Question about Sony Cyber-shot W290 Digital Camera
The lens of my sony camera will NOT retracked. What can I do, I love this camera.
  • 109 Answers
There is a capacitor dump that you can try.
Remove the batteries, wait 5-10 minutes.
With the batteries out, press and hold the power button for 10 seconds or so.
Put the batteries back in and your camera will start over (re-boot). You will know if it worked if you have to reset the date. But if that lens is really stuck you may be out of luck. The cost to repair it will exceed the cost of a new camera.
Posted on Dec 18, 2010
Cybershot DSC-W290 The camera powers up but the screen display flashes a message to cycle power. The problem is reocurring.
Posted on Apr 19, 2011
SOURCE:
When I turn on the camera the lens comes out and then retracks and it says to turn the power off and on again. when I turn the camera off it says the same thing
Hi, I have to say that's a problem I've seen fairly often with the Sony W320. My suggestion is to take out the battery and make sure it's fully charged then put it back in. If that doesn't work I'd contact Sony.
May 12, 2011 | Sony CyberShot DSCW320 Digital Camera
The lens won't retrack
Unfortunately this is one of the most common problems in your standard 'point and shoot' camera. If you are unable to fix it yourself, the cost to repair something like this is generally about the same cost as a new one. You can try and take it to a friend or a local repair shop, but before you do try reading the information from this link. Hopefully that helps
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Mar 21, 2011 | Sony Cyber-shot DSC-W50 Digital Camera
Sony Cyber-shot DSC-W150. when powering on the
allienment with the mother board and also failure of the sensors of the lens unit,so contact sony service
Mar 01, 2010 | Sony Cyber-shot DSC-W55 Digital Camera
E 18 errror
The following blog outlines some repair options for an E18 lens error. They won't work for all cases, but they're worth a try if the camera's no longer under warranty:
Dec 28, 2009 | Canon PowerShot S2 IS Digital Camera
The zoom lens don't retrack Display don't
Charlene, It seems that there some dust that has entered between the lens housing and the camera body. To remove it you must use the vacuum cleaner to pull out the dust from this place. And keep switching on and off the camera so that it tries to move the lens inwards/outwards. If this does not work then the movement mechanism of the lens may have got stuck and would require more serious efforts for which you may or may not have to tools and knowledge.
Nov 02, 2009 | Vivitar ViviCam 8400 Digital Camera
Ex-z9 lens is bent and wont retrack. PUSHING THE POWER BUTTON GETS A LENS ERROR MESSAGE. aNY WAY TO GET LENS UNSTUCK
There is no DYI fix for your damaged lens, and attempting to repair it yourself will likely cause serious damage to the camera. Professional repair is needed to fix this problem.
Oct 25, 2009 | Casio Exilim Zoom EX-Z9 Digital Camera
Lens goes out and stays out even with the batteries out.
OK you are probably going to think I am loony giving you this advise But No I am completely sane!
Get a can of compressed air OR acces to a compressor at your local garage Get them to fit the triggered air blower tool to it.
Blow around the lens in all the extension joins the firmly slap it in the palm of you hand with the side of the camera making contact with you palm. Do the procedure two or 3 times and inbetween the slaps turn it on to activate the lens mechanism. I have now fixed about 80 of these cameras with this method. I obtained the fix from Sony who charge $90 to do exactly the same. Keep at it as it will eventually work. One tip, make sure the battery is charged before you do this.
Please rate our help to keep the service online
Sep 02, 2009 | Sony Cyber-shot DSC-W50 Digital Camera
My digital Sony camera fell down Lens got stuck
    As in short answer you have to replace the optical lens assymbly.Because due to heavy jurk its motor called sledge motor stsrt malfunctioning and it can not be changed component level. For this please contact any SONY SERVICE CENTRE nearby to you.
Hope you will understand.
Thanks for using FIXYA!
Apr 28, 2009 | Sony Cyber-shot DSC-H7 Digital Camera
I have an A520 Powershot..I dropped it and jammed the lens..now the lens won't retrack back in.
The following blog outlines some repair options for a lens error. They won't work for all cases, but they're worth a try if the camera's no longer under warranty:
Apr 24, 2008 | Cameras
Sony Cyber-shot W290 Digital Camera Logo
191 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
JonSnell Electronic
JonSnell Electronic
Syzys
Are you a Sony Camera Expert? Answer questions, earn points and help others
