Question about Mitsubishi WD-Y57 57" Projection HDTV
We purchased thtv in 2007. 5 months later the buld needed replacement, still under warrenty. Two days ago the tv would not turn on. the green on light comes on, I can hear something winding on the back left side of the tv and then it shuts itself off. no picture and no sound.
  • Mitsubishi Master
  • 8,457 Answers
Replaced the bulb,again.This thing require replacing like every 1 1/2 or 2 years.If tv in used like 4 or 5 hours a daily.
Posted on Nov 17, 2010
SOURCE:
Riding mower problems. NO START
the filter isnt bacwards is it ,is the line crimped?
the line could be pinched between frame.does it have an electric feul pump thats something to look at also
Aug 04, 2012 | Husqvarna Lawn Tractor - 54in. Deck, 26...
I have a question regarding my Apex television set that I just purchased 4 months ago. The screen does not come on, there is only volume. I was advised that this TV is under warranty. Who do I need to...
Tries the place where u bought tv itself,tries get ur warrenty replacement from them for a replacement of a different tv.U look inside tv owner manual for 1-800... call Apex Corporation itself talk to their custumer service department find the close it repair center they have a contract with to do their repair work with.U come to them or make appoint they come to u.
Sep 01, 2011 | Apex Digital LD4088 LCD TV
My tv will lose volume for no reason while we are watching it. I try to press the volume button but nothing happens. I have to turn the tv completely off to regain volume. I have only had the tv for a...
This tv have intermittent Tuner signal board problems,this tv will develope alot more problems later for devices and for the incomming tv broadcasting signal cable attached to it.Take this back where u bought it,get a replacement.Don't take warrenty repairs,because intermittent problems will come and goes will be be there for weeks or months,until the problems is develope for good,than it can be fix.Get a tv replacement,a new tv replacement ok,don't take warrenty repair,when dealing with intermittent problems.
Dec 27, 2010 | Emerson LC320EM9 32 in. LCD HDTV
My touchpad in my toshiba computer is not working. i purchased my computer two months ago. what should i do
You are still in warrenty, go to Toshiba website and get to customer services. Also - as its under 3 months you could take it to where you purchased it from and they should sort it, dont let them tell you to go to the manufacturer as in the legal sense they have a duty to you as you purchased from them and it's been under 3 months.
DONT open it up or let any technician open it up while its in warrenty, that will void the warrenty.
Oct 29, 2010 | Computers & Internet
TV won't turn on after lamp was replaced
Check the switch on the lamp door. Listen for the color wheel to spin. if the door switch is bad the lamp wont come on, samething if the color wheel is bad.
Jun 16, 2009 | Hitachi 50V500 50 in. HD-Ready LCD...
14 month old Prima 36 inch lcd tv takes 2+ hours before on.
If you purchased the warrenty extra above the cost of the tv Sears will allow you to purchase another extended warrenty. Contact them and let them know your extended warrenty ran out and you would like to buy another. I would leave out the part about the tv being broken.
Dec 16, 2008 | Televison & Video
PURCHASED SAMSUNG TV 18 MONTHS AGO FROM COMMET, HAS STOPPED WORKING, REPAIR MAN CANT FINd PART strw6750f power supply chip anywhere, warrenty up 6 months ago, very dissapointed. CW-21Z403N
im afraid they stop making those parts you may find the parts in a tv repair shop from and old tv just look around will come across one sooner or later
Jul 18, 2008 | Samsung Televison & Video
Blinking Green Light on Mitsubishi DLP 52525
Replace the 1000uf capacitors on the DM board. thats whats causiong the problem. If you need further help go to this link they have your service manual available for emailing after purchase and that will entitle you for free tech support and one of their techs can fix those sets in his sleep he will walk you through the repair which parts are only about 20 dollars to fix the problem.
http://servicemanuals.vstore.ca/
May 07, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Olevia Syntax 42 inch turns green through hdmi
I had this problem running my pc through my television through DVI to HDMI as well as a normal HDMI cable. Now, I'm not sure about the ps3 but my problem was stemmed from the digital color format settings. When set to component video color settings rather than RGB or HDMI the screen looks great with no issues. I believe this is an issue with the tv itself which is why I had to "trick" it into working. However, I don't own a ps3 so I don't know if it's possible to change settings like that. I know it's not much, but I hope it helps.
Dec 01, 2007 | Olevia LT42HVi 42 in. LCD Television
RCA D52W26 Screen problem
remove spkr grill and a few screws, unplug connectors,remove entire screen assy and clean....reassemble
Aug 14, 2007 | RCA D52W20 52" Rear Projection HDTV-Ready...
Mitsubishi WD-Y57 57" Projection HDTV Logo
112 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
