How to remove the drum on hoover elite 940 washing machine
  • 327 Answers
Hello,The motor mounting are usually the tensional method for the drum belt. You need a socket set to take the motor off and replace.Don't over tension the belt as it will ruin the bearings in the drum and motor.You should be able to deflect the belt by half an inch in the middle of its longest run with medium thumb pressure.Watch out for sharp edges on the cabinet when heaving on a bolt.
Thanks
Posted on May 23, 2010
  • katehollyr
    katehollyr Nov 11, 2012
    Does anyone have a Manual for this Washer? I have one but have no Idea how to use it?
SOURCE:
Hi there , the drum is jammed on my Hoover nextra top load washing machine , any advice on freeing it please ?
Remove the base to reveal the motor, belt and lower drum bearing. Decide which is at fault and replace it.
Jan 21, 2017 | Hoover Washing Machines
My washing machine is leaving dirty marks on my washing can you help?
Looks you have aleakage of grease form a damaged bearing in the drum.
If you have the technical preparation, you should remove the drum and check those bearing. See some interesting youtube videos about issue:
How to remove washing machine Drum tub 1 of 4
How to Replace Washing Machine Bearings
How to replace washing machine bearings on Candy Hoover Otsein Zerowatt
Dryer Repair Replacing the Lower Front Drum Felt Seal GE Part WE9M30
YOU EVEN MIGHT FIND MUCH MORE ON THEME DOING GOOGLE REARS ON
Youtube repair drum
Some other brands are similar to Hoover
Aug 22, 2015 | Hoover Washing Machines
Hoover elite washing machine
FIXYA has no idea of any parts for hoover machine . contact hoover direct
Oct 23, 2017 | Washing Machines
Hoover elite 1206 washer keeps filling and wont stop
There is clear plastic hose that gos from the outside of the washer drum to a pressure switch inside the control area, this hose has probably come off and needs to be pushed back on.
May 06, 2011 | Hoover Washing Machines
My Hoover Elite 1210 toploading washing machine seems to make a horrible off balance sound on the spin cycle - even when there is a small load on. What can I do to fix it?
Could be bearings or more likely the concrete weight at the bottom of the drum is loos give it a shake from under to check...Good luck
Feb 09, 2011 | Hoover Washing Machines
Very noisy Hoover VHD9143ZD washing machine - just 2 years old
yes bearing housing get loose in plastic drum. needs drum replacement.
Oct 29, 2009 | Candy Washing Machines
Bra wire's trapped between inner and outer drum,
If you cant pull wire out from inner drum with long nose pliers, Remove heating element and use torch to inspect bottom of washer. Most of the time the obstruction makes its way to the bottom. Use whatever tool necessary to remove spring.
Sep 25, 2009 | Hoover AAA160 Front Load Washer
Loud noise on fast spin
The drum must be removed to get at it.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
May 30, 2009 | Kenmore Elite 45986 Front Load Washer
Hoover Elite 1205 washing machine
Does an Hoover elite 920 gearbox fit the hoover elite 1205 thanks
Sep 18, 2007 | Washing Machines
Washing Machines Logo
415 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
Marvin
Marvin
