Question about LG 42PX4DR 42 in. Plasma TV
The picture has hot spots and some times you can see thr lg logo
  • 49 Answers
Was it a display unit? If so its burn and you can't get it to go away Try to reset the unit by holding your Menu button for 8 to 15 seconds with the TV on. If this doesn't work then you'll most likely have to have the screen replaced. Check your serial number and see how old it is. First number is the year it was made. Next two are the month. so 911 is November of 2009. They find out what your warranty is. If its near the in warranty terms you stand a chance of LG taking the lead on fixing it for you for free or reduced cost.
Thanks,
Shawn
Posted on Jan 30, 2011
6ya staff
SOURCE:
My lg 52ld 550ub, has a problem . No picture, on lg logo comes on and red blinking light
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
If blinks continue without any pause, the main board is faulty.
Search the site by type in the "brand name" to your device, in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
May 18, 2016 | LG 52LD550 52Inch 1080p 120Hz LCD HDTV...
I am trying to pair my LG Volt smartphone with my LG GPad 8.3. They are both running Android 4.2.2
This can be tricky. it also involves the use "mobile hot spot". set your primary device as a wifi hot spot, then attempt to tether or pair the devices.
Aug 29, 2015 | LG Cell Phones
No picture but have sound.
Hi Celeste,
I appreciate your efforts so far.You have sound but no picture. Can you see the backlights? Or is there the on screen LG logo? If the logo is not there it means the backlights in your TV are not working. Mostly it is the inverter board which makes necessary power for the back lights goes bad. Good LUCK.
May 26, 2015 | LG Televison & Video
How do i get hot spot on my lgl34c phone
hot spots are not for phones tablets and notebooks .
Feb 23, 2015 | LG Cell Phones
My LG LH40 47Inch screen shows logo then gos off
Main board fault. Contact any service technician, or the authorized service center for LG. The second said will be the best.
Gopakumar Gopalan Google
Apr 01, 2014 | LG 47LH40 47 in. LCD HDTV
My fathom vs750 showing invalid battery id when iam switch it on after that it switching off, what can i do
I brought lg fathom vs 750 online its seller refurbished , after i install the battery , i start switch on the mobile first lg logo is showing on the display after that a sign of battery picture is showing on display with invalid battery id written on it , after that it stops , i mean switching off..pls advice me how to resolve this problem.
Jun 12, 2012 | LG Fathom VS750 Phone Verizon Wireless
My psp logo doesnt appear but it has green light
while booting up ur psp press thr R button the change the setting skip sony logo to disable
May 12, 2010 | Sony PlayStation Portable (PSP) Slim...
I just bought a 2000 ford taurus. It would not start or crank over.I noticed the ign.key had a lincoln key logo. I bought a new pats taurus key. It still did'nt turn over. A ngs was hooked up to the dlc...
At the base of your steering column is the ignition/start/run switch. This has failed and needs to be replaced. You'll need to drop the column and remove the kneepad to gain access. Be sure to locate the new switch in the exact spot of the old one. It has slotted screws.
Oct 12, 2009 | Ford Taurus Cars & Trucks
Spots on clothes after washing
Put another filter on before the washer. Try to find out if it is in the hot water or the cold. If it is the cold try a filter. If it is the hot, replace your hot water tank.
Jun 06, 2009 | LG WM0642H
LG 42PX4DR 42 in. Plasma TV Logo
143 people viewed this question
Ekse
RONALD CARTER JR
