Question about Mitsubishi WD-Y57 57" Projection HDTV
I replaced the lamp however the green light blinks for a minute then the lamp light comes back on and the tv can't be turned on. WD-Y57 model
    Sergeant:
    Champion:
  • 301 Answers
With that model after the tv shuts off pres the "menu" and "device" button on the front panel buttons together for about 8 seconds and then the power led will blink green. it will blink a certain number of times then pause and blink a different number of times this will be the error code for the fail that the tv thinks it is having. for example it may blink green 6 times then pause and blink 1 more time that would be code 61 check the code and repost and i will tell you the next course of action good luck
Posted on Jan 06, 2011
  • 2 more comments
  • grahamhill31
    grahamhill31 Feb 10, 2011
    Forgive me for being ignorant but I don't see a "device" button?
  • MATT BECKER Feb 12, 2011
    could also be labeled "input"
  • jeremyplaugh Apr 20, 2011
    I just replaced my lamp on the same model. It has worked for about 3 or 4 weeks and over the last few days the TV has shut off and the red lamp light comes on. I tried this method and got error code 66. Any thoughts? Is there a site that has these codes?Thanks
  • Wesley Jan 30, 2013
    Matt, I did what you said, and I got a code of 12. Do you know what that means?
SOURCE:
Wtf... wd-y57 change out the bulb. timer light blinks for a min.. then lamp light strats blinking tv wont come on HELP
If you did not have this issue before replacing the lamp remove it and look to see the socket it plugs into is not bent or damaged (it is possible when inserting to not get the two pins lined up correctly.
The lamp cartridge has to be installed precisely so it plugs into the socket and also the lamp door must be closed and secured.
Mar 22, 2012 | Mitsubishi WD-Y57 57" Projection HDTV
Wd-y57 change the lamp the bulb lamp light still blinking tv wont turn on
This question for some reason is posted here two times--see my previous answer here.
Replaced lamp but lamp light still blinks orange
I have a wd-57731 The lamp light blinked orange. i replaced the lamp turned the tv on and the timer blinks green for one minute and then the lamp light blinks orange again. It won't turn on. Can you suggest anything?
Nov 22, 2011 | Mitsubishi WD-57731 57" Projection HDTV
Tv shutdown
check your lamp door interlock switch.
Jul 31, 2010 | Mitsubishi WD-65733 65" HDTV
Blinking orange lamp light
if the lamp light is flashing and the tv won't come on you need to replace the lamp. check your owners manual for how to do it or call mitsubishi customer service
Jan 26, 2010 | Mitsubishi WD-Y57 57" Projection HDTV
I have Mitsubishi WD-Y57 DLP. Replaced lamp and now green timer comes on for a minute or so and then turns off. TV will not come on?? HELP!
I have the same TV. Mine is almost 3 years old. From what I've learned you should try to reset the TV. There is a small button in the front input compartment. Use a pen to push that in and wait for the green light to stop blinking. Then try the TV.
If that does not work you probably need a new lamp. Apparently the lamps only last for a couple years on average. Having to replace them can really add to the cost of buying/owning one of these TV's
Nov 21, 2009 | Mitsubishi WD-Y57 57" Projection HDTV
Red light status stays on, no screen....unplug for one minute then tv comes back on.....this has happened a few times...what is up?
If the red light is the lamp light then the projector lamp is defective.
915P049010 If your model is WD-Y57
Jul 07, 2009 | Mitsubishi WD-Y57 57" Projection HDTV
Mitsubishi WD-Y57 57" Projection HDTV Logo
723 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
