Question about Panasonic Lumix DMC-ZS3 Digital Camera
Upon trying to turn camera Panasonic DMC-ZS3 on, error message appears: system error (zoom). The lens comes out a bit and then goes back in, shutter closes, then lens comes out a bit again, then goes back in again ... then error message. Can you help? Thanks!
    Scholar:
  • 66 Answers
I don't know that I can help you fix it, but I can try. Here are my thoughts... Check the battery first. If it's like a normal battery, like AA or AAA batteries, replace them and try turning it on.
If it's a flat lithium battery that you recharge using a power cord that plugs into the camera, you might want to buy a new one. Charge it fully over night and try powering the camera up in the morning.
You never mentioned what the error message was! So I can't help you there.
Next, you might try connecting the camera to your computer and see if it comes up. Also, check with Panasonic and see if there's a way to reset your camera. Maybe there's a way to do a software reset. Also check to see that there isn't a downloadable software upgrade or patch available. Lastly, you may want to consider Panasonic customer support/technical support, they may be able to better help you diagnose the issue with your camera.
I have a Lumix too. I have an DMC LZ10, my daughter has a DMC TZ3. They're similar in many ways, and yet they're different in many too. Mine uses AA batteries, hers uses a flat lithium rechargeable that uses a power cord. The internal software is pretty much the same (sort of). Enough so that I can work the settings on hers without having to reference the manual.
As a computer tech, my first impressions are that you're having either power issues, or software issues. Eliminate the variables. Start with power and work your way out from there. If it behaves the same with any battery, you've eliminated the power issue. Now it's software. Simple enough?
Posted on Aug 03, 2010
6ya staff
SOURCE:
Zoom problem with ZS-3
It's eight years old now - just replace it.
Jun 22, 2017 | Panasonic Lumix DMC-ZS3 Digital Camera
My Panasonic TZ25 says "System Error - Focus". What should I do?
Panasonic DMC TZ25 compact camera - System Error (Focus)
- Try holding the shutter button while switching on the camera (suggested by Andrea Lock, above). I actually had to try this several times as camera was refusing to reset properly, but after a few goes, lens retracted and camera began to work again. Thanks Andrea.
Feb 21, 2013 | Panasonic Lumix DMC-TZ25 Digital Camera...
My panasonic Lumix camera DMC-ZS3 dropped and the zoom stopped working. Lens will go out only a drop, not enough to take pictures, and it says: "system error: zoom." Playback only is OK. Is this...
there is not a big problem if the lens are coming out but not enough..the mechanism is blocked i think will cost about 25$ or something like that
Oct 06, 2010 | Panasonic Cameras
My TZ7 says that it has a system error (focus) and will not take pictures, view pictures or menu and the shutter will not close when turned off. Help!
Here's a fix I got from Panasonic, I figured I would post this since I haven't seen this anywhere on the web and this post was the highest hit on google
Based on the information that you have provided, we suggest that you perform the following operation:
1. Turn off the camera 2. While off, turn the zoom button fully to the left or right (hold for about 3-5 secs) 3. Release then turn the camera back on... At this point in time the lens should retract. If it does not, repeat the previous steps however, press the zoom to the opposite direction than you did the first time around. If this does not resolve the issue, we recommend the product be sent to our Customer Service Center.
This seems to work for me. The lens retracted back in place and my camera resumed working.
Aug 28, 2010 | Panasonic Lumix DMC-ZS3 Digital Camera
When i turn on my panasonic lumix dmc fz28 it shows system error
HI there the camera lens guide pin is damages and thats why not zoom the image properly . You got the system error message. So you need to replaced or repair the lens guide pin. Thanks.
Apr 01, 2010 | Panasonic Lumix DMC-FZ28 Digital Camera
Please Turn camera off and then on again
This message usually appears when force has been applied to the lens.
Sep 12, 2009 | Panasonic Lumix DMC-FS5 Digital Camera
Lens stuck
It sound like a problem with the zooming mechanism (lens would not retract or extended) Press the power button on and hold it down while extending and twisting the telescopic zoom lens. It might fix your problem. In any case it could not make it worse Good luck!
Aug 22, 2007 | Panasonic Lumix DMC-LC43 Digital Camera
Panasonic Lumix DMC-ZS3 Digital Camera Logo
660 people viewed this question
Top Panasonic Cameras Experts
Ekse
rajiv6089
Level 1 Expert
Are you a Panasonic Camera Expert? Answer questions, earn points and help others
