I need a User Manual, for a Samsung CLP-550 - Office Equipment & Supplies
    Scholar:
  • 92 Answers
you can find you user manual on the link below: Samsung CLP-550 User Manual
Posted on Sep 07, 2010
Testimonial: "Thank you, for your help"
SOURCE:
Transfer belt
Try to take out transfer belt and reinstall. You might have to tell the machine that a new transfer belt has been installed.
I’m happy to help further over the phone at https://www.6ya.com/expert/eric_7148ad2a373711a3
Sep 09, 2013 | Samsung Image Transfer Belt...
Waste Toner Error Message For Samsung CLP 550
Dr. P,
Printer will display "Waste Toner Tank Full/Not Installed" error message if the waste tank is full of toner or not installed.
  • Open the waste tank door and check for the waste toner tank.
  • If the tank is full or not intalled, install a new tank.
If you have user guide, it will show you how to install the waste toner tank.
Sometimes you will also get this error message if the Waste Toner sensor is covered with toner powders.
  1. Remove your waste tank and look for the black plastic on the right side after removing the waste tank.
  2. You sould find small openings on each side in the black casing.
  3. Use Q-tips or thin cotton object to clean the inside the small opening.
for user manual just click here:
If this solution works, please don't forget to rate it fixya
For any more question just ask me.
Thanks
Iqbal
Apr 14, 2008 | Samsung CLP-550 Laser Printer
Waste toner tank full not installed
Behind the waste toner bottle near the top, there's a lever that uncovers a sensor that shines thru the bottle. You can blow out that area with canned air but usually the sensor needs to be replaced.
Feb 17, 2010 | Samsung CLP-550 Laser Printer
I would like to know where can I find a manual that clearly states how to change and refill the toner in the Samsung CLP 610n
User manual and quick guide available here
http://www.samsung.com/uk/support/search/supportSearchModelResult.do?menu=SP08&searchWord=CLP610n&searchInputBox=CLP+610n&find_button=
Dec 21, 2009 | Samsung CLP-600N Laser Printer
Samsung laser printer clp-550
When I this error on any printer my first question is 'Has somebody pulled on some stuck paper and torn it?' If people are honest and say 'yes' then there may be tiny piece of paper covering a sensor. Pull out the toner(s), fusers and paper tray(s) and look closely for any scraps of paper. They may be jammed in the parts that you just removed. If you have another of the eact same model you could simply swap parts to check none of them are faulty. Lastly, it may be worth buying a can of air and blowing it through the printer in case there is paper dust covering any sensors. Failing these, get the printer servied.
Please rate me if any of this helped J
Dec 12, 2009 | Samsung CLP-550 Laser Printer
CLP-550 Jam Inside Printer
Unplug the printer.
Uninstall all of your printer software. Reinstall it as if it where a new printer. Under printers select your model as the default printer.
Print a test page.
Aug 28, 2009 | Samsung CLP-550 Laser Printer
Samsung CLP-310 too much red
Dear,
Use the smart panel utility from Samsung website or from the CD to adjust the color density.
Regards
Jan 29, 2009 | Samsung CLP-550 Laser Printer
Paper Jam in CLP-550
Normal 0 I suggest you get a sheet of Card Stock (Heavy paper) and place it in the feed way. Then press the print button applying a slight amount of pressure on the Card Stock so it will feed through the printer. The reason for this is in some cases I have been able to clear the paper track of debris that was deposited there over time.
Worth a try, as I have fixed a number of printers this way, saving costly repairs.
Hope this helps. Bud
Jan 02, 2009 | Samsung CLP-550 Laser Printer
Transfer Belt vs Transfer Roller
Dear Friends:
I have a same problem after replacing both transfer belt and drum for Samsung CLP-510.
Can you help me?
An
Aug 20, 2008 | Samsung CLP-550 Laser Printer
245 people viewed this question
jasbo
jasbo
Ekse
Marvin
Marvin
