Question about GE GSL25JFPBS Side by Side Refrigerator
I am able to access the back of the condenser coil to clean it but cannot get to the front of it. Using a flashlight from the front I can see that the coil is totally caked with dust. How can I get to the front of the coil in order to clean it? The fridge is very low to the floor and it appears that the water lines enter through the front toe plate, therefore making it hazadous to remove the toe plate. Even if I were able to remove this plastic toe plate, there is a metal one directly behind it. I do not see any way to clean the front side of the coil without totally disassembling the refrig. I am a woman, so that is not an option. Please advise.
  • GE Master
  • 2,699 Answers
Get a shop vac and a condenser coil brush,you can buy it at any appliance or hardware store,you stick the brush into the coil and the dust sticks to it or falls apart onto the floor or i use a shop vac,one end vacs the other end blows,i vac up as much as i can and then blow the rest off of the coil,you can remove the bottom back panel and blow it to the back wall and then vac up the dust that blows to the back
Posted on Feb 27, 2011
  • 6 more comments
  • robertshe560 Feb 28, 2011
    The problem is cleaning the FRONT of the coil. I have already removed the back panel but cannot access the front of the coil
  • Sal De Feb 28, 2011
    remove the front bottom panel and remove the back bottom panel,tick the nozzle of the shop vac in the front with it on blow and blow the dust from the front to the back and it will blow out the sides,then just vac up the dust.it's that simple.i do it all the time
    The water line is entwined in the front panel and there are metal panels behind the front panel. I already broke a spring and lever type mechanism to release the front (plastic) panel (when the doors are open) but the panel will not release due to the water line being there. Do not want to deal with pulling the water line out. It is a GE Profile model, about 5 or so years old.
    if you can't remove the bottom front kick plate you better call someone in to show you what to do to get it off so you can clean the coil.on some of the front panels there are two screws that hold the kick plate on or you just grab it and pull the bottom forward and it pops off,it might look like the water line is wrapped around it but it should be behind it.if the water line is in the way there's a quick disconnect on the line,no water will come out until you hit the dispenser for the water.if you can't do it get someone that can,i can't tell you any other way you have to remove the kick plate to clean the coil
    I will try it this morning. Thanks
    Yes, the kick plate was held on with screws that were accessible when the doors were open. Behind the kick place there is a plate that appears to be porcelain, with oblong 1.5" oval openings every few inches. This plate is machined onto the bottom of the refrigerator. The oval openings are not large enough to even put a regular vaccum hose through. I can't imagine blowing from the back, as I will die of an asthma attack and the job will still not be done. It is no wonder we live in such a throw away world. Thanks for your help.
    listen to me,pull out the fridge,remove the bottom back panel,on the right hand side you're gonna see a round piece of metal with holes in it next to a fan blade,that's your coil,get the shop vac and vac off as much as you can,do this with the fridge unplugged,then switch the shop vac around to blow,blow into the coil with quick short bursts,when the dust blows out vac it up then blow it again,do this until it's clean,you can blow into the coil near the fan blade also,that will blow anything from the inside out and you should be done cleaning the coil in 5 to 10 minutes,if you want to clean under the fridge,remove the front kickplate and blow into the front and any dust that's under it or in front where you can't reach it will blow the dust to the back and out the sides,it's this simple,if you just want to clean the coil it's in the back on the right hand side,it's not like the older machines with the coil underneath.i hope this helps you out,you said you cleaned the coil in the back if you want to clean under it just blow it out from the front.with your vac you can't use a brush or anything all you can do is blow it out to clean it,if you already did this then you're all done
  • Sal De Mar 01, 2011
    how did you make out,did you clean your coil?
6ya staff
SOURCE:
Freezer only gets down to around 18 degrees but fridge is fine. No frost on the freezer evaporator fan is running
Modern consumer refrigerators only have coils in the freezer. In the lower back of the freezer there is a small fan and possible a damper (flap that opens/closes) to push cold air from the freezer to the refrigerator. Given that the freezer is 18 deg, it's probably cold enough to keep the fridge area at typically 34 deg.
So the cooling system (compressor, coils, thermostat) are not working properly to keep the freezer at, typically 0 deg. Possible causes: partial loss of refrigerant gas, icing around evaporator coils (in freezer), compressor failing, dust clogging condenser coils (under fridge), condenser fan clogged or broken (under fridge), thermostat failure.
