Question about Nokia 3110 Cellular Phone
Automatic Switch off
When I switch off the phone and again restart it, it restores momentarily and gets switched off automatically after 4-5 seconds. This is a recurring problem.
  • 6 more comments
  • manjul145 May 10, 2008
    my nokia 3110 gets automatically restarted again and again
  • Anonymous May 11, 2008
    ITs a great phone but it looks cheap with problems like these. When I trun it off it restarts and this process continues until the phone automatically gets switched off!
  • Aditya Narayan
    Aditya Narayan May 11, 2008
  • anilthakur04 Jun 24, 2008
    my cell phone gets restarted when i put memorycard
  • ivana_g_bt Jul 14, 2008
    When I switch off the phone and again restart it, it restores momentarily and gets switched off automatically after 4-5 seconds. This is a recurring problem. PLS HELP!!!!!!! as soon as you can, i need the problem to be resolve in 24h. thx anyway
    P.S. it only dose that when my memory card is in it. HHEEEEEEEEEEPL i need it fast
  • chauhan56don Jul 16, 2008
    i have the same problem
    so please give me some solution
  • Anonymous Jan 06, 2009
    l'k
  • rajcellcompr Nov 22, 2009
    nokia3110c automatic off
I have a mobile of nokia 3110. i found a problem in it that it suddenly restarted again and again ?is it any virus problem or any thing else? if yes where i found its anti virus plese suggest
Posted on Jun 25, 2008
    Sergeant:
    Champion:
  • 230 Answers
This problem can be overcome by formatting ur memory card by ur phone itself or by using card reader in personal computer..............and also dont add too many themes and dont change d themes often
Posted on May 11, 2008
How Can i remove a virus on it?
Posted on Jul 19, 2008
  • 2 more comments
  • Jeffrey mondia Jul 19, 2008
    I have the same problem HHHHEEEEEEEEEELLLLLLLPPPPPPPPPP!!!!!!!!!!!!!!!!!!
    Can i Format it in the computer by connecting with a USB?
    Can i format it by Connecting my 3110c in a Personal computer with a USB cable?
    Where can i find an anti-virus for 3110c?
    New Friend:
Flash ur mobile use desire latest firmware
Posted on Nov 27, 2011
    New Friend:
Nokia 3110c off on 3 min
Posted on Feb 13, 2011
SOURCE:
Unlock Child lock on nissan if the lock is on and dont open from outside
All doors lock automatically when the vehicle speed reaches 15 MPH (24 km/h).
? All doors unlock automatically when the ignition is placed in the OFF position.
The automatic unlock function can be deactivated or activated. To deactivate or activate the automatic door unlock system, perform the following procedure: 1. Close all doors.
2. Place the ignition switch in the ON position.
Within 20 seconds of performing Step 2, push and hold the power door lock switch to the position (UNLOCK) for more
than 5 seconds.
4. When activated, the hazard indicator will flash twice. When deactivated, the hazard indicator will flash once.
5. The ignition switch must be placed in the OFF and ON position again between each setting change.
When the automatic door unlock system is deactivated, the doors do not unlock when the ignition switch is placed in the OFF position. To unlock the door manually, use the inside lock knob or the power door lock switch (driver's or front passenger's side).
NOTE:
The automatic door unlock function can be changed using the Vehicle Settings in the vehicle information
Sep 30, 2016 | Nissan Pathfinder Cars & Trucks
Generator will not stay running
The toggle switch automatically resets all faults when it is turned to the off position. I would turn the toggle switch off, turn off the breaker on the generator and then turn off all the loads in the house except a few lights. Turn the generator breaker back on, then turn the toggle switch back to automatic. If it starts and stays running, you were overloading the generator. Turn on other loads slowly and keep track of what is on so you don't overload it again. If it still does not stay on, you may have a problem with the panel. Let me know what happens.
Nov 20, 2013 | Briggs & Stratton 15,000 Watt Home Standby...
How do I adjust squelch. Squelch is locked on
I suspect you have it in the continuous monitor mode so follow the directions for getting back into the automatic squelch mode.
AUTOMATIC SQUELCH: The FRS is equipped with an automatic squelch circuitry filtering out weak transmission and unwanted noise, usually caused by terrain conditions.
MONITOR:
- This feature turns off the automatic squelch feature, either momentarily or continuously. It helps in receiving signals to its maximum range, but may pick up static signals, too.
Momentary monitor:
- Press the MON button; the monitor symbol will appear.
- Release the button to restore the automatic squelch.
Continuous monitor:
- Press the MON button for more than 2 seconds until a beep sound is heard. The monitor symbol will appear.
- To restore the automatic squelch, press and release the MON button again.
NOTE: You cannot transmit when the Monitor feature is activated.
This comes from the manual I found on-line at:
http://www.michaelknows.com/electronics/walkie-talkie-manual/
Oct 26, 2013 | BellSouth 1011 (14 Channels) 2-Way Radio
Ma cellphone automatically switch-off when i do configuration setting
Restore factory setting is the first aid.Go to "setting" select "Restore factory" choose "Restore Only" and enter 12345 or what you done.Phone will restart automatically.Im not sure but somtimes working.Thanks visit again.
Jul 12, 2011 | Nokia 2730 Cell Phone
Automatic switch off while selecting ring tone settings,
SOLUTION FOR YOU
1. Click on Menu 2. Go to Settings> Restore Factory Setting 3. Enter the code (Default code is 12345) if changed enter the changed code. 4. Press OK to restore all the settings. 5. The phone will restart, and now the problem will be solved.
Hope this Helps.
