Question about Philips 21PT4475 TV
Philips tv power supply ok but tv on and some seconds tv standby then power led is blinking
  • hothead08 Sep 18, 2008
    tv power supply is fine. but the led is blinking it takes more tha 30 min for the display.
  • uncola302 May 04, 2009
    +Everything was fine when we turned the TV off last night. Went to turn it back on today and the power light just blinks 3 times and quits. We recently stopped our direct TV but we've been able to watch DVDs since then. Can't figure out what the problem is. Any help is appreciated.
    Problem Solver:
  • 15 Answers
Sounds like the two large caps in the psu have gone slightly low in value and may need replacing.
Posted on Jan 04, 2009
I have a 32 inch phillips tv that I bought from someone else and it has a child lock code on certain channels. How do I get this code off.
Posted on Jul 15, 2008
SOURCE:
I have a Philips TV model 50FPF5332D/37. There is no picture and no sound.
Those blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
https://homenol.blogspot.com/
https://electronicshelponline.blogspot.com/
If blinks continue without any pause, the main board is faulty.
Search the site by type in the "brand name" to your device, [Exclude the model number] in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
Counting the number of blinks to Philips TVs is entirely different to that of other brand TVs. It is not a direct count procedure. The site have details about how to count the number of LED blinks [Fault Codes] to Philips brand TVs are given; along with details of the faulty circuit location./
Apr 06, 2018 | Philips Televison & Video
SHARP LED TV does not power on
Sounds like main board fault. These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
http://electro-medical.blogspot.com/
Blinking codes details of many popular brand TVs are given. Surf the site with patience.
Search the site by type in the "brand name" to your device, in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
Feb 10, 2016 | Sharp Televison & Video
I have a Sharp 70" (LC-70LE632U) LED TV. When you turn it on, the front led is on, but no screen. After a few seconds, the front led starts 5 short and 2 longer blink and continue this way constantly.
Blinking codes details of many popular brand TVs are given. Surf the site with patience. If blinks continue without any pause, the main board is faulty.
Counting of number of blinks to Philips TVs is entirely different to that of other brand TVs. It is not a direct count procedure. The site have details about how to count the number of LED blinks [Fault Codes] to Philips brand TVs are given; along with details of the faulty circuit location
Nov 12, 2015 | Sharp Aquos LC-70LE632U 70 Inch 1080p...
42pf7320 10
These blinks (flashes) are fault indication. By the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit stage inside the TV. Count the blinks occur at one time switch ON, carefully. Do it once again, and make sure about the number of blinks. If the flashes are continious, non-stop, the main system control IC should be suspected. If you wish to get more details, check the site linked here. It has blinking codes detail to many brand TVs. Pull up older posts. Check the site in 'Mosaic' view. It will make search easy. http://electronicshelponline.blogspot.com/
Counting procedure to blinking codes to Philips TVs, are entirely different to that of other brands. Cannot count it directly. Just surf the site linked above for more details.
Jan 16, 2014 | Televison & Video
Turns on, lower right shows "DIGITAL TELEVISION"
Good day!!!
That problem is usually cause of bulged capacitors on the power supply board..
This the sample picture of your power supply board and I marked the possible problems on capacitors..
Things you will need.
1. A plastic flat end screw or any object with flat ends....to fry off the cover
2. Soldering iron.
3. Soldering lead
4. Soldering pump.
5. Flat and Philip Screw
6. Replacement capacitors (of same value with the blown one) that you can buy to any electronics store.
Hope it helps..
Feb 02, 2012 | Sylvania LC420SS8 LCD TV
Tv sony stop after 20 min standby led flashes 3 times
HI,
By three blink it means the B+ over voltage protection (OVP), unit goes to the standby mode then displays the 3 blink fault. This is because there is problem in the power supply circuit. Check for any dry soldering in the power supply side. If the tv is working properly for 20 minutes then its sure that there is some dry soldering joints in the power supply side. You have to resolder suspected soldering contacts using soldering ion and solder. The dry soldering joints will look like on in the picture.
ajin_g_109.jpg ok
Oct 06, 2011 | Sony KV-29FX66 29" TV
Philips 42PF5321D/37 Plasma No Picture Six Red LED Flashes
http://homenol.blogspot.com/
Counting of number of blinks to Philips TVs is entirely different to that of other brand TVs. It is not a direct count procedure. The site have details about how to count the number of LED blinks [Fault Codes] to Philips brand TVs are given; along with details of the faulty circuit location.
Mar 12, 2017 | Philips Televison & Video
AKAI LCT26Z4AD wont power up.
Mar 10, 2017 | Televison & Video
Toshiba TV
Will not power, led blinking
check R640 (1K 1/4w) if open replace ic600 (8-759-670-30)
Standby led blinks slowly, a few times, chassis won't start up
I changed the vertical deflection ic type TDA8170 and I measured two leaky capacitors in the power supply. Better to change all 4 capacitors in the power unit, everything was then ok !
Nov 24, 2007 | Toshiba MD13P3 13 in. TV/DVD Combo
Actually Philips 20PF5320/01 Fault no power, blinking LED
ok you have defective power supply! from the secondary power supply! or hot side.
Oct 08, 2007 | Philips 20PF5120/01 20 in. EDTV-Ready LCD...
Philips 21PT4475 TV Logo
223 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
