Question about LG TROMM WM2688H 4.0 cu.ft. Front Loading SteamWasher
LG tromm front loader OE
The error code OE is falure to drain we found that if we blast a jet of air from our compressor up the drain hose durring the last drain cycle. The OE goes away and the washer drains fine for a while. WE have been doing this for 6 months about every two weeks. Please help us perminantly fix this issue. Thanks John
  • 2 more comments
  • phantom13 Aug 10, 2008
    my LG tromm was leaking from the vent in the back. I blew air up the drain hose and it was draining for about 15 minutes then gave the code OE.
  • cpower79 Sep 29, 2008
    I am having this problem also. I drain the washer and clean out the filter about once every 2 weeks (because I have 3 dogs and I want to keep the dog hair out of it) and I got the error message this weekend, drained it, cleaned the filter, put it back, etc. and when it got to the next drain cycle it still gave me OE. It did this several times last night until it got so late that I decided to pick it up again today. It says this error message can also be a clogged or bent drain hose, but the drain hose is draining and the part that comes outside the washer isn't bent. Can anyone help?
  • SUPERFREAKY Dec 07, 2008
    WE ARE HAVING THE SAME ISSUE....AND YES WE HAVE REMOVED THE SMALL ACCESS PANEL IN THE FRONT AND CLEANED ALL FILTERS, WE HAVE CHECKED ALL HOSES...COULD IT BE NEEDING A NEW PUMP? IF SO ANY TIPS ON CHANGING THE PUMPS OR SHOULD WE SCRAP THIS????
    k
  • Anonymous Mar 21, 2014
    When it gets to the rice cycle water does not drain to spin and I get oe already checked line and small basket in front pump is louder than normal LG tromm wd5670
    New Friend:
All of the ways to solve this problem are right on--take the filter out (in front on the bottom left when facing the machine). Before you do, take time to drain out the water with the hose below. Once drained open the filter and clean out. Try on speed wash with no spin. Nine minutes in you will know if the drain works. If not, turn on side and remove the washer pump. To do this, remove the hoses first starting with clamps. Then remove the three screws in front where the filter is. It easily comes out. The top pump is the drain pump. First mark the wires--blue is positive and black is negative. Remove the pump and clean out.The pump comes out of the casing. Try removing this and cleaning. If you have a power source, test the pump. If works, put back and start in fast cycle with no spin. If not, then you have to replace the drain pump. You will not find anyone in town the has the pump unless you live in New York or Dallas Texas. To get the pump at a reasonable price and expedited call and order through Sears at 18004881222. These guys are good and well get it to you as promised. The entire job once recieved the pump took about 30 minutes. Also, saved about $100 in labor. Good luck and hope this helps...
Posted on Dec 31, 2009
  • 6 more comments
  • elodiepass
    elodiepass Apr 04, 2012
    Thank you so much for your detailed solution: you just saved us having to call a repairman and spending more than we needed to. Thank you!
  • elodiepass
    Thank you for saving us having to call a repairman. Sincerely!
  • suzanne_isab
    suzanne_isab Nov 13, 2012
    oh my gosh this problem drove us crazy last night - looking forward to taking your directions home and trying this, tonight. Thank you so much! (fingers crossed)
  • Margo Smith Dec 23, 2012
    A few things are unclear. Do you mean to turn the washing machine on it's side?
    These directions are not clear.
    At one point you talk about a "washer pump" and then a drain pump. Are these two different things?
  • HEATHER DREW Dec 23, 2012
    Having the same problem. There is no way I can turn the machine on its side as it is stacked with dryer on top and under the stairs of our 100+ year old house. Is this something we should source out for repair?
  • 706 Answers
This may be obvious but have you cleaned the filter that precedes the pump? Open the small access panel on the bottom left ( front of the washer) and twist out the filter trap.. clean all debris.. and the little bit of water that trickles out onto your floor.. Hope that helps...
Posted on Aug 29, 2008
    New Friend:
I just took the whole drain pump out and if you have a phillips screwdriver and some patience the pump is very easy to remove. Once I had the pump out I took off both the tops off each pump to view the impeller and cleaned them up. This all started with the EO error that would not clear. Once I cleaned everything up, blew out all the drain hoses with air and water and reassembled my washer was back up and running. The pumps still make quite a bit of noise so I will be getting a new one but getting to the pump was not bad at all and you can test you washer with ease outside if you so choose by hooking it up to your garden hose and just use the cold setting.
Posted on Oct 08, 2013
6ya staff
SOURCE:
My LG Tromm front loader has an OE error message and isn't spinning. First received the message during a full load of laundry. Had to drain the water from the hose at the bottom and finally got it unlocked...
OE is normally down to blocked drain pipes, mcalpine (connection under the sink) or a blocked front filter. empty the machine and unscrew the filter behind the flap at the bottom right hand side, check for any obstructions, icoins, hair grips etc are normally blocking here
Apr 10, 2014 | LG WM-2277HW Front Load Washer
IT DON'T GO THROUGH CYCLES COME UP WITH A CODE OE
Hello & Welcome to FixYa
OE is a drain error and is displayed when the washer is unable to drain water. Please check the drain hose and drain pump filter for any clogs to clean the error. Please get back to me if you have any other questions.
Kevin
Jan 06, 2011 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
Lg tromm front loader washer wm0532hw shows oe error
that's draining error. check the filter cleanout behind lower left panel on front of machine; of course drain 1st via small drain hose. if thats o.k the drain pump itself may be jammed with debris or the drain hose could be clogged.
Jun 24, 2010 | LG WM-2277HW Front Load Washer
I have the LG Tromm 27'' Front Loader model WM2277HW
The LG error code OE simply means "the pump is blocked". Presumably the water isn't being emptied properly. As with all error codes it is possible that there is a cause other than the exact description in the error code explanation but basically this error means as far as the washing machine is concerned it thinks the water isn't pumping out. A pump, or filter blockage is the most common cause but it could be caused by other faults such as a faulty pump, or even a blockage in the drain hose or somewhere else in the system etc.
LG themselves have some information on this error code..
http://lgknowledgebase.com/kb/index.php?View=entry&EntryID=6273
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.!!!!!!!!!!!
Oct 07, 2009 | LG WM2688HWM TROMM SteamWasher
Getting the OE error message on LG Tromm
I have an LG TROMM wm1812cw washer. Out of the blue the machine will not spin or drain. It has given an an error code OE
Sep 27, 2009 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
MY LG WASHER WONT DRAIN, IT SAYS THE ERROR MESSAGE
OE is a drain error - Check there isn't a kink in your drain hose, ensure the filter is clean, the drain hose can become clogged with sludge, sometimes a hot wash with 1/2 a cup of vinegar will remove this sludge
May 06, 2009 | LG WM2277H Front Load Washer
OE error code on LG front loader
The OE error code means:-
The Drain hose is kinked or blocked or the drain filter is blocked
Solution:-
Clean and straighten the drain hose and clean the drain filter
Nov 01, 2008 | LG WD-14124RD Front Load Washer / Dryer
Washing Machines Logo
26,485 people viewed this question
Top LG Washing Machines Experts
Gerry Harvey
Gerry Harvey
Marvin
Marvin
jimorris77
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
