Washing machine off balance in one cycle
Hoover 500 m top loader washing machine keeps getting off balance during the pre rinse cycle. never during any other cycle. re distributing the load doesnt work only thing that does is holding the tub while it goes through the cycle til it gets to spin dry. dont want to make that a permanent thing just needed work clothes
    New Friend:
  • 88 Answers
Make sure washer is on a level surface and all four feet adjusted properly. A slight forward lean may help with this problem as the out of balance switch is at the rear.
Posted on Feb 28, 2010
6ya staff
SOURCE:
Why does my washing machine not complete a rinse & spin cylcle?
is it a top loader? if so, older top loaders do not have a balancing function so you must evenly distribute the load.
Oct 16, 2016 | Washing Machines
Always out of balance
out of balance is from the tub not level and or the air dampeners on the ends of the suspension rods are broken( top loader machines ---machine type not stated --
if it is a top loader and you laid it on its side , it is possible that the tub is now not level and the dampeners have been damaged
Oct 23, 2017 | Washing Machines
My Kenmore 500 top loading washing machine wont work right. sometimes it will work and other times it wont. I will put a load in it and sometimes when it hits the rinse cycle it seems like it gets stuck...
for the top loading washing machine mostly have drain pump, please check the filter of your drain pump, if clog your drain pump of some hair pins,cotton buds or coins or any small item,that the cause of water stuck,and it will long time draining or totally not running the drain pump.and its cause of stop of cycle of washing machine in rinse time or spin time,because after washing the pump must be on to remove water before start the next cycle.and the unit top load have drain pump you must be up the drain hose up to 90cm from floor lever to make the water lever is make in normal,the water automatically goes out by drain pump.
and for unbalance most of all top loader have problem in unbalance, the main reason is overload or the type of cloth you wash.
Nov 02, 2013 | Kenmore 24032\24036 Top Load Washer
OUt of balance during rinse and spin cycles
I have the same problem. During the spin cycle, the washer spins all over the room.....very loudly.
Dec 26, 2009 | Maytag Washing Machines
Why does my front loader washing machine bang loudly during the wash/rinse cycle - it is not overloaded or on an uneven surface?
it is either out of balance from over loading or the center rotorey bearing is bad ,,most likely problems
Nov 09, 2009 | KitchenAid KAWS850L Top Load Washer
My 5 year old Hoover 500 mb has started to stop mid cycle or not progress through the cycle !
Mate, I just had the same fault with the same model machine. The local machine repair man called me (i'm a sparky) to double check things for him. The macine stopped at the pre wash rinse part of the cycle every load. He replaced the timer with two NEW ones which both had the same fault as the original. We now suspect an inherrent fault in the timer design but as yet dont have an answer.
Aug 10, 2008 | Hoover Washing Machines
Hoover 550 MA Top Loading Washing Machine
if if spins the belt is ok,may have timer fault or timer module ( next to timer) if fitted will be faulty
Mar 24, 2008 | Washing Machines
Hoover 2305 washine machine wont spin
hi, i have a hoover 500 mb, occasionally it will not [ click into ] the wash cycle, then gets confused and does not spin dry properly
Jun 24, 2007 | Hoover HTC243 Top Load Washer
Washing Machines Logo
184 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
Marvin
Marvin
