Question about Car Audio & Video
Radio not working on my 2002 Nissan Primera."Secure" message comes up on display.No access to radio or cd. Brought it to main dealer and was told key needed to be paired with radio. Had this done but secure message still coming up,now they say its a fault with the radio and will have to be replaced. Considering that the radio was not taken out and checked and the the cost of replacment I am wondering if they were just trying to sell me a new one.Surely there must be an easier fix to my problem
  • fubartoons
    fubartoons Apr 21, 2012
    serure message eventually changes to "enter code" when ignition key is on. the code is entered by using radio preset numbers 1-4. so if the code is 7234. press "1" 7 times; "2" 2 times; "3" 3 times and "4" 4 times, then press ^ up button and its entered correctly. your pin number should be with your car, possibly near the back of its manual. if not, you should be able to obtain the pin code from a nissan dealer, using your registration certificate (log book)
    New Friend:
Any solutions, i hav e the same problem
Posted on Jul 11, 2013
I have just returned from my main nissan dealers in silversprings cork. Very polite and helpful. I got the exact answer as main post had. He informed me that i should try and source the radio part second hand as it is very expensive to buy a new one. He was very helpful. Maybe he and his mechanics were unaware of the radio code being entered incorrectly too many times. I will try this as i have not left the radio on for more than one hour. I will update ye on how i get on.
Posted on Feb 22, 2013
  • 2 more comments
  • mattias_b_jo
    mattias_b_jo Mar 05, 2013
    Any updates on this yet, did you manage to fix it? I just discover the same problem with my stereo so I'm very interrested about the outcome of this.
  • mattias_b_jo
    DDid you manage to fix your problem? I have just noted the same error in my car, so I'm very interrested if you suceeded or not.
  • Dominic McCarth Apr 01, 2013
    Radio on 02 Primera stuck on Phone mode ..any solutions please??
  • dieudelautorite
    dieudelautorite Jul 12, 2019
    pls i have same probless on my nissan primera i need help on how i can fix my radio
    Renaissance:
    An user who is expert in 3 categories / brands.
  • Car Audio & ... Master
  • 2,226 Answers
The radio probably needs a code to be entered. It sounds like someone tried to enter the wrong code too many times. See if you can get the right code, then leave the radio turned on for an hour or two. The secure message should disappear then to be replaced by code. You should then be able to enter the code.
Posted on Apr 07, 2011
SOURCE:
Radio not working showing word SECURE
look inside your book owner manual
somewhere it supposed to have the code and a way to enter the code ,
or a manual of the radio !
somewhere in those books the code is printed like a ink pad label !
when you change the battery you need to inter the code each time,
open the radio with the number pad enter the code
you must do step by step like the manual of the radio say !!!!!
or the car dealer could help you
if you dont have the code the radio is useless
Nov 27, 2015 | 2003 Nissan Primera
I've got a nissan primera, 2004, radio was faulty so I got a 2nd hand one off ebay with code, I fitted radio and all it says on the screen please wait that stays one for a min or 2, then it says secur
Turn radio on and leave! It could be minutes or hours.....depends on how many attempts to input code have been made! The radio will eventually be ready to accept code! If you turn radio off before it reaches the code stage the process starts again.......so turn radio on and leave, just keep checking the screen for indication of code ready to be input!
Feb 06, 2015 | Clarion Nissan Primera P12 Tuner Amp Radio...
Nissan primera no heaters no sat nav no radio or cd plus the doors wont lock any solutions thanks
check all your fuses and relays could also be a short in a wire somewhere.
Feb 20, 2013 | 2003 Nissan Primera
I replaced the battery on my 2002 Honda Accord. After turning on radio, the radio display read "COdE". I entered the 5-digit code from the Anti-Theft ID card. Radio display said "Err1"....
Hello you will need to visit the dealer to retrieve the unlock code for this problem your having removal of the battery has cause this to lock.Dealer usually charges $15-$20.00 for the unlock code this is the best solution.
Jan 04, 2011 | 2002 Honda Accord
I lost my nissan primera 1996 radio code
just take it in to your local nissan dealer - they will look it up for you
Jan 30, 2010 | 1996 Nissan Sentra
On my Nissan Primera sve 2002 the display screen does not work
The most likely cause of most problems electrics on that model is the poor earth connection on the rear light cluster. There is a simple fix which you can find on the nissan primera owners club website. www.npoc.co.uk. The fix is easy to do and involves putting another earth from the rear cluster to the bodywork where there is an existing bolt. It solved my issues.
Sep 06, 2009 | Nissan 200SX Cars & Trucks
Nissan (NATS) immovilizer 4 PIN code needed for a NIssan Sentra
hi ,i need a pin code to nats...
vin :SJNBFAP11U0594153
NISSAN PRIMERA 2001 1.6
Please Help..
Aug 07, 2009 | Vehicle Parts & Accessories
How do i reset service light on my 55 reg nissan primera
turn ignition to position 2 turn off radio push and hold info button whilst turning volume button on radio a new menu will appear on screen go into confirmation adjustments then go into service and reset
Feb 24, 2009 | 2003 Nissan Murano
2002 Altima Factory Bose Audio ERR3
there are only couple options. pull radio and send to shop for repair, purchase used radio from good junk yard. or call dealer and see if there is a warranty on it. even though its 6 yrs old they may help. what they do at the dealer is an exchange
Nov 16, 2008 | 2002 Nissan Altima
Car Audio & Video Logo
3,876 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Marvin
Marvin
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
