Question about LG 42PX5D 42 in. Plasma HDTV
42" LG Plasma with 4" vertical lines at each end
New 42" LG HD Plasma TV has 2 vertical 4" lines at each end of picture?? This usually looks a little lighter in color than the rest of the picture?? IT looks like the lines that are visable during the commercial when it is not full picture or the TSN Vertical lines when again it is not full screen. Is this normal or should these lines disappear after picture goes back to full HD picture?...Thanks
  • Anonymous Apr 18, 2009
    linhas verticai no canto da tela
  • Anonymous Mar 24, 2014
    screen picture flickers on and off.
LG service is non- existent . The only solution that I can suggest is "Give a wide berh to LG products. Dont ever touch any"
Posted on Mar 09, 2008
SOURCE:
Vertical lines with no picture on a RU-42PX10C LG
You can either use test equipment etc or start guessing----most likely board would be main board that controls screen and all information viewed there.
Want to see what boards it may have: shopjimmy.com
Jun 12, 2012 | LG RU-42PX10 42 in. HD-Ready Plasma...
42inch LG plasma TV
well if you could please give out the model nuumber thank you
Sep 10, 2008 | LG RU-42PZ61 42 in. HD-Ready Plasma...
My ten year old sony plasma tv has vertical herring bone lines no picture just color lines. Is my picture tube gone.
If its 10 years old boards and or parts will likely not be available--average life on Plasma and LCD sets is 3-5 years.
I would retire it--recycle it and buy a new set.
May 16, 2012 | Sony FWD-42PV1 42 in. HD-Ready Plasma...
1" black vertical line in center of screen. Sony Plasma.
NOT DEFECTIVE!!!
There are 4 or 5 ribbon cables on the bottom or on one side, they control part of the plasma screen. Check the ribbon cable2_bing.gifnear the black lines. Unplug the ribbon cable and look for black chipson the underside of it, I think they say 100 on them, you need toresolder both ends on each chip. Should fix the black line issue.
Aug 19, 2009 | Zenith P42W34P 42 in. EDTV-Ready Plasma...
Blue vertical line thru picture
It is called "Thin vertical lines" and change colors depending on the background color.
It is fixable but there are several components that can show this sympton.
You will need a tech to fix it in order to save money (because you do not want to buy a board you dont know if will fix it).
Possible Solutions:
Replace Timer Control Board, if it is not fixed
Replace Sustain Board.
One of those boards needs to be replaced and I wrote the most likely first.
May 27, 2009 | LG RU-42PX10 42 in. HD-Ready Plasma...
Multi coloured vertical stripes on plasma screen
With half of the screen working, and with a Plasma tv. I will look at the driver board as being bad. Take the back cover off, the driver pcb will be at the top or bottom of the set. They are only about 2 inches tall and will cover most of the lenth of the set (2 boards that run end to end). The board that is on the side of the tv that is bad is the bad board. Replace that board or have a tech replace it.
Nov 15, 2008 | LG 42PX5D 42 in. Plasma HDTV
Red in picture
Have you tried with a new scart or htm lead?
Sep 23, 2008 | LG 50PX4DR 50 in. Plasma TV
Plasma TV technical difficulty
if you can still see the picture its most likely the control board that's going bad, you will still need a tech out to fix the issue.
May 19, 2008 | LG 42PX5D 42 in. Plasma HDTV
Plasma tv vertical lines
I am getting a vertical green line on my lg 50 incs is the screen or have you a solution
Sep 03, 2006 | Sony WEGA KZ-42TS1 42 in. Plasma...
LG 42PX5D 42 in. Plasma HDTV Logo
819 people viewed this question
Ekse