May 19, 2011 | Nokia 1650 Cell Phone
After few seconds phone automatic gets switch off
Switch off or restart? Please check your IMEI number. Enter *#06# from standby screen
Dec 28, 2010 | Nokia 3110 Cellular Phone
I have a problem with switching my nokia 3110 classic answer pls!
The Problem with Nokia 3110c – Switching off and automatically restarting This is what happens. Nokia 3110 hangs, gets switched off and restarts randomly. More often, it restarts around 3 times or so and then gets switched off.
Possible Causes and Solutions Cause 1 – Phone Memory Full – Nokia 3110c mobile phone has got 9MB of internal memory.
Solution – Keep the free space between 350 to 500 KB, so as to keep things running smoothly on your phone and prevent Nokia 3110c from restarting.
Cause 2 – Changing Themes – Some people have reported that the phone restarts automatically when they try changing display themes on the phone.
Solution – Don’t get your phone loaded with too many themes downloaded from the internet or atleast, don’t switch themes frequently. These themes, mind you, also load up things into your already falling Nokia 3110c phone memory.
Cause 3 – Memory Cards – Some people have reported that Nokia 3110c restarts due to some issues with the memory card.
Solution – Remove the card, get it formatted and then insert it back and then restore factory settings. This just might solve the issue.
Cause 4 – Transferring data via Blueooth / USB data cable (or) Updating Music Library – A few people have reported that their Nokia 3110c mobile phone restarts when updating the music library.
Solution – Don’t try updating of music library frequently or don’t often transfer data in/out of your Nokia 3110c phone.
Cause 5 – MP3 files
Solution – This may seem dumb, but consider converting all your MP3 music files to WMA and then store them on the memory card. Some users suggested this.
Also try this:-----
It ll work . you dont need to go 4 the firmware v5.05
If ur phone restarted 3 or 4 times and switched off automatically. Try this
method
1] Remove the battery and Micro SD card
2] wait about 5 minutes
3] Then switch On the phone WITHOUT the memory card
Now ur phone working well without restarting
4] Then you must restore Factory settings frm the Settings Menu
[default security code:12345]
{i know most of people have done this thing,but remember u have 2 go
with the correct order.Unless it will not work.OK}
5] Now apply a theme. The theme's size should be below 100kb
6] Now ur phone working fine without the Micro SD
7] Then wait about 5 minutes and Switch off ur phone
8] Remove the battery and insert the Micro SD
{Don t Format the memory card}
9] Switch On ur Nokia 3110c phone.
10] Now Keep ur free Phone memory space [Not the memory card's free space]
between 470kb - 499kb.
Now surely ur 3110c working fine about 5
months.During these time u can
1] Send/receive any file via bluetooth.
2] Enjoy Music,video, GPRS,Yahoo Go .....etc
3] Also u can Update music library anytime.
but remember below DONTs
1] Don t try to change themes.{u have to stick with a theme}
2] Charge ur phone in ON mode
3] Dont fully discharge the battery
4] Start charging ur phone when there is only a bar on Battery indicator
5] Dont erase calender notes
Make sure about above 5 Donts
Dont worry if ur phone restarted once.{U know the problem is restarting several times
and automatically swiched off.}
After 4 or 5 month there is a possibility to occur the problem again.
if so Follow the above steps again.
Good luck
To be frank, This mobile has this as a generic problem. As I told, The problem can come back again.
Thank you Sir, Have a nice day.
Sep 21, 2009 | Nokia 3110 Cellular Phone
Automatic restarting problem with Nokia 3110c mobile phone
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} This is what happens. Nokia 3110 hangs, gets switched off and restarts randomly. More often, it restarts around 3 times or so and then gets switched off.
Possible Causes and Solutions Cause 1 - Phone Memory Full - Nokia 3110c mobile phone has got 9MB of internal memory.
Solution - Keep the free space between 350 to 500 KB, so as to keep things running smoothly on your phone and prevent Nokia 3110c from restarting.
Cause 2 - Changing Themes - Some people have reported that the phone restarts automatically when they try changing display themes on the phone.
Solution - Don’t get your phone loaded with too many themes downloaded from the internet or atleast, don’t switch themes frequently. These themes, mind you, also load up things into your already falling Nokia 3110c phone memory.
Cause 3 - Memory Cards - Some people have reported that Nokia 3110c restarts due to some issues with the memory card.
Solution - Remove the card, get it formatted and then insert it back and then restore factory settings. This just might solve the issue.
Cause 4 - Transferring data via Blueooth / USB data cable (or) Updating Music Library - A few people have reported that their Nokia 3110c mobile phone restarts when updating the music library.
Solution - Don’t try updating of music library frequently or don’t often transfer data in/out of your Nokia 3110c phone.
Cause 5 - MP3 files
Solution - This may seem dumb, but consider converting all your MP3 music files to WMA and then store them on the memory card. Some users suggested this.
Feb 12, 2009 | Nokia 3110 Cellular Phone
Automatic switch off my sigmatel s3 mobile
automatic switch off mobile & it lost its phone data(my msg.)date and time
;my mobile setting will change
please send us solution for this
my email id chetanthorbole16@yahoo.co.in .
Thanks
chetan
Sep 30, 2008 | Handmark Software MobileLists (950142) for...
battery problem then u check ur mobile to service center is best
Sep 08, 2008 | Sony Ericsson Z550i Cellular Phone
Nokia 3110 Cellular Phone Logo
321 people viewed this question
Top Nokia Cell Phones Experts
jonathan mariano
jonathan mariano
ASHRAF CA
ASHRAF CA
