Question about O2 Samsung SGH-E250 Cellular Phone
I have replaced charging socket on samsung e250. Would not power up or charge before. Now when I plug in charger, the screen flashes between the "charging" screen, white screen and "Samsung E250" screen. Also keypads light up / go out. Any ideas please as to what the problem might be?
SOURCE:
  • 316 Answers
SOURCE: Keypad Locked on Samsung SGH-E250
are you getting a display on screen? if yes then the phone soundslike it's faulty send it back.
if no screen display check that the sim is in the correct way
Posted on Jan 18, 2008
SOURCE: samsung e250 freezed
Enter in with no sim #*7337#
Posted on Mar 06, 2008
BearWeb
  • 357 Answers
SOURCE: SAMSUNG SGH-E250 puk blocked
Hi everyone
Every PUK code is unique so nobody can tell you your PUK number, but i will tell you what you can do!
1) If you still have your packet that your Sim Card came in, you should find your PUK number in there, if you don't have the packet, please read bellow.
2) You must get a phone that is on the same network as your phone and call the networks Customer Care and ask them for your PUK number, they will ask you for your phone number, then they will tell you your PUK number. Once you have done this, you will be able to reset your Pin number so you will be able to go into your phone again.
Please also remember to give me a good rating on my profile.
Kind regards
Dustin Ellse
Posted on Jun 26, 2008
SOURCE: Samsung shows a white screen
what is the solution when my cellphone SGH-E250 turns to white screen?
Posted on Oct 05, 2008
  • 9 Answers
SOURCE: I HAVE SAMSUNG SGH-E250 ONLY WHITE SCREEN - REMEDY PL.
flex problem
Posted on Jun 12, 2009
My dell inspiron plugged in not charging
buy a replacement charger
if this does not work
i suspect the socket is perhaps damaged
sometimes its the laptops power management
so take the battery off
open the screen
press the power on
wait a few seconds
plug the battery back and the power
and see if the light flashes for charge again
i do suspect the charger or the laptops power socket...
Apr 19, 2015 | Dell Computers & Internet
Light does not flash when charging battery
Please try this:
1) Make sure camera is OFF.
2) Plug Charger into the wall (not into camera)
3) Last think plug charger into the camera
Oct 15, 2014 | Nikon Coolpix S3000 Digital Camera
My Samsung s5 is not charging
try this
SAMSUNG GALAXY S5 - NO POWER, BATTERY, CHARGING AND CHARGER ISSUES alltabshighlighted.jpg
No power, battery, charging and charger issues
This guide contains troubleshooting steps and advice to help resolve issues you may experience when attempting to charge the handset.
After performing each step, please test to see if the issue is resolved.
Symptoms:
  • Battery not charging
  • Battery is not lasting long
  • Phone won't charge
  • Charging error
  • Failure to charge
  • Display remains black or blank
  • No power
  • Boot failure
  • Overheating
Troubleshooting Questions
  • Are you using the correct equipment?Make sure you are using an approved Samsung wall charger and USB charging cable. Other brands of charging accessories may have different voltage parameters and could cause charging issues when used with Samsung devices.
  • Have you charged your phone for longer than 30min? Leave your phone plugged in to the charger for about 30min without powering on. In some cases, it may take slightly longer for your phone to charge.
  • Is the battery icon displayed on the screen when charging? After charging your phone for a little while you should get a battery charging icon appear on the screen which will indicate that your battery is charging properly.
    If the charging icon appears, leave your phone for a little longer before you try to switch your phone on.
    If however, the screen is blank and nothing is displayed, follow the below troubleshooting steps.
  • Is the charging cable plugged into a USB port? Some charging cables can disconnect from the wall outlet adapter and plug directly into a USB port. However, when plugged into a USB port, the charging process is much slower due to the limited power output of USB ports. Instead, plug the device directly into a wall outlet to speed up the charging process.
  • Is the outlet faulty? Try a different outlet or check for a switch connected to the outlet. If possible, try powering a different device on the same outlet.
  • Does another USB cable, or wall charger work? Charging issues can occur if either the battery or charging cable is damaged. Verify that the charging contacts are clean. If necessary, clean the contacts using a cotton swab and rubbing on isopropyl alcohol.
