Question about Sony BRAVIA KDL-V32XBR1 32 in. LCD HDTV
Sony Bravia Dolby digital SRS tru surround XT Model number KDL-32S5100 was changing channels and TV suddenly went black screen and won't change channels, cannot watch a DVD. Tried turning off and on, hitting menu button both on TV and remote as well as tried changing channels and unhooking from the DVD receiver to test. When I turn it off and back on, it powers up with the word Bravia on the screen but then it goes back to being black- no picture, no sound.
SOURCE:
SOURCE: Sony BRAVIA KDL-40S2000 40 in changing from HD to digital channels
40X2000, both PS3 and DVD player are using a HDMI input and both flicker and loose signal fully, have to turn TV of then back on to get signal back. Sony say they have never heard this problem and replaced board. NOTHING fixed, still same problem.
Posted on Jul 20, 2008
SOURCE: Can't Turn On SRS Tru Surround XT On My LG 42LH7000.
I have fiddled about with this and the SRS Tru Surround XT is only available with an HD signal. I tried BBC HD on BBC iplayer and the surround sound item on the TV menu burst into life.
Posted on Sep 14, 2009
vinnyq
  • 157 Answers
SOURCE: sony bravia kdl-52w3000, turn tv on, no picture or
Most likely this is caused by a defective main board. Changing the main board will fix the issue about 95% of the time.
To be absolutely sure, the voltages need to be checked on the power supply. If they are not the values listed in the service manual, then you should replace the power supply instead (accounts for the other 5% of the time).
Posted on Oct 07, 2009
maatmartin7
  • 1257 Answers
SOURCE: hi! I have a problem with my sony bravia lcd tv
You may have a case of a bad signal board. The clue was that your power button on the tv and remote are the only ones functioning. If the tv is still under warraty, call the service number to get help!
Posted on Nov 16, 2009
SOURCE: KDL-32M4000 sony tv screen went black suddenly,
We are having the same problem! Whats the solution!!!?!?!?!?!!!?
Posted on Nov 26, 2009
Sony model KDL-70W850B crack screen repair cost
It usually requires getting a new digitizer which on a cell phone is cheapish but for a larger screen it can get quite pricey. If you post a pic i can give you better idea.
Nov 07, 2016 | Sony BRAVIA KDL-70W850B 70" 3D 1080p...
My tv is turning off itself after a few seconds and I can't change the channels. This problem starts when I open the google and search the movie tube. How can I fix this?
Hi
first you do factory setting because all data become normal then try again if problem remove then ok if still second update the software if remove then ok but still at last you should change the system board
Feb 19, 2015 | Sony BRAVIA KDL-48W600B 48 1080p LED-LCD...
TV Flickering
change ur power supply all capacitor mat b solved ur problem
Mar 28, 2014 | Sony KDL46EX520 - Bravia Kdl-46Ex520 46"...
Using an antenna on KDL-32S5100
No you do not. Your Sony already has a digital tuner. If you are not getting all the channels you think you should, you just need to keep progromming your TV with the antenna at different locations to maximise your signal.
Apr 17, 2012 | Sony BRAVIA KDL-32S5100 32 in. LCD HDTV
Oct 18, 2009 | Sony KV-36FS100 36" TV
Found this on a forum somewhere. Clear Voice II is probably turned on. When this feature is on, SRS TruSurround is not available. You'll have to turn off Clear Voice II to enable SRS TruSurround. Someone mentioned that once you turn on TruSurround you can then go back on turn on Clear Voice again.
Apr 08, 2009 | LG 42LC2D 42 in. LCD HDTV
Mar 09, 2008 | Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
Sony BRAVIA KDL-V32XBR1 32 in. LCD HDTV Logo
179 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Steve Allison
Steve Allison
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
