Question about Panasonic DVD-A115
Lately when we rent a dvd our player says that it can not read the disc. I have tried cleaning it and that doesn't help. Other dvds still work.
  • 132 Answers
I think you just got a bad DVD. Might be scratched, might be the wrong region, or it just might be incompatible with your player. I would tell them it won't play give me another one.
Posted on Mar 03, 2010
SOURCE:
The dvd player side doesn't want to read all discs. Some it just flashes the loading and makes a clicking sounds, sometimes it loads up and freezes on dvds, it does this when i try to put in a cleaning...
The clicking is made by the laser head as it moves across the surface of the disk repeteadly trying to pick up the data signal and failing.
If it has used to work then it's clearly a dirt problem. If a cleaning disk has failed to work then the dust has gone all the way to the reading sensor. To clean it you will need top completely dismantle the unit access the optical mechanism, take off the cover and access the reading head - there blow with the can between the lens and the sensor then with a q-tip wipe the surface of the lens.
Sep 17, 2011 | Philips Magnavox DVD/VCR Dual Player
My dvd/vcr recorder combo records, but the playback is the problem. I get disc error, or the disks skip and freeze. the problem has only recently started and with recorded dvd's i've played back with no...
If this doesn't happen with regular DvDs you rent or buy, there may be something wrong with the way you're recording DvDs then.
It could also mean the lens head on your DvD reader is dirty
below is a link with instructions on how to clean
http://www.ocmodshop.com/ocmodshop.aspx?a=1225
May 02, 2011 | Philips Magnavox DVD/VCR Dual Player
Hardly used it & now it doesnt recognize any dvd any clue what could be wrong
Laser eye reading buble,might be dirty,reqiure cleaning or having problems with those DVDs disc's itself like dirts,grimes or cracks and big scratches on those DVDs disc's laser shinning surfacing data's reading side?Check all ur DVDs disc's again u are using,might just require a good cleaning on DVD's discs on the reading data's shinning surface sides,with some dish washing soap?If the DVDs disc's are not the problems.Tries websites like Ebay.com,Amazon.com to buy a DVD disc cleaning kit.By using the DVD cleaning disc,might work,might not.But than u don't have to be littery taking the portable DVD player aparts and used some Q tips,dipping in with some rubbing alchahol to clean the Laser eye reading buble itself.
Dec 01, 2010 | TruTech PVS12701 Portable DVD Player
Hi, my DVD player was bought in Hong Kong, brought it back to England to use. recently, it is not reading discs properly, always say"no disc", no problem to read card though. I am wonder how and...
DVDs are encoded with a "Region Code" to allow studios to control release dates around the world. Hong Kong Region Code is 3, UK is 2. Your player will not play back Region 2 DVDs that you are purchasing or renting in UK. It will work fine with Region Code 3 DVDs I would bet.
Sorry to deliver the bad news.
Oct 27, 2010 | Philips DCP750
-bad disc reports
The problem with using rental discs is that they are dirty. Buy a dvd player cleaning disc and follow the instructions. These discs help to realign the laser. If this does not help try cleaning the disc with a disc cleaner. Also depending on how new the dvd is there have been a lot of discs manufactured outside of the US that have been bad. It may not be your machine but the discs. I personally went through 6 of the same movie before i gave up and rented something else that worked perfectly fine. Hope this helps you watch.
Sep 11, 2008 | Televison & Video
DVD problem
It could be a couple things...
#1. Over time, dust and deposits can accumulate on the laser that reads the disc. In many cases, DVD players with this problem can still read CDs. You could try a DVD laser cleaner, which is usually a disc that has a tiny brush glued onto it. Run the cleaning disc 2 or 3 times, and try it again. Try both CDs and DVDs, since CDs are easier to read than a DVD.
2. After a DVD player has been used for awhile, another common problem is that the laser in the DVD player becomes misaligned, inhibiting its ability to read DVDs. In many cases, DVD players with this problem will still be able to read a CD. I'd try a cleaning disc first, since the only way to fix this problem is to bring the unit to a service center for repair.
Let me know what happens after you get the DVD laser cleaner and run it. Hope this helps.
May 07, 2008 | Televison & Video
Mizuda dvd player wont read dvds
A couple of things To try.
1:) The DVD Player May be Region encoded, can only play certain region Dvds. ** Try different Disks**
2:) The Disk May Be Dirty-Scratched ( Towards The Centre )
** Clean The Disk With A Soft Lint-Free Cloth**
3:) The Laser Head may have a speck of dust or debris on it.
** Try a Laser Cleaning CD**
Hope this works For You.
Mike @ Compurepair.
Mar 01, 2008 | Shenzhen Mizuda DVD-999 DVD Player
Can't read disc
Possibly a bad, or more likely, a damaged disc.
It's not uncommon, especially with often abused rental copies.
Tell Blockbuster - they should give you a credit on the rental.
Jan 12, 2008 | Sony DVP-NS700P DVD Player
Panasonic DVD-A115 Logo
61 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