I'd start with condenser. Remove the slotted trim at the bottom front and look in with a flashlight. Are the coils clean? Pull out the fridge and remove the lower back cover (usually cardboard). You can now see the coils and fan. Clean and blow them out.
If it's icing, it probably means freezer door not closing tight. If auto-defrost not working properly it would probably get worse over the period of a few days so not likely.
Apr 21, 2016 | Frost Refrigerators
Tip
Cleaning your coils.
<span>Remove the grill along the bottom of your refrigerator. Locate the drip pan, using a flashlight if necessary. The pan should be sitting on a set of black condenser coils.<span> </span><span> </span></SPAN><br> <span>Remove the pan and wash it. Use a mixture of warm, soapy water and bleach to kill the mold.</SPAN><br> <span>Reinstall the pan and the grill.</SPAN><br> <span>Locate the coils. They look like thin, black radiators and may be underneath the fridge or attached to the back.</SPAN><br> <span>If the coils are on the back, pull the refrigerator away from the wall, then vacuum the dusty coils, using the brush and crevice attachments. Reinstall the refrigerator grill.</SPAN><br> <span>If the coils are underneath, pull off the grill and remove the drip pan. Vacuum the dusty coils, using the crevice attachment to get between them. Take care not to damage the delicate coils. Reinstall the refrigerator grill.</SPAN>
on Feb 23, 2011 | Refrigerators
Temp in the freezer and refrigerator not as cold as they should be. COntrol on the coldest.
There are two sets of coils for cooling appliances like refrigerators, they are called the evaporator3 and condenser1 coils. Overly simplified, the two coils are filled with gas and liquid respectively, and are parts of a complex "circuit" that has a compressor4 and expansion valve2 that perform the work. The gas filled evaporator coil is located in the space to be cooled, and performs the task by absorbing heat from that space. It is usually protected from damage and out of view inside the freezer section. The "heated" gas is compressed by the compressor, where it is further heated (hot to the touch) by the compression process. The heated compressed gas and liquid is passed through the condenser coil that is located away from the cooled space. This condenser coil is where some of the heat in the liquid is released to the ambient air. The cooled liquid is then drawn through the expansion valve by the suction of the compressor, where the liquid immediately boils off to a gas. This causes the temperature of the gas to drop significantly (well below freezing) in the evaporator coil. The process repeats until the thermostat in the space is satisfied. Because the condenser coil is exposed to the ambient air on the refrigerator, it requires regular cleaning. There are a few locations that the condenser coil may be found:
  • Older refrigerators have the coil (a grid-like structure often painted black) mounted on the rear of the refrigerator.
  • Newer refrigerators often locate the condenser coil at the bottom. It is likely that a fan (that may or may not be readily visible) will be directed at the coil to assist with heat dissipation. Use a flashlight to assist locating the coil and fan if needed. The coil will be accessible from one of two places:
    1. Toe space panel. Remove the panel at the bottom of the front of the refrigerator and carefully slide the condensate tray out (if present, the condensate tray may contain water). A visual inspection upward into this space may reveal a flat condenser coil when located here.
    2. Rear access panel. If not found behind the toe space, the refrigerator will have to be slid away from the wall further to work from behind. Disconnect water supply lines if too short to allow enough room to work. Remove the fasteners that holds an access panel in position. The condenser coil may be flat, but will likely be cylindrical in shape when located here.
Feb 03, 2015 | Refrigerators
Where is the filter on this dehumidifier. Mod# ad75ust
To locate the filter: Shut unit off. Remove "bucket". You should find a "tab" at top of where bucket goes in middle front of unit. Pull down to remove tab of Filter. Clean thoroughly and dry Filter before re installation. Visually inspect the coils and condenser while filter is out ( a flashlight helps). If it looks slightly dusty or like covered in felt, then it would be wise to remove front and rear covers and give the coils and condenser a thorough cleaning.
Sep 26, 2013 | Whirlpool 75-Pint Dehumidifier
Ge gss25wgpa
Typically on most household refrigerators there is a kick plate in the front of the refrigerator on the bottom, that usually is just clipped on either pulls out or lifts up and pulls out. If there is nothing there, then unplug the refrigerator and there is usually a handful of screws that hold a access panel on, it will be towards the lower part of the refrigerator. Remove the screws and the access panel.
