Question about Samsung CLX-3175FN Color Laser All-in-One Printer
Multi-function Samsung CLX-3175 doesn't scan to PC
I have a multi-function Samsung CLX-3175FN printer. I recently got a new PC with Windows 7. I've installed the Samsung printer as a network printer via ethernet cable to a Linksys WRT320N wireless router. I can use the printer function but when I try to scan something from the printer to my PC, the control panel on the printer says "Not available". I am able to scan and save directly to a USB device such as thumb drive plugged directly into the printer/scanner. Prior to getting this new PC with Windows, I was able to scan from the CLX-3175FN to my previous PC. My previous PC had Windows XP and the printer/scanner was installed as a local printer via USB cable.
    New Friend:
I had the same issue with Windows 7 64 bit.I managed to solve it by doing the following
1. Locate the scan2pc.exe program in C:\Windows\twain_32\Samsung\CLX3170 2. Right-click/properties - Compatibility tab. 3.Set compatibility to win xp. Set "Run as Administrator"
I also added the scan2pc.exe to the firewall allowed programs (did that for scanmgr.exe as well, but I don't think I needed to).
Works great now!
Good luck!!
Posted on Apr 30, 2010
  • 2 more comments
  • vova831 May 04, 2011
    Helped with Samsung CLX-3185N, in addition, IP address was set as static in printer's Network settings.
  • dreamfox001 Aug 27, 2011
    had the same style of problem, aldough using both several xp and windows 7 in my network on a clx-3185fw, the problem was not the compatability, but more the fact that as from the moment the ip adress changes, it doen not on the pc's in the samsung scan management soft. what you should do is the following:
    whatever win7 or xp: run from the start/programmes/samsung/scan and fax management program. try to locate the samsung 's ip, click on the found printer and propoerties, change port, search for printer, click on the found printer and confirm settings.
    That did work with my problem having looked for hours and hours...
  • bkester123 Sep 04, 2011
    I had a similar problem. Situation: 2 networked PC's, one Vista, one Win7. For unknown reasons I would get the message, "Scan ToPc MFC has stopped working" on either PC. That PC could still print, but the 3175fn no longer even offered that destination in the scan options. No amount of re-booting equipment would re-instate the PC. Then when the 2nd PC would get the message at some other time, the USB option was the only option on the lcd.
    I devised a work around to get them both recognized by the scan function. On each networked PC, Start> All Programs> Samsung CLX3170 Series> Maintenance -leave default Repair button indicated> After port search leave the default “Local or TCP/IP Port” indicated, but reinstate network port by clicking on it.
    I have had to do this a few times, it's a pain, but at least I get all scanning functions back to my networked PC's
  • mark49063
    mark49063 Nov 27, 2012
    For me, opening the firewall did the trick. Curiously, when I then disabled the firewall rules just to experiment, the scan to PC function continued to operate!
    New Friend:
I have found out that two things are important.
  1. Scan Manager on the PC/MAC must NOT be open when you initiate the scan for the scanner. If it does it you get an error message. "Warning! Error during scan.
  2. The IP address of the printer must be correct in the properties section of Scan Manager. If not, you get "Not available" on the display when you try to initiate the scan.
My setup is CLX-3175FW and Mac OS 10.6. I guess the same applies to other 3175 models and Windows PCs.
Posted on Apr 08, 2010
    New Friend:
Going in to scan and fax manager and adding the printer fixes this. choose edit or whatever the option is and let it search the network for the printer. I have found out the root cause of the issue. If at any time you go into the network configuration from the menu on the printer it will wipe the settings in the scan and print manager and you will have to correct the IP.
Posted on Feb 06, 2012
    New Friend:
Had this problem on XP, turns out after quite a bit off messing about that i had 'microsoft loop back' adapter installed, this isnt needed on my pc anymore, removed from devices and it worked instantly....
Posted on Aug 01, 2012
SOURCE:
Replace Imagine unit Soon
Log into the service menu Samsung CLX-3175 without a numeric keypad similar to the unit Samsung SCX-4623F/FN:
Consistent set of combinations of
"MENU" - "COPY ID" - "LEFT" - "RIGHT" - "MENU" - "BACK" . Samsung CLX-3175XX/X with a numpad press: Menu, #1934, Menu
The unit switches to English, if you installed any other.
In the menu appears TECH MODE.
In
Samsung CLX-3175 to enter the reset require a password 1934. The numbers by pressing "LEFT" - "RIGHT",
After each number press the "OK"
Good luck in the reset.
Have any questions, you here http://skit-ltd.narod.ru/
Jul 04, 2011 | Samsung CLX-3175FN Color Laser All-in-One...
I need to downgrade to previous firmware for Samsung CLX printer. (clx-3170 0r clx-3175)
Unfortunately, once you install a firmware upgrade it is permanent. Driver updates can be reversed but not firmware. That is why you should always have a definite reason for upgrading the firmware.
Jan 06, 2011 | Samsung CLX-3175FN Color Laser All-in-One...
How to set black & white print as defult for CLX-3175
can be set in windows, just like other printers
Goto start, printers, select samsung printer, right mousebutton on samsung printer, select preferences, graphics, colourmodus gray.
(translated my Dutch menu to English)
In default my printer prints BW, if i need colour prints, same menu youll get in any program by using printsetup, set it to colour and send your printorder.
Sep 09, 2010 | Samsung CLX-3175FN Color Laser All-in-One...
My samsung 3175fn laser printer keeps getting a black line and ye
The printer has a build up of toner on the drum/fuser, a maintenance cleaning done by certified technician of the printer would fix this problem.
May 31, 2010 | Samsung CLX-3175FN Color Laser All-in-One...
What toner does the clx 3175 take. Does it use a chip as well - which one?
Takes CLP 310
To use Toner refill you need a chip that solder to the main board. search Ebay for reset chip for CLX-3175
run around $40.
Service Manual Free
http://hotfile.com/dl/28988134/55113fe/CLX-3170-3175.zip.html
Feb 12, 2010 | Samsung CLX-3175FN Color Laser All-in-One...
Brand new Samsung multi-function CLX-3175FN prints a shadow or "ghost" image in color.
Have you done a print head alignment? If yes, and that did not fix it, take it back before you warranty runs out. Most modern day electronic devices work perfect but when they don't they also do it perfectly.
The only things you can do is print head alignment and making sure when you installed those nice new print cartridges that they are pushed in all the way. To try and test anything else will cost money and since this is a brand new device it is best returned.
Aug 09, 2009 | Samsung CLX-3175FN Color Laser All-in-One...
Sanner is locked!
Service Manual at
May 31, 2009 | Samsung CLX-3175FN Printer
Samsung CLX-3175FN Color Laser All-in-One Printer Logo
33,068 people viewed this question
Top Samsung Office Equipment & Supplies Experts
jasbo
jasbo
Steve Allison
Steve Allison
Lawrence Singapore
Level 1 Expert
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