    If possible, test the charging cable by plugging it into another device and seeing if the device charges. Alternatively, try charging the device with a different cable. This may mean changing out the cable or the adapter on two-piece chargers.
    If charging through a car charging kit, ensure that the car engine is running, and if possible try to charge other devices using other cables, through the same car kit. If none will charge, then it is likely there is a fault with the car charging kit. It is recommended to continue to cross-test devices, cables, and car kits until the problem device can be identified.
    If the device charges when using a different USB cable or wall charger, the issue most likely lies with the charging accessory. In this case, follow the approved charger repair / replacement process.
    Also, if the charger is connected via an extension or other multi-socket adapter, remove this and plug the charger directly into the wall-mounted socket. This will eliminate the possibility of a fault with the adapter.
    If you are still unable to charge your device, continue to the next step.
  • Has the phone experienced any shock or exposure to water? Accidental physical shock to a handset can sometimes cause problems to arise with battery or charger, as these components contain delicate parts, particularly. Damage can occur either to the component itself, or to the component's connection to the motherboard.
    Water exposure can also lead to damage of these components, however due to the slow way in which this type of damage can manifest itself, the cause may not always be readily obvious.
    With any physical damage of this nature, the only recourse is to contact the device manufacturer, and follow their approved repair or replacement process.
^_^
Jul 04, 2014 | Samsung Galaxy Cell Phones
My samsung sgh-e250 has a problem with charging it charges off and on
Hello, when a phone does not charge, it means that the phone charger or the port at which the charger is inserted in the phone is faulty.
Might be due to dust or dirt. You can Clean charging port on the phone with a brush and alcohol to remove dirt.
After cleaning it,if still not charging, you can test charger with another phone to be sure if the charger is working. And ifcharger works with another phone,that means the charging port on the phone is faulty and will need to replaced.
Take care.
Aug 16, 2010 | O2 Samsung SGH-E250 Cellular Phone
Battery charging issue
Check your mains adapter plug that connects into the laptop power socket with a multi-meter, the voltage should be slightly higher than the voltage that is printed on the label on the bottom of the adapter. If the voltage is zero or way below the voltage that is printed on the label then the power adapter is faulty and needs to be replaced.
If the adapter is OK then connect it to the laptop and power it up, then look at the power/battery charging LED light and wriggle the power plug in the laptop's power socket. If the power/battery LED light flashes and in a certain position this LED light stays firm, then the power socket is either faulty or it has a dry solder joint where it is connected to the motherboard.
This can be repaired but it requires the laptop to be completely dismantled to get at this power socket and repair. I suggest you get a quote first.
Oct 11, 2009 | Advent Netbook
Charging problems Samsung i70
I have had exactly the same problem. It appears to be to do with a fluctuating power source, believe it or not. I certainly didn't know my power fluctuated! Try charging from different sockets in your house. Mine works in one socket only! It's a single socket, whether that is significant.
Aug 07, 2009 | Samsung i70 Digital Camera
Samsung NP R70 Laptop won't charge
Most laptops will work with or without the battery and with the power adapter connected.
If the power adapter is OK, just connect it to the laptop's power socket and wriggle this plug. Does the charging LED flash as you wriggle this plug? If so the power socket may have a dry solder joint or it may be faulty. Either way the laptop needs to be dismantled to solder or replace the power socket.
Jul 21, 2009 | Computers & Internet
My Samsung R40 will not charge. The cable/charger
it is called the AC power Wall Socket is that what u r talking about do u think u can replace it i think u should call some elec guy to fix it like maintenance guy it has nothing to do with ur notebook its just the pins inside the socket got loose and ur plug is unable to stand in there am i right pls vote if u find me helpful
Feb 22, 2009 | Samsung Computers & Internet
Samsung sgh p310 wont charge
check to make sure it is connected properly and whether the pins in the phone's charging slot are not broken, because I have a samsung SGH-D807 and I forced the charger in the slot and the pins got broken, it won't charge. I have to repair it.
so connect it properly and check to see if the pins are broken, if not, try another power socket to plug the charger in, not all sockets are compatible with a charger.
Dec 13, 2008 | Samsung SGH-P310 Cellular Phone
O2 Samsung SGH-E250 Cellular Phone Logo
246 people viewed this question
Top O2 Cell Phones Experts
Ekse
asber
Are you an O2 Cell Phone Expert? Answer questions, earn points and help others
