Question about HP LaserJet M1522nf Multifunction Printer (CC372A)
10.1000 Supply Memory error. How can I fix that?
  • hadad May 15, 2017
    hi. you have to change cheap in the cartridge! good loock
  • naresh mishra
    naresh mishra Apr 30, 2018
    yes
    New Friend:
  • 29 Answers
Sounds like might be your toner, specifically your black toner.
is this a non-standard toner or HP? IF it your toner you can try this:
Place a stip of opaqe tape or paper or the chip. When the printer detects a non-standard cartridge press the green (go) button. It will then reset the LCD to Ready.
Found this info on a recycled manufacturer site. http://www.infinityimaging.com/cgi-local/SoftCart.exe/online-store/scstore/p-2300.html?E+scstore
otherwise it's probably the memory on the printer, try removing or replacing a DIMM
Posted on Jun 09, 2010
I am changd 88a toner cartidge to hp mfp m128fw
Posted on Apr 30, 2018
  • 776 Answers
Please find below the description and solution given by HP:
Alert and warning message tables Alert and warning messages Control panel message Description Recommended action 10.0000 Supply Memory Error A specific print cartridge has an e-label error. Reinstall the print cartridge.
Turn off and then turn on the product.
If the problem is not solved, replace the cartridge. 10.1000 Supply Memory Error A specific print cartridge has a missing e-label. Reinstall the print cartridge.
http://h20000.www2.hp.com/bizsupport/TechSupport/Document.jsp?lang=en&cc=us&objectID=c01312064
4 Suggested Answers
6ya staff
SOURCE:
guilopmar
  • 304 Answers
SOURCE: what is 10,1000 supply memory
A specific print cartridge has a missing elabel.
Posted on Jul 21, 2011
seeker5211
Seeker5211
  • 1089 Answers
SOURCE: Printer is displaying the following
There is a chip on the toner cartridge that feeds info to the printer regarding the status of the cartridge. Either the chip is bad or the cartridge was replaced with the chip missing.. Try reseating the cartridge and then power cycle the printer. If the error persists, replace the cartridge
Posted on Sep 23, 2011
Ashraf
  • 38 Answers
SOURCE: I am getting error: 10,1000 supply memory error reinstall
You are using re manufactured toner and it has a bad chip. Replace the toner.
Posted on Jul 12, 2010
Supply memory error
Remove cartridge, observe a small chip mounted on cartridge shell..This chip calculates the approximate toner levels, once its reached "Zero" printer says cartridge empty/low replace it.. If the memory is not detected due to any reason printer will say supply error or 10:xx supply error..
Replace this memory if available( locally its available ) or replace the cartridge.. Very few cases same error appears with faulty DC controller..
Ex supply memory:
Oct 28, 2013 | HP LaserJet P2055d Printer
Need a error list for a Canon IR 600 imagerunner
E000 fixing overheating
E001 fixing assembly overheating
E002 fixing assembly low temperature
E003 post-standby fixing low temperature
E007 fixing film rotation error
E010 main motor rotation error
E014 fixing motor rotation error
E019 waste toner case full, waste toner case full sensor error
E020 toner clogging between sub hopper and developing assembly
E024 developing assembly connector disconnection
E025 hopper motor, bottle motor error
E032 NE controller counter error
E064 power supply voltage error (high-voltage)
E100 BD interval error
E110 scanner motor error
E191 communication error for high voltage power supply
E202 CIS home position detection error
E225 CIS light intensity error
E227 reader unit power supply error
E248 backup memory error
E261 zero-cross signal error
E315 image data error
E400 feeder communication error
E490 wrong DF type
E500 finisher communication error
E503 finisher internal communication error
E505 finisher backup memory error
E514 stack delivery/trailing edge assist motor error
E519 gear change motor error
E520 off-set motor error
E530 rear alignment error
E531 stapling error
E532 stapler shift error
E535 swing error
E537 front alignment error
E540 stack tray ascent error/upper tray ascent error
E542 lower tray ascent error
E577 paddle error
E584 shutter error
E590 punching error
E591 puncher dust sensor error
E592 punch horizontal registration sensor error
E593 punch shift error
E5F0 saddle paper positioning error
E5F1 saddle paper folding error
E5F2 saddle guide error
E5F3 saddle alignment error
E5F4 saddle rear stapling error
E5F5 saddle front stapling error
E5F6 saddle butting error
E5F8 saddle connector error
E5F9 saddle switch error
E602 hard disk error
E604 image memory error/shortage
E609 hard disk error
E610 herd disk coding key fault
E674 fax board communication error
E710 IPC initialization error
E711 IPC communication error
E716 communication error for pedestal/ communication error for 3-way unitA1
E717 communication error for NE controller
E719 coin vendor error
E730 PDL software error
E732 scanner communication error
E733 printer communication error
E740 Ether board error
E743 DDI communication error
E744 language file/boot ROM error
E745 TokenRing board error
E746 accessories board wrong model error
E748 controller board and SDRAM size mismatch
E805 fan error
Aug 07, 2013 | Canon imageRUNNER 600 Printer
000110-0001
Code Error name/description
Jul 15, 2013 | Canon Office Equipment & Supplies
What is 10,1000 supply memory error with hp
Jul 21, 2011 | HP LaserJet M1522nf Multifunction Printer...
How to fix a problem 10.10/01 Supply Memory error I turned off the computer and it still continues
The error 10.10.01 is telling you that the cyan toner cartridge is missing the cartridge memory tag.
Replace the cyan toner.
Feb 25, 2011 | HP Color LaserJet 3500 Printer
My printer shows 10.1000 supply memory error
This might be a non-HP toner (although i doubt it) since the error indicates that the supply memory chip was not found at all.The chip might also be deffected.
This are the steps offered by the service manual:
1. Open and close the front door.
2. Ensure the cartridges are fully seated.
3. Swap the cartridge for the color
indicated with a cartridge in another
slot to determine whether the error
follows the cartridge or stays with the
slot. If the error follows the cartridge,
replace that cartridge, otherwise,
continue with step 4.
4. Check the memory controller PCB
contacts to the memory tag. Clean if
dirty.
5. Reseat the memory controller PCB
connector J201 and DC controller PCB
connector J1025.
6. Defective memory controller PCB,
replace the memory controller PCB.
7. Defective DC controller PCB, replace
the DC controller PCB
Good luck,im sure that replacing the toner will solve it.
Jan 22, 2011 | Office Equipment & Supplies
Jul 06, 2010 | HP Laserjet CM2320nf All-In-One Color...
Canon ir 3530
E490 wrong DF type
E531 stapling error
E535 swing error
E577 paddle error
E584 shutter error
E590 punching error
E805 fan error
Feb 21, 2010 | Canon ImageRUNNER 3570 Copier/Printer
HP 4200 10.0000 supply memory error
It appears that the printer is having problems reading the e-label on the print cartridge. Remove and reinstall the print cartridge, then press the Select button. That should clear the problem.
Apr 07, 2009 | HP Hewlett Packard LaserJet 3000dn Printer
HP LaserJet M1522nf Multifunction Printer (CC372A) Logo
23,840 people viewed this question
Clive
Clive
Ekse
Thomas F. Schneider
