Question about LG Flatron L1951S-SN 19" LCD Flat Panel Monitor
Swithched on and only many coloured vertical lines
LG Flatron 42" Plasma about five years old - no problems until yesterday - switched on and only many coloured vertical lines - no picture
  • 84 Answers
Interface cable or video card memory problems
Posted on Sep 15, 2010
SOURCE:
Took lg plasma tv off wall when i put it back there is a fine vertical line which changes colour
IF YOU HAVE A SOLID BLACK LINE RUNNING VERTICALLY THEN YOU HAVE A FAULTY MATRIX INVERTER. IF CENTRAL THE MAIN VERTICAL INVERTER NEEDS CHANGED. LEFT = LEFT VERTICAL INVERTER RIGHT=RIGHT.........
ANOTHER WAY TO GET THIS FAULT IS WORN OR DAMAGED RIBBON/PLASTIC GOING FROM THE SCREEN MATRIX TO THE INVERTER
HOPE THIS WILL HELP IN SOLVING THE PROBLEM.....
Aug 09, 2011 | LG 42PC3RA 42 in. HD-Ready Plasma TV
My 42 inch plasma has black distorted picture
hi
its cathode ray tube problem or the colour wheel...check that both please.....
thank u,,,,,,
Mar 07, 2009 | LG 42PC3D 42 in. Plasma Television
Vertical lines across my entire screen
My 42" Samsung Plasma HDTV HP-R4252 has a 2" vertical strip of green pixels down the right side of the screen.
My 3 year warranty with Circuit City expires in Nov 2008.. so I hope I'm covered.. can't call until the morning.
Samsung said it might be a logic board problem.. but they want almost $2000 to fix. I might as well buy another TV if Circuit City can't fix it.
Apr 19, 2008 | Samsung HP-R4252 42 in. Plasma HDTV
Vertical bar on Daewoo Plasma screen
YES YOU HAVE DRY JOINTS UNPLUG FROM POWER SUPPLY REMOVE THE BACK/ INSIDE YOU SHOULD SEE AT THE BOTTOM SEVERAL RIBENED CONECTORS FROM THE SCREEN ITSELF? UNDERNEATH YOU SHOULD BE ABLE TO SEE 2 OR 4 COMPONENTS CAREFULLY APPLY A HOT SOLDERING IRON AN SOLDER THE ONE THAT YOU ARE HAVEING PROBLEMS YOU SHOULD NOW HAVE FULL PICKTURE AGAINE ANY PROBS email me andymay2@msn.com
Mar 09, 2008 | LG 42PX5D 42 in. Plasma HDTV
LG PLASMA TV WITH COLOURED LINES OVER SCREEN
If the Video (Picture/Pix) is gone but you can hear the Audio (sound), then it could mean the YSUS PCB Assembly is gone/kaput/finish. Can replace the PCB, not repair the PCB due to timing circuitry involve. Cost maybe roughly $500 depending where you located. The PCB is located on the left hand side of your TV when you are facing the back (Back open). Might find 3-4 brown flex membrane connecting to the plasma panel. The PCB has a silver or black aluminum heatsink (big) on it.
Good Luck.
Dec 22, 2007 | LG 42PX5D 42 in. Plasma HDTV
LG 42 PLASMA
check all inputs on tv ,also check if menu on tv is working ,make sure lines arent being produce by another source, cable box etcc..If menu and or OSD are affected .Then there is a good chance you have lightning damaged some where in signal section on tv .
Dec 03, 2007 | LG 42PX5D 42 in. Plasma HDTV
Daewoo 42 Plasma - Model DT4280NH
I have a samsung 42 in plasma television which is three years old, it has a blue flickering light to the right of the television, sometimes can see some at the top in the middle, hope you can help with this problem, is it repairable.
Sep 02, 2007 | Akai PDP4294 42 in. EDTV-Ready Plasma...
Lg 42" plasma labeled by sky
Could be a component inside is going bad which mean it'll die soon. (it just trying to tell you to save $ for a new TV) Or wire is lose somewhere. (My work pc, I touches the monitor cable and sometimes it switchs color like you described)
Aug 25, 2006 | LG MZ-42PZ14 42 in. Plasma Television
LG Flatron L1951S-SN 19" LCD Flat Panel Monitor Logo
347 people viewed this question
Top LG Computers & Internet Experts
Ekse
Alun Cox
Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