(be sure the unit is unplugged for safety)
from there the condenser coil is typically is located towards the front of the refrigerator, you can use either a shop vac, or a coil cleaning brush available at a hardware store, and clean the condenser coil off.
Then re install either the panel or the kickplate, and plug the refrigerator back in.
Be sure not to disturb the wiring or the piping and you should be fine, if unsure of what to do, then I recommend not doing it......
I’m happy to assist further over the phone at https://www.6ya.com/expert/robert_54ae41aaaffbab00
Jul 08, 2013 | Refrigerators
My dehumidifer runs but no water is being pulled out
Might be a dirty coil and condenser.
I have had a AD75UST0 WHIRLPOOL Dehumidifier for several years. If it actually still runs, I would suggest you take off covers and give the coils a good thorough cleaning. Otherwise the units are not designed to be serviceable aka - "disposable small appliance". if you do dispose of it take it to a qualified recycle organization for Freon products. Shut unit off. Remove "bucket". You should find a "tab" at top of where bucket goes in middle front of unit. Pull down to remove tab of Filter. Clean thoroughly and dry Filter before re installation. Visually inspect the coils and condenser while filter is out ( a flashlight helps). If it looks slightly dusty or like covered in felt, then it would be wise to remove front and rear covers and give the coils and condenser a thorough cleaning.
WHIRLPOOL DEHUMIDIFIER Parts Model ad75ust0 Sears PartsDirect
Apr 18, 2013 | Whirlpool 75-Pint Dehumidifier
Freezer is freezing, but ice box is not cold. Told to clean fan. Where is the fan located?
Feb 25, 2011 | Refrigerators
GE refrigerator Model GTS18FBSARWW Don't have manual, as it came w/the condo. Don't know how to clean the coils or how to get to them, either. Thanks.
The condenser coil is located underneath the refrigerator on most models. YOu can access it from the front, or in some cases, in the rear. To access it from the rear, after pulling it away from the wall, you will have to remove the machine compartment cover screws and the cover itself. If it is the type i believe it is, it is called a no-clean condenser, but they still need occasional cleaning. It will be a barrel shaped condenser on the right side of the machine compartment. A good refrigerator tip for anyone looking to clean the condenser is to make sure you turn the fridge off or unplug before cleaning it.
Oct 13, 2010 | GE GTS18FBRWW Top Freezer Refrigerator
I have a Samsund SRS579NP both fridge and freezer not getting to right temperature. I don't think that the temp gauge is working properly. the fridge says that it is -1 degree but its deffiantly not that...
My first thought is dirty condenser coils (the coils on the bottom of the refrigerator behind the kick panel). You wouldn't believe how much impact a large accumulation of dust and lint on these coils can have on the efficiency and operation of a refrigerator. It's also one of the least expensive 'fixes'... It's FREE.
Remove the front kick panel and, with a flashlight, look at the horizontal coils under the refrigerator. If they are covered with a thick layer of dust and lint, you can almost be assured that this is the problem. They make tapered brushes specifically made for cleaning these coils, but any long slim brush that you can get between them to clean off the accumulation of dirt is better than nothing.
You can do a more thorough job if you pull the refrigerator out and remove the back panel to clean from both front and back. Be sure to unplug the refrigerator while you do this to avoid the condenser fan from coming on while you're working. It's always advisable to use a vacuum attachment to actually REMOVE the dust and lint from the bottom of the refrigerator rather than leaving it under there to be drawn back up into the coils very quickly after you've cleaned them off.
There's no specific definition of 'clean' coils, but my advise is to clean them as thoroughly as you can and be sure to clean off the small condenser fan as well.
Put the panels back in place and plug the refrigerator back in. This should do the trick. Dirty condensers can make you think your whole refrigerator just when ka-pooey when this easy (although somewhat dirty) task can make it run like new again.
Hope this helps.
Jun 28, 2009 | Samsung Refrigerators
GE GSL25JFPBS Side by Side Refrigerator Logo
295 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Ron Beer
Ron Beer
Level 1 Expert
vince
