Question about Mach Speed Trio Portable MP3 Player
Battery will not hold a charge for more than 20 minutes when fully charged
  • 5 more comments
  • Anonymous May 31, 2008
    I'm right there with ya'.
  • Anonymous Jun 11, 2008
    ME TOO!
  • chrissyc000 Jun 11, 2008
    Same thing with me!
  • Anonymous Jul 11, 2008
    I have the problem also
  • donaldm1305 Aug 03, 2008
    My Mach Speed Trio Clip indicates battery full but when you turn on the unit it goes into shut down as if there is no battery power. I have placed it on charge using two different computers and still have the same problem.
  • Anonymous Mar 07, 2009
    My daughter just got hers and she's listened to it twice. Now it won't hold a charge!
  • Anonymous Apr 11, 2009
    me too
I had the same problem and then went to the website to find that you have to have the off/on switch in ON position. This solved it for me. Hope it's that easy for you too!!!
Posted on Aug 19, 2009
SOURCE:
I bought a 2010 zone electric cart and I do not think the battery charger is working. It will show fully charged and will not last but about 20 minutes please any advise
First of all take your battery to a place that sells batteries and have it checked. Sounds like your battery is only partially charging but the charger will show fully charged as it won't charge any more. Battery could be bad.
Dec 26, 2014 | Golf
How do I charge the battery on a 1990 xlh sportster 1200
The voltmeter test provides general indicator of battery condition. Check the voltage of the battery to verify that it is in a 100 per cent fully charged condition. If the open circuit or disconnected voltage reading is below 12.6 V, charge the battery and then recheck the voltage after the battery has set for one to two hours. If the voltage reading is 12.8 V or above, perform the load test described below.
The load test measures battery performance under full current load and is the best indicator of battery condition. Load testing a battery tat is not FULLY CHARGED i.e. at 12.8 VDC can permanently damage it. Fully charge it first and then let it stand for at least an hour before the load test is done. You also need a load tester AND you should know how to perform a load test. Often the best way to load test a battery will be to take it to a battery shop and have it done there.
VOLTAGE and STATE OF CHARGE FOR AGM BATTERIES IS:
12.8 VDC is 100 per cent
12.6 VDC is 75 per cent
12.3 VDC is 50 per cent
12.0 VDC is 25 per cent
11.8 VDC is 0 per cent
COLD CRANKING AMPERAGE (CCA) for a DYNA battery is 270
Battery Charging Rates/Times (Approximate)
FOR A 19 AMP HOUR DYNA AGM BATTERY
BATTERY STATE OF CHARGE is 12.8 VDC is 100 per cent Charge; Rate of Charge is N/A
BATTERY STATE OF CHARGE is 12.6 VDC is 75 per cent Charge; Rate of Charge at 3 AMP is 1.75 hours at 6 AMP is 50 minutes at 10 AMP is 30 minutes at 20 AMP is 15 minutes
BATTERY STATE OF CHARGE is 12.3 VDC is 50 per cent Charge; Rate of Charge at 3 AMP is 3.5 hours at 6 AMP is 1.75 hours at 10 AMP is 1 hour at 20 AMP is 30 minutes
BATTERY STATE OF CHARGE is 12.0 VDC is 25 per cent Charge; Rate of Charge at 3 AMP is 5 hours at 6 AMP is 2.5 hours at 10 AMP is 1.5 hours at 20 AMP is 45 minutes
BATTERY STATE OF CHARGE is 11.8 VDC is 0 per cent Charge; Rate of Charge at 3 AMP is 6 hours, 40 minutes at 6 AMP is 3 hours, 20 minutes at 10 AMP is 2 hours at 20 AMP is 1 hour
The figures listed above assume that the battery is charging at room temperature. If warmer than room temperature, use a slightly shorter charging time. If colder, use a slightly longer charging time.
The use of constant current chargers to charge maintenance free batteries is not recommended. Any overcharge will cause dry out and premature battery failure. If a constant current charger is the only type available, do not exceed the charge times listed above and do not continue charging the battery if it gets hot. When charging, never exceed 15 volts for more than 30 minutes.
If the battery gets hotter than 110 degrees F or 43 degrees C during charging, discontinue charger and allow the battery to cool. Overheating may result in plate distortion, internal shorting, dry out and/or other damage.
Apr 22, 2014 | Harley Davidson XL 1200 S Sportster Sport...
Dead battery 1990 xlh sportster 1200
The voltmeter test provides a general indicatorof battery condition. Check the voltage of the battery to verify that it is in a 100% fully charged condition. If the open circuit (disconnected) voltage reading is below 12.6V, charge the battery and then recheck the voltage after the battery has set for one to two hours. If the voltage reading is 12.8V or above, perform the load test described below.
The load test measures battery performance under full current load and is the best indicator of battery condition. Load testing a battery tat is not FULLY CHARGED i.e. at 12.8 VDC can permanently damage it. Fully charge it first and then let it stand for at least an hour before the load test is done. You also need a load tester. AND you should know how to perform a load test. Often the best way to load test a battery will be to take it to a battery shop and have it done there.
