Question about Sony BRAVIA KDL-40S2010 40 in. LCD Television
I have a sony bravia 55 inch rear projection tv. model no. KF-55E200A. when i turn it on it flashes green like normal but then starts flashing red. can you tell me what is wrong with it please
  • Sony Master
  • 890 Answers
Most probably it is an optical block issue. You can contact sony customer service to setup the free service.. If you need the contact infomation, please let me know where you're.
www.fixya.com/users/shajanrs
Posted on Jan 17, 2011
6ya staff
SOURCE:
Ihave sony bravia kf 55e200a tv, but my tv wont turn on. The red light flashed 4 times and display flashed and off how can i fix.it
it is caused by a shortage in circuit board. it can be fixed by check and replace faulty components in main board.
if it is in warranty then claim it now,
if not then take it to a service shop.
Aug 02, 2015 | Sony Televison & Video
My sony KF 55E200A projection tv is loosing its colors what can be done to cure it ...plz help.
I need to know if areas of the screen are green or blue with the color set to zero or with the set on a unused video input with nothing connected is the screen a uniform grey or black? This will point to what kind of trouble you have.
Dec 12, 2012 | Sony KF-55E200A TV Lamp with Housing
Sony LCD Model KF-60WE610 lamp was replaced and then it shortly after stopped turning on. Blinks Green 6 times then Red 6 times Please help!
For Sony Model KF-60WE610, KF-50WE610, and KF-42WE610, the Diagnostic Code of power light indicator flashing 6 times green, then flashing 6 times red (6 red etc), means you need to replace part number A-1302-272A G1 BOARD, COMPLETE. See Sony Service Manual, 4. Chasis-1 at part Ref no. 103. The Power Board sits vertically in two slots on the left side of the electronics board. 4 wire connectors to remove when replacing. This component fits all 3 KF models listed above.
Jun 22, 2011 | Sony Grand WEGA KF60WE610 60" Rear...
SONY GRAND WEGA KF-50WE610 can't turn on TV screen.
Ths 5 blinks usually indicate an AKB problem. There is a break in the video path. I'll look up your specific model and post the results here. Please update this if you wish to attempt the repair yourself.
Thanks,
Dan
Mar 19, 2009 | Sony Grand WEGA KDF-55WF655 36" Rear...
60 inch sony wega tv
Green flashing is normal. Red flashes are error codes. Count the error flashes.
3x - Lamp cover position or cover detect switch bad.
4x - One or more fans failed RPM test
5x - Lamp power supply/ballast failure
6x - Thermal fuse failed (usually)
Oct 16, 2008 | Sony Grand WEGA KDF-60XS955 60" Rear...
Sony projection tv does not turn on
There are a lot of sites that sell bulbs for those. Use a search engine and the model with the word bulb. Be aware that it may be the ballast though.
Oct 12, 2017 | Televison & Video
Sony bravia
what model of Sony is it? On many of the Sony projectors, a 3 flash error code indicates the lamp is not properly seated/installed or the lamp door is not closed properly
May 15, 2008 | Sony BRAVIA KDL-40S2010 40 in. LCD...
Sony BRAVIA KDL-40S2010 40 in. LCD Television Logo
379 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Ekse
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
