Question about Mitsubishi WD-65C8 65 in. LCD HDTV
My mitsubishi wd-65c8 has a flashing green light.. I have replaced the capacitors on the DM board and the same is happening.. what else could be the issue. <a rel='nofollow' href=http://www.musicfrost.com/ >salsa music</a>
    New Friend:
Moving vertical lines on top of my WD-Y65 Mitsubishi TV
Posted on Jul 07, 2013
    Master:
  • 691 Answers
Common Repairs
For the following models: WD-52631, WD-57731, WD-65731, WD-Y57, WD-Y65, WD-57732, WD-65732, WD-57831, WD-65831, the most common repair problem stems from television shutting off almost immediately after it has been turned on accompanied by the message, "TV will shut down in a few seconds. Please check if the air flow is blocked." According to the Mitsubishi website, this issue is caused by a loose connection as a result of a faulty thermal sensor. For models: WD-73727, WD-73827, WD-73927, WD-73732, WD-7383, the most encountered repair problem has been in relation to the optical engine. Another common situation consumers have encountered is failure of the TV to turn on along with unceasing flashing of the green power light. The solution for this problem, caused by the DM board, will vary by repairman. Consumers have also encountered issues with moving vertical or horizontal lines appearing on the screen which can either be due to problems with the capacitor, light engine, or formatter board. Make sure all bad caps are changed.
Posted on Jan 23, 2011
SOURCE:
Wd-52525 flashing green light reset does ot fix. have to unplug for a few seconds to fix. Is this a conputer probem inthe TV?
Ur DM power supply board have problems.U know how to solders?Capacitors bulb up or pop open.Replaced this capacitors will fix ur Flashing power.Tries website Tv repair World.com to buy these capacitors to replaced.
Apr 13, 2010 | Mitsubishi WD-52525 52" Rear Projection...
Mitsubishi TV green flashing timer light after power outage.
You will need to cahnge the capacitors on the DM board, very common problem. The V21 V19 DM repair kit at the following link contains the replacement capacitors and detailed instructions. Its listed under the repair kits catagory at the following link.
http://servicemanuals.vstore.ca/
Aug 29, 2009 | Mitsubishi WD-52525 52" Rear Projection...
I turned on the TV but just got a black screen but could hear audio just fine. Turned the set off and unplugged it. When I plugged it back in the green timer light started flashing and would not stop...
Nonstop blinking is likely a DM or format board - format board most likely. I have rebuilt several of these by simply replacing all the caps, about 70 of them, and takes about two hours start to finish... But this set does need to boot. It takes about 70 seconds of flashing green light before you're able to press the power button - even when everthing is working as it should..
Hope this helps!
Bill
William Rayburn, CET
Premium Technologies
PO Box 442
Long Beach, WA. 98631
360-642-4993
Aug 22, 2009 | Mitsubishi WD-52525 52" Rear Projection...
Green light flashes continuously and you cant turn TV on.
Got nothing but bad news for you. The Digital Module is not booting up. A common problem for that unit. The only proper way to fix it is to have a reputable tv shop pull the entire chassis and ship it back to Mitsubishi for rebuild. It is a very costly repair. Usually in the neighborhood of $700 to $800.
Jun 09, 2009 | Mitsubishi Televison & Video
Green Light Under Timer Stays Flashing and Will Not Go Out
Mitsubishi has repaired some sets if you have the origional purcahes documents. If not you can get the v26 DLP DM repair kit which should take care of that issue. Heres a link to the kit if needed.
http://servicemanuals.vstore.ca/product_info.php/pName/v26-dlp-dm-pwb-repair-kit/cName/repair-kits
Apr 21, 2009 | Mitsubishi WD-52725 52". Rear Projection...
Mitsubishi HDTV
Press and hold menu button for 8 sec, then unplug for 1 minute. Plug back in and 1 minute later it will pop up for you.
Jan 27, 2009 | Mitsubishi WD-52525 52" Rear Projection...
Screen won't turn on --flashing green/solid green power light
Your main boards are bad. They are no longer available, You have to have the chasis rebuilt. Mitsubishi is rebuilding these chasis. You have to pull it without any cut wires & ship to Georgia.
tvdoctor
Jan 21, 2009 | Mitsubishi WD-62725 62" Rear Projection...
Mitsubishi wd-52628 flashing green timer light
If the power/timer led is the one blinking constantly
the most likely problem is two 3300 mfd caps and 1 to 8 1000mfd caps on the power board.
could be the DM board or caps on it as well.
Jun 17, 2008 | Mitsubishi WD-52628 52" Projection HDTV
Flashing green timer light, no image on TV
4 capacitors on the DM board causes this they are 1000uf @35 volts replace these capacitors and that should take care of your problem
Mar 19, 2008 | Mitsubishi WD-52628 52" Projection HDTV
Mitsubishi WD-65C8 65 in. LCD HDTV Logo
1,540 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
