Question about Apple iPhone Smartphone
My iphone show me a apple logo but dont start after that
    New Friend:
  • 12 Answers
Need to restore iPhone, put it in DFU and do a restore
Posted on Jun 13, 2019
    Master:
  • Apple Master
  • 498 Answers
If your iPhone was stuck at the Apple logo screen, you can follow below solutions to try to fix it.
what to Do When iPhone Stuck on Apple Logo The first method that users want to try may be resetting the device. People need to hold the Sleep/Wake button and the home button at the mean until you see the Apple logo again, and then release the button. This simple method may be helpful when your iPhone get stuck on Apple logo by mistake.
But some iPhone users get no luck when they try the method above, they only get the loops between the black screen and the Apple logo. At this moment, the users will need to restore their iPhone with the computer. The following guidance will show you how to do it.
  1. Turn off iPhone. If you can't turn it off, just hold the Sleep/Wake button and the home button at the mean time for a few seconds.
  2. Plug your iPhone into computer via the USB cable, and hold the home button when you connect iPhone to computer.
  3. When you see the "Connect to iTunes" screen, release the home button. If you don't see the screen, just repeat the steps above for another time.
  4. Then you will get the notice: "iTunes has detected an iPhone in recovery mode. You must restore it before it can be used with iTunes".
  5. Then restore iPhone with iTunes.
If your iPhone is stuck on Apple logo, this method may also be useful. But sometimes you may only enter the recovery mode by mistake. At this moment, you can restart your iPhone to exit the recovery mode, or wait for 15 minutes, and then the device will exit the recovery mode itself. Of course, iTunes will erase all the contents and settings on your iPhone after you restored the device. You may lose the newly added data in your iPhone, and you will have to restore the iPhone with the backup.
When iPhone is stuck on Apple logo, the users may have no other good ways to do except for restoring iPhone. So this also reminds us of the importance of updating iPhone backup. In our daily life, we may also experience the data loss occasionally and don't want to use iTunes because we don't want to lose the newly added data. At this moment, a piece of iPhone data recovery software will provide much help.
If this method doesn't work, check this guide. iPhone Stuck on Apple Logo? How to Fix It
    New Friend:
  • 37 Answers
To fix iPhone stuck in Apple logo, my option is to use Tuneskit iOS System Recovery to fix it. It is designed for all iOS users to fix iPhone stuck in white Apple logo, black/blue/white/frozen/locked/boot loop screen, recovery mode, iOS update failure, headphone mode, etc in several seconds. You can have a try depend on own needs. https://www.tuneskit.com/ios-system-recovery-for-win.html
Posted on Apr 28, 2019
    Novelist:
    Habit-Forming:
  • 72 Answers
You may be one of Apple users attracted by the new features of iOS 10.3.3 or the newest iOS 11 and now you try to update your device. But while updating, your device stuck on Apple logo and cannot work. So how to quickly get out of this bad situation? In this post, I give you some solutions that you can easily follow and have a try.
Don't Miss: How to Fix iPhone Stuck on Apple Logo.
Solution1:Force Restart iPhone iPad
Have you tried to power off your device to clean all processes on your iOS device? If you can't power off your device by press "Power/Sleep" button, you can try to force restart your device to get your device out off "stuck on Apple logo".
Solution2:Restore in Recovery Mode
If restarting can't help you get out of the problem "iPhone stuck on Apple logo", you may need to restore your device in Recovery Mode.
Solution3:Use iOS Repair Tools
Some recovery tools could help you fix this iOS issue. For example, by using iOS repair tools of Fonedog, you can get your device out of stuck on "Apple Logo", "Restarting Loop" or "Connect to iTunes".
Hope it can help you.
Posted on Dec 18, 2017
  • Apple Master
  • 4,199 Answers
How to fix iPhone stuck on Apple logo?
My iphone 5 is stuck on a black screen and seems to be frozen, the apple logo is the only thing that appears when I try to start it up again! Sadly,I did not back up my data on itunes, is there a way to get it back to normal without restoring and losing everything?? I have already tried holding down the + volume button, or the home button trick, it didn t work. Help!!! Thanks
After Jailbreaking, restoring your iPhone, updating iOS version, sometimes iPhone users will find their iPhone can't boot up normally and stuck on Apple logo. Don't worry about it. In this article, I will show you a way to fix iPhone stuck on Apple logo without restoring your iPhone. If you didn't backup your iPhone, don't worry. You won't lose anything if you follow this article and fix iPhone stuck on Apple logo with iMyfone D-Back program.
