Question about Panasonic DMP-BD60K Blu-ray/DVD Player
Can't seem to play all dvd disc's ..something about I can only play in region A...whatever that means. How can I update my blu ray player to be compatible to all regions or discs. Quite frustrating when renting dvd's and they don't work. Lots of wasted money for a piece of equipment that doesn't work half the time.
    Sergeant:
    Champion:
  • 387 Answers
Region A is only for the U.S.A disc's
you need the code to unlock all the regions
Posted on Oct 20, 2010
SOURCE:
Won't play blu ray after update
follow this guide and fix it. God bless you
Does not play disc
  1. No disc. - Load a disc into the tray.
  2. Disc has been loaded upside down. Place the disc with the label side up.
  3. Disc region code does not match region code of the player.
  4. Disc type is not the correct type to play.
  5. Disc is damaged or dirty. Clean the disc or try another.
  6. Moisture may be condensed inside the unit. Remove the disc and the leave the power on for one or two hours.
Nov 05, 2013 | Sony BDP-S3100 DVD/Blu-ray Player with...
I CANNOT PLAY REGION A DVDS ON MY 3D BLU/RAY PLAYER BDP- 7500 PHILIPS DVD BLU/RAY PLAYER COULD I PLEASE HAVE A SOFTWARE UPDATE OR SOME KIND OF CODE TO UNBLOCK THE PROBLEM OR DO I REQUIRE A MULTI REGION...
No disc in tray
Press Home
Scroll to settings
input code: 13893108520
The settings will pop up and you will see that the DVD region is now set to 0 (meaning region free).
I have checked the hack on a BDP8000 (region 2)and it sets the region to 0 (the 7th. digit from the left) alright, but it does not make the player region free as a message from the disc (MGM) comes and tell that the disc is not supposed to be played in this region. The region on the player can be changed to the region by changing the "x" in 138931x8520 to the actual region you want to play.
Try this out. The hack codec for blue ray are not yet published so it is not possible to make Blue Rays totally region free as of now.
Sep 27, 2011 | Philips Computers & Internet
My blu-ray player is only playing dvd instead of blu-rays i have updated my player but still not playing blu-rays disc at all
First confirm that the firmware update that you used is in fact for that very model.
Then check the region code for the discs in question.
Try the update again.
Sep 04, 2011 | Vizio VBR210 Blu-Ray Player
My blu-ray will not play some disc or differant movies how can i get it to play all movies
This could either be because your player needs a firmware update or the disc is region locked. Connect the player to the internet and do an update. If it's region locked you can use a code remover on your computer, but thatvdoesn't take the restriction off of the disc, just the digital copy on your computer.
Mar 06, 2011 | Toshiba BDX2000 Blu-Ray Player
How to play region A blu ray discs on region c Blu ray player. i have bought this player in India but would like to play BD discs got for USA, and the player does not plays such disc.
The Player will not play the Blu-ray discs other than Region C.
This is because all the Blu-ray/DVD Players are designed such way that it will play only the discs that are manufactured and sold in the same country where the Player is manufactured.
You can play the discs that are "Region ALL".
However, you may try copying the content of the Region A/B Blu-ray discs to a Computer then create a video Blu-ray disc to check whether you can play them in the BDPS370.
Jul 21, 2010 | Sony BDPS370 BluRay Player
Toshiba BDX2000
is there a multi region hack for the toshiba bd2000kb blue ray so i can play imported dvds and blue ray.
Apr 10, 2010 | Toshiba BDX2000 Blu-Ray Player
Sharp blu ray wont update
hello.what you need to do is.
go in the menu
there will be a option that says regions
change your region there.
May 11, 2009 | Sharp AQUOS Blu-ray Disc Player
Wrong Disc
Are you referring to a prerecorded commercially produced DVD?
Discs are Region Coded This means that you will not be able to watch DVDs intended for use in a different country, unless you have a multi region player. .
There are two video standard formats, NTSC which is mostly North America, and PAL which is the rest of the world. Some players will play both, others won't. Some DVD players allow you to select the format.
Feb 23, 2008 | Jwin JD-VD130 DVD Player
Hp dvd player
This problem can often be caused by the DVD player software thinking it is in a region different than your discs. (DVD discs are often encoded with 'region codes' meaning a disc purchased in Asia will not work in a player expecting to see North American discs)
What can happen is the player 'forgets' where it is, and your regioned discs won't play any longer (region free discs should continue to work as will audio CDs ....)
A power surge, random cosmic ray or similar flakiness can cause a player to 'forget' what region it was designed for ....
If that is what has happened you need to 'reset' the region code.
Altho I can diagnose this, I have NO CLUE as to how to do this with a hp DVD player. Anyone out there know how to reset the region codes for this (or generically for a DVD player?)
Thanks!! //cheapz
Nov 15, 2007 | Televison & Video
Panasonic DMP-BD60K Blu-ray/DVD Player Logo
219 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