VOLTAGE (OCV) STATE OF CHARGE FOR AGM BATTERIES IS:
12.8 VDC = 100%
12.6 VDC = 75%
12.3 VDC = 50%
12.0 VDC = 25%
11.8 VDC = 0%
19 AMP HOUR BATTERY =
BATTERY STATE OF CHARGE = 12.8 VDC = 100% Charge; Rate of Charge = N/A
BATTERY STATE OF CHARGE = 12.6 VDC = 75% Charge; Rate of Charge @ 3 AMP = 1.75 hours @ 6 AMP = 50 minutes @ 10 AMP = 30 minutes @ 20 AMP = 15 minutes
BATTERY STATE OF CHARGE = 12.3 VDC = 50% Charge; Rate of Charge @ 3 AMP = 3.5 hours @ 6 AMP = 1.75 hours @!10 AMP = 1 hour @ 20 AMP = 30 minutes
BATTERY STATE OF CHARGE = 12.0 VDC = 25% Charge; Rate of Charge @ 3 AMP = 5 hours @ 6 AMP = 2.5 hours @ 10 AMP = 1.5 hours @ 20 AMP = 45 minutes
BATTERY STATE OF CHARGE = 11.8 VDC = 0% Charge; Rate of Charge @ 3 AMP = 6 hours, 40 minutes @ 6 AMP = 3 hours, 20 minutes @ 10 AMP = 2 hours @ 20 AMP = 1 hour
The use of constant current chargers to charge maintenance-free batteries is not recommended. Any overcharge
will cause dry-out and premature battery failure. If a constant current charger is the only type available, do not exceed the charge times listed above and do not continue charging the battery if it gets hot. When charging, never exceed 15 volts for more than 30 minutes.
If the battery gets hotter than 110 degrees F. (43 degrees C) during charging, discontinue charger and allow the battery to cool. Overheating may result in plate distortion, internal shorting, dry out and/or other damage.
Chaging batter
12.8 VDC = 100%
12.6 VDC = 75%
12.3 VDC = 50%
12.0 VDC = 25%
11.8 VDC = 0%
COLD CRANKING AMPERAGE (CCA) for an XLH battery is 270
COLD CRANKING AMPERAGE (CCA) for a 2001 XLH battery is 270
Battery will not hold charge
you need a new battery. It is possible that the battery may be fried.
Aug 20, 2017 | Black & Decker Garden
I have new laptop how many hour battery charge first time
First Time Charging
  • The amount of time it takes for your battery to fully charge depends on many factors, like your battery type and operating system. Many newer laptops will charge in 15 to 20 minutes, while others can take a few hours.
    When you're charging your battery for the first time, charge it fully before using your laptop. You may have to go through a battery cycle a couple times before your battery begins performing at its maximum capability. To do this, charge your battery fully, let it discharge to about five percent, and then fully charge it again
  • Read more: For How Long Should One Charge a New Laptop Battery? ' eHow.com http://www.ehow.com/way_5261076_long-charge-new-laptop-battery.html#ixzz1GTAFQEz9
    Mar 13, 2011 | Acer Computers & Internet
    The car is not holdong a charge. I replaced the Battery about a year ago. Today I replaced the alternator. I used jumper cables it ran for about 20 minutes and then died again. All the wires look good. Any...
    FIRST, YOU MAKE SURE THE BATTERY IS FULLY CHARGED.. A GOOD BATTERY WILL GO FOR 12 HOURS EVEN IF THE ALTERNATOR IS NOT WORKING.. SECOND YOU TURN THE CAR ON.. ONCE THE CAR IS ON. YOU DISCONECT THE BATTERY,, IF THE ALTERNATOR IS GOOD , THE CAR SHOULD REMAIN ON WITHOUT A BATTERY.. IF IT SHUTS DOWN , YOU HAVE A BAD ALTERNATOR OR THE WIRING IS WRONG ONE OF THE TWO.. SHORTS ON YOUR WIRING CAN CAUSE THE BATTERY TO LOOSE POWER.. BUT NOT THAT FAST. BECAUSE IF THE SHORT WAS TO SERIOUS.. YOUR WIRING WOULD BE BURNED.. COMPLETELY..
    IF THE ALTERNATOR IS OKAY,, REPLACE YOUR BATTERY,, MOST OF THE TIME BATTERIES GO BAD EASY WITH ANY LITTLE PROBLEM THE CELLS BURNOUT AND THEY DONT HOLD A CHARGE EVEN IF FULLY CHARGED THEY WILL LOOSE POWER IMMEDIATELY .. I THINK THAT IS YOUR PROBLEM.. SINCE IT ONLY LASTED LIKE 20 MINUTES.
    Dec 14, 2010 | 1996 Isuzu Rodeo
    After charging my MP3 player it appears fully charged but it will only play for about an hour and the battery runs down. i have recharged it again, same thing. now what?
    The very first time you charge your battery YOU MUST CHARGE IT FULLY!!! If you didn't, that is probably the problem.
    Also, even if you charge the player for just a couple of minutes it will APPEAR to have a fully charged battery when it actually doesn't.
    Most portable media devices require at least 20 minutes to an hour to fully charge whether the screen shows that it is fully charged or not.
    Jun 30, 2010 | SanDisk Sansa e250 MP3 Player
    Battery charge question
    in this phone when the battery is fully charged the running battery indicators stop at full position. U must charge every phones battery a maximum of 2 hours b'coz charging more than it reduces battery life and if the battery is not fully charged in 2 hours u must charge it after 20 minutes again
    May 20, 2008 | Nokia 2610 Cellular Phone
    Won't start
    how old is the battery? if it's more than 2 or 3 years old, it may not hold a charge. swap a known good battery and see if it works.
    Dec 10, 2007 | Panasonic AG-DVC30 Mini DV Digital...
    Mach Speed Trio Portable MP3 Player Logo
    360 people viewed this question
    Top Mach Speed Audio Players & Recorders Experts
    Joseph Hoffmann
    Steven Wander
    Steven Wander
    Are you a Mach Speed Audio Player and Recorder Expert? Answer questions, earn points and help others