D-Back is the best assistant for iOS users to fix iOS system problems. It can detect the problem of your iOS and fix it easily. It can not only fix iPhone stuck on Apple logo, but also iPhone stuck in recovery mode, iPhone stuck in DFU mode, etc. It works with iPhone 7/7 plus/6s/ 6s plus/6/6 plus/5s/5c/5/4s/4 perfectly.
dr fone toolkit iOS System Recovery How do fix iPhone in recovery mode How do fix iPhone in recovery mode
Posted on Oct 11, 2017
    Master:
  • Apple Master
  • 134 Answers
Just see the following tutorial about iPhone stuck on apple screen.
Some method may cause data loss, be cautious.
iPhone Stuck on Apple Logo Best Three Solutions for You
1. Fix iPhone stuck on Apple logo issue via force restart
2. Fix iPhone stuck on Apple logo via DFU mode
3. Fix the "iPhone stuck on Apple logo" during startup problem using iOS System Recovery
Posted on May 03, 2017
    New Friend:
    Problem Solver:
  • 5 Answers
SOURCE:
Unfreeze my iphone
Reset it with the home and power buttons until it shows the apple logo. If not, put it in DFU mode, but it will erase everything you have.
Mar 23, 2012 | Apple iPhone 3G
When I turn on iphone 3G it only show apple logo, after that it is turned off and shows nothing, Further when I connect it to itunes or computer it does not show iphone. I have tried to restart the set by...
Hello.
You'll need to reset the iPhone.
From About:
To do that, hold both the sleep/wake and Home buttons together for at least 10 seconds.
The red shut down slider will show up at the top of the screen and then disappear. Keep holding the buttons. The screen may even go black, but don't let go of the buttons until the Apple logo shows up. When it appears, let the buttons go and the phone will start up normally.
Hope this resolves your problem.
Jan 15, 2011 | Apple iPhone 3G
My iphone is disable
Step 1: Turn off your iphone
Step 2: PRESS & HOLD home button, then PRESS & HOLD on/off button on the top
Step 3: DONT release both button, untill u see Apple logo display, then release the on/off button, in the meanwhile still HOLD the home button aorund 30 sec.
The display will come out a screen, it showed USB & iTunes logo.
Step 4: Open your iTunes, RESTORE. FINISH & DONE.
Jul 27, 2009 | Apple iPhone 3G Black Smartphone
My iphone 3G does not starting up it simply shows the apple logo
U PLS do as i say ..............Open iTunes and connect the iPhone to your Mac or PC
Step Two
Press and hold the Home button and the Sleep/Wake button at the same time.
Step Three
After exactly 10 seconds release the Sleep/Wake button. Continue holding the home button until you iTunes pops up a message telling you that it has detected an iPhone in recovery mode.
The iPhone screen will remain black like this:
NOTE***: It may take a few attempts to get your iPhone into DFU mode. Generally, I hold down both buttons then release the Home button just before I think the Apple logo would appear. If you are still holding both buttons down and you see the Apple logo you are holding them down for too long!
Jul 16, 2009 | Apple iPhone 3G
Frozen Apple Logo
if itunes recognizes the phone use the restore option if not you need to perform a force recovery mode. to do this hold power and home screen buttons until the screen resets when it does keep holding the home screen button and plug in the phone to the computer after a few seconds itunes should see a phone in recovery mode and force you to do a restore. if that does not work you might have a hardware problem and will need to go to a store.
Jan 24, 2009 | Apple iPhone Smartphone
Iphone is not starting
You have bricked it, to fix follow:
Hold the Power and Home button for 10 seconds Release the Power button, hold Home for 5 more seconds. Plug into iTunes
Jun 24, 2008 | Apple iPhone Smartphone
Iphone not working
Turn it on so it goes to the apple logo Hold the power button and the home button
 Keep holding both until the screen goes black
 Let go of only the POWER button, but keep holding the home.
Connect you iPhone to your comp
itunes should open up. Restore
Jun 06, 2008 | Apple iPhone Smartphone
Apple iPhone Smartphone Logo
728 people viewed this question
Top Apple Cell Phones Experts
Ekse
jacobcheatha
Level 1 Expert
Are you an Apple Cell Phone Expert? Answer questions, earn points and help others
