Question about Sony BRAVIA KDL-40V2500 40 in. LCD HDTV
My sony bravia 40 inch tv, almost half the screen is black with vertical bright pink, yellow, green stripes running through it, and almost a shatter effect of white lines in the corner. we have not damaged the tv, and there isn't a mark or chip on it. what's happened?
  • 178 Answers
Does it look like the bands in the picture? it is defective panel.my sony bravia 40 inch tv, almost half the screen - d817bda.jpg
Posted on Apr 21, 2010
Testimonial: "it's like that, but with a shatter/spider web pattern in the corner. an engineer said it was caused by impact damge - but this isn't the case. if we use the tv now, it just spreads and gets worse"
  • Shukai Fung
    Shukai Fung May 26, 2010
    you said with a shatter/spider web pattern. I think it look like this picture. this is the LVDS cable or the T-con board fails and not the panel.
6ya staff
SOURCE:
I have a 70 inch Bravia XBR 70X850B which up until yesterday green/red/pink vertical line that runs across the middle of the screen.
If you wish to get some details; check the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/ Line faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Search the site by type in the "BRAND NAME" of your device; (Exclude the model number), in the "Search box at the top right of the display window of the Homepage" to get gathered related posts
Nov 17, 2016 | Sony XBR Televison & Video
I have a Sony KDL-32BX300 showing vertical lines. Is this repairable?
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Line, faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent.
Apr 30, 2015 | Sony Bravia KDL-32BX300 32" 1366 x 768...
Horizontal lines on SONY TV
the ribbon flat connection tapes that connect the led panel driver to the panel have prob delaminated
this cant be repaired easily and you would need to replace the panel
Dec 05, 2014 | Sony KDL40EX520 Bravia KDL-40EX520 40 Inch...
Free tv repair advice
try looking through all the settings to find something about the screen brightness then change something, see if there is a difference then reset your tv/ turn it off then on again.
hope this helps :)
Jun 27, 2013 | Sony BRAVIA Televison & Video
Vertical lines after the tv is been for a minute
If you can open LCD Tv than refit all connector of Mother Board
Jan 21, 2010 | Sony BRAVIA KDL-40V2500 40 in. LCD HDTV
Pink line across top of sony wega 46" tv
after changing the lamp, I still had the same problem as you. I contacted sony and they offered me a brand new 40 inch bravia flat screen tv replacement...at no cost! If I chose a 46" or 55" there would be a charge between $325
Dec 24, 2009 | Sony Grand WEGA KDF-55XS955 55" Rear...
Vertical line on TV
usualy this problem is cause by the lcd drive board.
Oct 09, 2007 | Sony BRAVIA KDL-40S2010 40 in. LCD...
Vertical green line on screen
If your set is a plasma, this can be one of two problems : either there is a loose connection (one of many, many connections) between the plasma screen and the driver board, or one of the transistor devices has blown. Try GENTLY applying pressure to the opposite ends of the TV to give it a subtle "twist" (please be careful!). Sometimes moving the set to a different location will produce the same effect. If it's still under warranty, call your dealer. Vertical stripes are a common fault with plasma technology I'm afraid! :-( Next time, go for LCD!
Apr 09, 2007 | Sony BRAVIA KDL-V40XBR1 40 in. LCD HDTV
Sony BRAVIA KDL-40V2500 40 in. LCD HDTV Logo
2,482 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Ekse
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
