Question about LG Televison & Video
I have a 21inch TV (LG golden eye) which is 10 years old from and now i am facing a problem that when i switched on the tv the standby LED of the tv blinks for a few seconds and then automatically off. after 1 week or 10 days tv is working fine again and picture clarity also good for a few days and then again the same problem starting. could you please tell the reason?
    New Friend:
  • 49 Answers
This is line output transformer problems. Before changing LOT,watch any dry soldering is there and also check vertical output ic is good or bad ?by replacement methode.
NOTE- if you know the protection pin, isolate the pin and switch on tv through 200watts bulb seriesly.then watch the symptomes.
Thanking you
Posted on Aug 04, 2010
  • anji_i Apr 18, 2011
    what is the cost of LOT
  • srinivas rao V Oct 03, 2012
    chinese LOT will cost you Rs. 150 to Rs. 350
I have lg 25'' tv sound fo tv is good but it takes 5 minit after tv start
Posted on Apr 15, 2013
    New Friend:
I have a 21inch TV (LG golden eye) which is 10 years old and recently i am facing a problem that
1) Some times the colors in my lg tv got changed. Only a small portion in the top right side of the screen has the true colors. The color change is something like the one that happens when a magnet is taken near the screen. But nothing like that was near my tv.
2) usevally after power off to the tv for about one hour, if i switched on the tv, the standby LED of the tv blinks about 5 to10 minutes and the same time tv will not on & the remote also does not function.after blinking of LED is stoped ,now i can ON the tv by remote (or) by tv buttons. tv will be working fine . again if i switched OFF the tv for about one hour, same problem will be repeated.
resulting i have to wait about 10 minutes to switch on my TV which result incinvenient to me.
3) part of picture about 5% of image missing on the screen on left and right side of the TV.
could you please tell the reasons and suggest the solution for rectification of the above problemstell the reason?
Posted on Mar 21, 2011
    New Friend:
  • 3 Answers
SOURCE:
Element tv model ELEFW601 has a bright red standby light till i hit the power button,at first it would come on but now it flickers and wont turn on
Possibly a fault in the TV, causing safety circuit to kick in.
My LG Golden Eye CRT did the same.
Turned out that an HT tube component (Flyback) had failed.
Jul 15, 2018 | Element Televison & Video
I have LG golden eye pride tv . its around 17 years old and the real problem is that it has started blinking. could you please suggest possibly what could be done
Power supply is probably going out, it will be more expensive to replace than tv is worth. Sorry, look on a local craigslist for a tv bargain locally.
Jan 11, 2018 | LG Televison & Video
Lg led tv has sound but no picture
suspect either a back light power board issue or main power board to back light board issue...also, is it under warranty ?
Dec 28, 2013 | LG Electronics 47LS4600 47" LED HDTV
Lg golden eye 21inch ctv stand by led glows but switchin progress key only clicking sound found,set unable to on
Shorted component/s in the main circuit board's horizontal output section. Check and replace the damaged components there.
Jan 05, 2013 | LG Televison & Video
In my Lg Golden Eye 21" television remote control
Which type of remote control can I use for golden eye TV
Aug 12, 2011 | LG Televison & Video
I have an LG Golden eye tv which was bought 10 years back, now the video is suddenly going off and the screen is black at which time the remote control also does not function, but the audio will remain...
The device called LOT (Line out Transformer) inside the TV has gone weak. Call a TV service engineer and he should be able to repalce the LOT to fix the issue. Also ask him to give a report on the life quality of the picture tube.
Mar 05, 2011 | Televison & Video
Dear Sir, LG Golden Eye Marquis Model No: RF-29CA40PQ., i forgot the 4 digit Tuning Lock Code. Due to this i am not able to Tune my TV. Can any one help me out, is there any master Tuning Lock 4 digit...
In my LG golden eye marquis 32 inch TV, I have switch on the childhood protection mode to prevent the TV from children's by pressing the buttons on my TV.... Now The remote gets broken which was given along with the TV.. Now I bought a remote for tat model that name is LRIPL... I can't able to access the menu button and most of the buttons cannot able to process... I need to access all the buttons... Please help me..
Feb 24, 2011 | Televison & Video
Televison & Video Logo
1,438 people viewed this question
RONALD CARTER JR
