release the reel if it is tangled up inside. Reset the switch at the bottom of the frot pannel and try to eject the cassette. It will slove your problem. If it is not then you must consult the nearby sony service centre.
Aug 07, 2009 | Sony DSR-45P DV / Mini DV VCR
Ink casette error
If you just put new cartridges in the printer, check to make sure you removed all of the protective plastic wrap that may be required to remove prior to printing.
Also, check the cartridges by removing and replacing each one. make sure there is no obstruction, or torn papers, that may cause a jam or other problems.
Also, after verifying all that. Use the printer utilities to run a test. Hopefully that should fix or clarify if there is any other problem.
Hope that helps..
~enov8
Mar 07, 2009 | Canon SELPHY CP760 PHOTO Thermal PRINTER
Head cleaning
Use good quality video head cleaning cassette as camera gives error if use improper or very old tape.
Jan 11, 2009 | Sony HVR-Z1 Mini DV Digital Camcorder
Mini cassette tape is wrapped around one spool inside the casette
1). Remove the five screws from top half of cassette shell. If the cassette shell halves are glued together, very carefully split the shell with a Phillips-head screwdriver. Maneuver the screwdriver around the shell to break its seal. Avoid getting cut or damaging internal components of cassette.
2).Carefully lift off the top half of the cassette shell.
3). Pull the head if the tape from the left reel.
4). cut-off the damaged edge, and attached a peice of sctoth tape to the shining side of the tape, and leave about 1/2 inches of scotch tape beyond the head of the recording tape.
5). trim the sctoch tape using single edge of the sctoch tape razor or X-Acto knife to the same width as the recording tape.
6). carefully insert and tape the head of the recording tape to the right reel. and manually wind the tape till the recoding tape is flat to the front of the recoding pad.
7). carefully close the top shell, make sure not to pinch the tape. use your finguer trun the right reel, make sure the tape winds freely.
8). secured the top with screws.
Nov 24, 2008 | Maxell 179030 Microcassette 3-Pack (60...
Error Code: 3271
SONY DSR 45
ERROR CODE 3271
Oct 16, 2008 | Sony DSR-45 Mini DV VCR
HP LaserJet 2430dtn - "Tray 2 open or empty"
1-Is the paper set correctly in the tray? if you have Letter paper in it make sure the guides are snug against it
2-Check the lever inside the tray, remove the tray and look at the tires there should be a lever that you ca move freely that is the paper sensor
Oct 10, 2008 | HP LaserJet 2430dtn Printer
ERROR: please remove the casette
There is likely a problem with the transport mechanism. This is something that should be serviced be a professional repair shop.
Sep 12, 2007 | Canon Elura 2 Mini DV Digital Camcorder
Put tape in new video cassette
TAKING A GOOD QUALITY TAPE FROM ONE CASETTE AND MOVE TO ANOTHER WITHOUT HARMING THE TAPE QUALITY: TAKE A NEW, GOOD CASETTE AND UNSCREW THE 5 SCREWS HOLDING THE TWO PARTS OF THE CASETTE TOGETHER. AT THIS POINT DO NOT OPEN THE CASETTE. TURN THE CASETTE UPSIDE DOWN (SO THAT THE SIDE WHERE THE SCREWS CAME OUT IS NOW SITTING DOWNWARDS ON A FLAT SURFACE) IF YOU OPEN THE CASETTE BEFORE TURNING IT UPSIDE DOWN, ALL KINDS OF SMALL PIECES WILL FALL OUT AND YOU WILL NOT KNOW WHERE THEY CAME FROM. NOW GENTLY SEPARATE THE TWO PARTS OF THE CASETTE AND PAY ATTENTION TO EXACTLY WHERE THE TAPE RUNS THROUGH VARIOUS SPINDLES, ETC. MAKE A SKETCH IF THIS WILL HELP YOU. GENTLY LIFT OUT THE TAPE AND REPLACE IT WITH THE TAPE THAT WAS IN THE BROKEN CASETTE. THIS IS ASSUMING THAT THE ONLY DAMAGE WAS TO THE CASETTE ITSELF AND NOT THE TAPE. REPLACE THE TOP PART OF THE CASETTE (WITH THE SCREW HOLDS STILL FACING DOWNWARDS). HOLDING THE TWO PIECES OF THE CASETTE TIGHTLY TOGETHER, TURN IT OVER AND REPLACE THE SCREWS. TRY NOT TO HANDLE THE TAPE ITSELF. I HAVE USED RIGHT FITTING SURGEON'S GLOVES WHILE DOING THIS, BUT REALLY DON'T KNOW IF THEY HELP, BUT THEY DO KEEP THE NATURAL OILS OF THE FINGERS OFF THE TAPE.
Feb 26, 2006 | JVC HR-J461MS VHS VCR
Sony DSR-80 DV/Mini DV VCR Logo
637 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Ekse
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
