Question about Panasonic Toughbook-19 Tablet PC
How do you run a battery recalibration
This was suggested the computer won't hold a charge
  • Panasonic Master
  • 32,281 Answers
If the laptop battery is more than 3 - 4 years old then the battery could be worn out. Rechargeable batteries have a finite number of charge and discharge cycles and will lose their charge capacity over time, i.e. won't charge to 100% and gradually the charge reduces until the battery won't charge up at all.
OR The battery shows a 100% charge but when the adapter is disconnected the battery drops off to zero capacity in a very short time.
If the battery drops to an unacceptable charge level then the battery needs to be replaced
Posted on May 26, 2010
SOURCE:
Won't take a charge.
Armend, Could be a bad charging port. Press and hold on button for 15-20 seconds a couple times to see if it will reset and power up before trying anything else. Check the attached links, videos,instruction and guides on kindle charging problems. Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Kindle Fire Won Charge Fix
12 major Kindle Fire problems and how to fix them
Reset Kindle Fire When it Won Turn on or Charge
Apr 08, 2016 | Amazon Kindle Fire HD
Fully charged. Why doesn't it turn on?
Ruby, try pressing and holding on button or you will have to reset.
My kindle won turn on
My kindle won turn on Is it the battery Kindle Fire HD
Amazon Kindle Won Charge Quick Fixes
Mar 12, 2016 | Amazon Kindle Fire HD
Mycharger on my samsung table 10.1 tab 2 won charge please help
The problem might be that your battery is too old. Rechargeable batteries have a limited number of charges that it can undergo.. usually between 300 and 500, before it starts to not hold much power anymore.. If it's not the battery,
I suggest you test the charger.
if you have a multimeter/voltmeter, unplug the charger from the wall socket and tablet. Set multimeter to measure Resistance/Ohms.. Touch one end of your meter cable to one of the charger pins(that you would otherwise stick into the wall socket) & the other end to the end you otherwise stick into the tablet.. all you're looking for is 'some' measurement... if you get a reading, test the other pin (wall socket end of the charger) .. if you get a reading again, then your charger should be fine.
Next look at your tablet, where you stick the charger into.. does anything seem loose/out of place? if no.. call the shop you bought it from an ask for assistance over the phone (typically shops offer advice freely over the phone)
Nov 12, 2014 | Tablets & eReaders
Kurio 7 won't hold charge. When pluged into charge it feels like it is seizing up and vibrates.
Don't most electrical/electronic equipment have a 12 month warranty at lest, Batteries 6 months, well here in Aus it's how I am aware it is. Anyway if you can and have warranty take it back, that's all I can suggest.
May 15, 2013 | Techno Source Kurio Kids Tablet With...
My textbook 7p won't turn on
This tablet does t reset with the power button unlike other Android devices. When you hold down the on/off switch, it only drains the battery. If you see the color indicator still charging, allow a full charge.Then, only stay put and pulse the button for a moment quick and let it rest few seconds to try again and again. Only when u see a light coming out of the screen, and I recommend you do this with the power cord on, you hold the power switch down until the rebooting is iniciated. Let go til it is finish and see where the problem is. More likely, like mine, the Settings stop working and needs tune up for the CPU. Never leave an application running when closing your system. With or without internet connection.
Apr 20, 2013 | Tablets & eReaders
Galaxy Samsung tab 10.1 won't turn on
you had to plug it in the charger for a while and then you hel the power button for more than a minute
if it not work hold power button and volume up for 20 sec.
Mar 22, 2013 | Tablets & eReaders
Motion Computing LE1600 Tablet PC won't charge.
know of similar problems. either the cable and connection end you have or the receiving end in the tablet. can be diagnosed by getting replacement charging cable. if the problem goes away then its the cable if not it is probably the receiving end in the tablet
Apr 05, 2012 | Motion Computing LE1600 Tablet PC
AC adapter/charger is attached, but the battery will not charge. it doesnt even show that the battery is there
Ifthe laptop battery is more than 3 - 4 years old then the battery could be wornout. Rechargeable batteries have a finite number of charge and discharge cyclesand will lose their charge capacity over time, i.e. won't charge to 100% andgradually the charge reduces until the battery won't charge up atall. ORThe battery shows a 100% charge but when the adapter is disconnected thebattery drops off to zero capacity in a very short time. Ifthe battery drops to an unacceptable charge level then the battery needs to bereplaced.
Jun 21, 2011 | Toshiba Portege M200-S838 Tablet PC
Panasonic Toughbook-19 Tablet PC Logo
685 people viewed this question
Top Panasonic Tablets & eReaders Experts
Steve Allison
Steve Allison
Mike
Tom Chichester
Are you a Panasonic Tablet and eReader Expert? Answer questions, earn points and help others
