Question about Sony BRAVIA KDL32V5500 32 in. TV
Didn't get a pedestal with my 32 inch Sony Bravia LCD TV. I do have a pedestal for my 42 inch Pioneer Elite TV. However, as you would imagine, the holes don't line up. I'm thinking of attaching two steal bars across the back of the Bravia and then attaching another, longer steal bar to those that will be long enough for me to attach the Elite pedestal to it. Before I begin this project does anyone know if it will be stable? I wouldn't want my grandchildren to topple it over. Thanks.
It doesn't sound like it would be very stable. Why don't you just call Sony and ask for a replacement part? They will usually quick ship you a part if it was not included at the time of purchase.
Posted on May 29, 2017
SOURCE:
welcomejee
  • 10594 Answers
SOURCE: I can't get rid of the information bar across the top of my TV
Press " i " (information) button on TV remote and on-screen display will disappear.
Posted on Dec 29, 2008
welcomejee
  • 10594 Answers
SOURCE: replacement table top stand for sony bravia 32
OK, Following is part number of Stand of KDL-32S3000 TV
A-1259-944-A STAND (M_WS) ASSEMBLY (KDL-26S3000/32S3000 ONLY)
It is available in Part Store.
Thanks.
Posted on May 18, 2009
  • 210 Answers
SOURCE: My SOny Bravia 40 inch LCD TV has a vertical line
It could be 1 of 4 things:
1. One of the ribbon cables has worked itself loose (Simple Fix)
2. One of the assembly boards maybe faulty
3. The driver board which feeds the panel maybe faulty
4. The panel is faulty
The driver board in the UK costs approx £70 and approx £35-70 to fit it if this is the fault.
All other parts are between £80-160 and approx £35-70 to fit it if this is the fault.
The panel will cost approx 50-75% of what the TV was worth when you bought it - "Repair versus Replacement"
Thanks
Posted on Oct 01, 2009
  • 52 Answers
SOURCE: sony bravia kld32s4000 32 inch lcd vertical lines
Bad LCD panel if still under warranty have TV service if not you need to replace the panel.
Posted on Nov 14, 2009
SOURCE: The TV has horizontal lines across about 5 inches
Horizontal lines are relatively rare problem in LCD TVs.
The likely problematic areas are:
1) The LCD itself (the micro ICs embedded into the LCD panel structure); that doesn't sound likely based on what you say, but it's not completely impossible. The bad news is it's mostly uncurable.
2) The power board A-1511-322-D G5
Power boards may sometimes cause problems with display, although rarely causing horizontal lines.
I wouldn't start looking here either, but it is certainly a problem to consider.
3) Main board 1-876-561-13 R1506072C
Slightly more possible and yet not quite likely. A high operating temperature and bad SMD soldering process may cause some soldering contacts on the main board to behave differently when the board is cold versus when it heats up. It is very common and may have all kinds of different effects on the TV and the screen.
One way to check for that is with a regular dryer..the process is explained in many other solutions at fixya and around the net, so I wouldn't repeat it here...but it takes time and patience.
4) The most likely place to start with is the T-Con / LCD controller
404652ASNC6LV4.1 M139.
I'd first replace that and see if the problem goes away.
5) There's a very minor chance that the LVDS cable that connects the main board with the T-Con does not make good contact initially and changes that as a result of getting hot. It's easy to just touch and move it lightly when the TV is still cold to see if it has an effect on the picture.
Sorry I couldn't just nail it for you, but that's the nature of the repair businss :-)
Bobby, www.coppelltvrepair.com
Posted on Mar 15, 2010
My screen is cracked on my 32 inch sony bravia.is there a replacement scrren i can buy
Replacement panels are available for purchase, but in most cases it will cost more to replace the screen Vs. buying a new set.
Jan 13, 2013 | Sony BRAVIA 32-inch 720p LCD TV...
Does my 32 inch Bravia have a fan? There is a noise in the back of my tv that sounds like a fan running.
There are no fans inside your 32 inch Bravia. I don't know the sound you are asking about. Is it a high pitch squeal? Is it a low volume humm? In either case you may hav e a bad filter capacitor or a problem in the Dolby noise reduction filter. In any of these cases, the filter cap in any location on the board can create the first sign of a problem. For starters, always suspect your filter caps.
Dec 19, 2009 | Sony BRAVIA KDL-32S2000 32 in. LCD HDTV
How can I use my lg lcd tv model m1994a for my ps3 there's no video signal,I try it all inputs to my lcdtv from av cable.component video,and hdmi cable still there's no video signal,but if I'll connect to...
I solve it already my problem by connecting my ps3 to an 32 inches lcdtv and I change the videosetting to my ps3 to default setting because before when I had my sony bravia 32 inches I changed it to 1080p via HDMI cable signal...After I changed to default settings I connected it again to my own LG lcdtv 19 inches but it sadly 1080p is not so very much supported but anyway I can play now ps3 games...
Nov 21, 2009 | LG 42LC2D 42 in. LCD HDTV
Can you fix a cracked screen on a sony bravia 32 inch
HELLO
The answer is simple to this one....NO!
This is the main problem with LCD TV's when the screen is cracked a replacement screen will cost more than a new set.
Your only cure is a new TV!
Oct 20, 2009 | Sony BRAVIA KDL-32S2000 32 in. LCD HDTV
I have a sony bravia xbr 32 inch and the picture is only on half the screen
It is possible that Twin Picture function is enabled, turn it off with remote/ menu options.
If this is not the case then T-Con board sounds bad and needs to be tested/ replaced.
Qualified tv tech will test and replace it.
Thanks.
Oct 06, 2009 | Sony BRAVIA KDL-32S2000 32 in. LCD HDTV
Replacing LCD TV screen
crack on the screan of 32 inch plasma
Mar 03, 2009 | Sony BRAVIA KDL-V40XBR1 40 in. LCD HDTV
Sony BRAVIA KDL32V5500 32 in. TV Logo
71 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Steve Allison
Steve Allison
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
