Question about RCA 36V430T 36" TV
I dont get cable service in my area. i want to hook up a digital antena but i dont know if my set is digital capable or do i need digital converter box? it's a rca 36" modl# 36v430t
6ya staff
SOURCE:
zimcloud
  • 135 Answers
SOURCE: 36 inch RCA 36v430t
Mike-It looks like the power supply is going on your tv-it can be replaced. This happens, usually, when little kids are playing wth the remote or power button on the tv. Turn it off and on a whole bunch of times in a row, kids love to do that, and it burns out the power supply part- to make a CRT tv like your RCA36 incher- which is a beautiful machine- I have the RCA/PROSCAN 36 incher-LAST longer...You should always wait 5 min between turning it off and on. Don't ever sell it. This one is worth fixing. It has better color and sound Than the new plasmas and lcds-The Pros know this. Be carefull, they might try and talk you out of it-so they can fix it and have it for themselves. So what if it's not High Deff. It's a great set.
Posted on Jul 02, 2008
zimcloud
  • 135 Answers
SOURCE: 36 inch RCA tv (model # 36V430T)
I wouldn't advise doing it yourself. All you have to do to kill yourself is touch the wrong part connected to the magnets on the back of the tube-even if it has been unplugged for a couple of days- no joke. The repair place will be better able to track down the part, and install it, and guarentee it. Be aware- it might take a week or two for them to just get the part-then they have to install it.
ABRsvcs
  • 4234 Answers
SOURCE: rca 36" 36v430t
Without seeing the actual set, I can only suggest some of the common things that can cause this. Based upon your description, I would first look for a poor solder connection where the AC cable connects to the board. Look in that area for any charred spots. Let me know if there are any. The bussing usually is arcing of the AC power.
Dan
Posted on Oct 27, 2008
jumon
  • 18 Answers
SOURCE: I have an RCA converter box hooked up to an RCA tv
Basically, you cannot use the coax connections for both the VCR and the RCA converter box. I would hook up the phono/cinch connectors from the VCR to the TV if you can (these are also called RCA connectors, but I'm avoiding using that name so we dont confuse the digital receiver with a cable/connector name that is the same here). There should be a yellow one for video and red/white ones for left and right stereo. I believe the RCA converter comes with a three headed cable that can do this for you. With this configuration, you can set the TV to input on these connectors and the VCR should always output there. Once that is set, you can still use the converter box to receive the signal from your antenna, then run the coax to the VCR. Now, the VCR will always have to be set on channel 4 in your setup and you will need to manually change channels on the converter box for it to record a show. Does this make sense so far?
Posted on Feb 27, 2009
Anonymous
  • 93 Answers
SOURCE: my 36 rca modle f36715 makes a beeping noise and
the beeping sound means that you a shorted regulator and possibly a hign voltage transformer.shop time
Posted on Sep 06, 2009
I'm trying to auto search for chanels 19 inch. But its not connecting to any channels, the cable to the antena is conected and. I just dont know wich setting to search on the menu.?
You must purchase a digital to analog converter to receive over the air broadcasts now, that has been so for about 2 years. Your TV can't receive digital broadcasts directly.
Nov 04, 2016 | Televison & Video
Hooking up old Sanyo box tv with old magnavox vcr
You need a TV cable though ANY cable might work. But definitively the only way to connect a VCR co a TV is through the antena setting TV to channel 3 or 4.
Even if you can't see it, all old TV sets must have an antena input.
If you can't find it, call a TV repairman, should help to make a connection.
Jul 03, 2016 | Sanyo Televison & Video
Do you need a cable box for it
U mean a digital converter box for getting free broadcasting DTV airing channels?No,this tv it is a digital tv,just require a roof or a good digital antena.Hook it up with the antena and goto tv menu go to setup go down to Ch.pick AIR not CABLE and go into scanning for DTV channels after that tv will get all the free broadcasting DTV air channels.
Feb 17, 2011 | Toshiba 19HLV87 19 in. LCD HDTV
Do i need to buy a converter box for this tv
No,this tv is a digital tv,just reqiure a good antena like a digital antena or a roof antena.Hook it up.Just go into tv menu setup and set up to pick up AIR not CABLE and enter to scan for DTV free air channels.
Feb 01, 2011 | RCA L26WD26D 26 in. LCD TV
Cannot get TV to work on antenna...In menu I set cable to off, then initiate autoprogram but tv says "no signal". My antenna has a bulit in digital to analog converter. Suggestions?
Must buy a Digital converter box and to install it seperatly to devert back to tv anlogue tv signal to make the tv to work.Tv antena inverter alone can't convert analogue signal to digital signal only can give basic tv antena for better antena reception.Tries websites like Ebay.com,Amazon.com to buy a stand alone digital converter box to install and that didigal antena install and auto scan again u should able to get all the free DTV air stations.
Feb 01, 2011 | Sony FD Trinitron WEGA KV-32FS120 32" TV
I need to connect a digital bos to my emerson 1304 tv.i can not find any place to connect the coax
The antena hole input in the Converter box that where said the input source said Ant.,use a antena like a digital antena,roof antena or a rabit ear antena.Hook up ur source of the antena go in that hole.The hole input said out to tv in the Converter box,use a cable that was supply to u,came with the Converter box.Use that cable plug in the Conveter box tv hole said out to tv.The other end of that cable go to ur tv Ant. hole.Now u got it all hook up.Turn ur tv to channel 3 or 4 now u got a menu from the Converter box,go down to the highlight word said scan channels,push that highlight word.Ater the scan are finish,u will now get all the free DTV channels.
May 05, 2010 | Emerson EWC1304 13 in. TV/VCR Combo
Power antena after markit how to make it work with radio
on the radio there is a cable that is for Power Antena you might have to set a cable out to the area you are instslling the antena if this car already had a power antena you only need to hook up the leds from the old if not then like i said you need to get positive cable out to the antena and ground it to chassis
Apr 01, 2010 | 2000 Mercury Sable
I have hooked up my converter box but its not receiving any signal. do i need to buy a new antana? Or what could be the problem?
make sure u have the antena hooked to box and box hooked to tv, make sure antena wire is actually hooked to an antena if wire is coming out of the wall, otherwise u more than likely need a new antena, or box it's self is bad but if it turns on and u see somtin on the screen like make sure antena is hooked up then the box is probaly good
Nov 18, 2009 | Insignia Digital-to-Analog Converter for...
Connecting mt digital converter box
Antena will go into converter box input then out of the converter box output into the satilite boxes antena input then out to tv!
Please rate this response and help keep this area FREE!
Thank You!
Jan 22, 2009 | Televison & Video
Is my tv digital compatible or not
I have a Sylvania 27 inch tv from 1986. I currently have Cable TV. Is it possible that it will not work even with a converter box?
Apr 15, 2008 | RCA P46920BL 46" Rear Projection...
RCA 36V430T 36" TV Logo
41 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
