Hi,I own copier Nashuatec 3722 td, I note that the error code is: E1 - 43 ... what's the problem? thk
    New Friend:
  • 9 Answers
Sir my photocopy machine naushates manual model 3722td show an error E-4 on screen how i solve it
Posted on Jun 13, 2019
SOURCE:
nyakpoyawo
SOURCE: Hi, my Nashuatec D420
quel est son code d'annulation
Posted on Nov 10, 2012
  • 990 Answers
SOURCE: funcional problem code SC542
Hello sir; Follow the steps to reset;
1, press "clear mode", "107", then press and hold "clear/stop" key untill display change.
2, enter 5810, then press "execute" on screen, then press "close".
3, turn power off then back on, it will go back to normal.
Posted on Apr 28, 2009
  • 1316 Answers
SOURCE: COPIER MACHINE NASHUATEC 3715+ DISPLAY ERROR CODE
The malafunction is in the fusing unit.Cleam the fusing thermistors,thermofuses and make a copy.
Posted on May 08, 2010
SOURCE: error code
You're right, it cross references to a "Ricoh FT4727". You need to press the "." key to read the last 2 digits, however "1xx" codes all relate to the optics section: For example, exposure lamp, scanner motor, lens, etc. You'll need a technician to fix this one.
Posted on Mar 28, 2009
  • 32 Answers
SOURCE: copier code error
service program sp-9, mode 90 needs to be set to "0"(off). also, the key counter shorting connector must be removed.
that should disable any key counters.
Posted on Apr 02, 2009
Error code c 3722
Fusing high temperature abnormality.Turn OFF the copier.Press and keep pressed the Utility key and turn ON the machine.Keep pressed the Utility key and wait the Trouble reset message is displayed.Touch the message ,turn OFF wait 1 minute and turn ON.
Jul 31, 2014 | Konica Minolta bizhub Office Equipment &...
Nashuatec 3732 td gives code 42
that mean thermestor is defective must be changed that due to high temprature thus it's corrupted
Feb 24, 2011 | Ricoh FT5832 Copier
Sorry i have cleaned my nashuatec but the error sc 390 is still shown but i dont know where is TD sencor locted can ou help mewith that please
llajajlajjajlook my friend td sensor is located in under tank devolper yo will see it but yo this disput belong to acount of devolper mesure it and check bias and high voltage board
Feb 03, 2011 | Ricoh Aficio 450e Black and White Copier
Oct 07, 2010 | Office Equipment & Supplies
How to clear error code,sc542 nashuatec photocopier-mp6500
01. Press Clear/Stop Key (Yellow key) 2 tram
02. type 107
03. press Hold down Clear key 5 secend ( Red key)
04. type 5 and press # or Ok
05. type 810 and Press # of Ok
then machine Of and On
Jan 14, 2010 | Ricoh 6513 Copier
Copier code error
Mar 29, 2009 | Ricoh Office Equipment & Supplies
Error
I do not recognize either of these codes (187 or 387) as part of the Aficio 2015 error list.
If the code is displayed on the screen, physically TURN OFF the copier with the main switch (red switch), wait 10 seconds and turn it back on. If it's an erroneous error, this should reset the error code. NOTE: THE ERROR CODE MUST BE DISPLAYED FOR THIS TO WORK.
Jul 08, 2008 | Ricoh Aficio 2015 Copier
266 people viewed this question
k24674
Marvin
Marvin
