Question about Mitsubishi WD-Y57 57" Projection HDTV
I have a mistubishi WD-Y57. I replace lamp 7 month ago, and now my tv doesn't work. I have sound but no picture. I took off the plastic grill from the back of the tv to see what it was doing when I tried to power it on. I see the fan turn on and see the light trying to cut on. It flickers light. It try two times before shutting down. If I see light flicking, does that mean the lamp isn't the problem? I tried to read the code light by holding those two buttons in front of the tv. But am not sure how to count it. It seem like it blinks 6 time each cycle. What is my issue?
    New Friend:
    Problem Solver:
  • 11 Answers
WOULD YOU LIKE TO SELL IT ..LET MY NO LEE
Posted on May 04, 2011
  • 5 more comments
  • clonetechnol May 04, 2011
    How much you want to spend?
  • lee chamber May 04, 2011
    wot was you thinking???might be able to repair it then might..im takeing a risk..
    if i was you id cut my lossers might cost £150 to repair ,do you mind if i asked wot you paid for it, and look at the end result could cost you a small fortune..but i can fix it it needs an fan cause its shorting out,the lights are comeing on twice because theres a short happing..and iv a good idea wots causeing it ,but it not be a cheap job..regards Lee
    give me some ideia as its not working???
    £90.00
    were abouts are you???you tell me wot you want..it will need a lot of work..so wots your bear minium..straight up..
    mine cost me £30.00 not working at all...
SOURCE:
Screen stays black, have sound no picture
Hello:
From the sounds of things, you might have a defective lamp. Feel free to give us a call at 866-764-5822 or email us at sales@dlplampsource.com and we would be happy to help you troubleshoot your problem.
Best Regards
Dan
DLP Lamps Projector Lamps Specialty Lighting
Apr 06, 2014 | Mitsubishi WD-Y57 57" Projection HDTV
I have a 65" Mistubishi WD - 65734 and have no
Yes,"LAMP" LED light indication front of tv bazel frame is on or blinking,yes mean tv projection lamp life are over.The whole tv warrenty only for a year,tv projection lamp should last at leat 1 1/2 or 2 years,by tv been on and watches used it like 4 or 5 hours daily?U never done tv replacement parts,any kinds before?Yes,hire a tv Tech. to do it.Shop around for a Tv tech.should replaced the projection lamp for u shoud be around $250 to $300 that including part the projection lamp.
Jan 03, 2011 | Mitsubishi WD-65734 65" HDTV
My tv has no picture but has sound whats wrong?
Steady scrapping sound like a bad bearing is color wheel gone bad. Buzzing sound every 15 seconds is lamp bad.
Apr 18, 2010 | Mitsubishi WD-Y57 57" Projection HDTV
I have Mitsubishi WD-Y57 DLP. Replaced lamp and now green timer comes on for a minute or so and then turns off. TV will not come on?? HELP!
I have the same TV. Mine is almost 3 years old. From what I've learned you should try to reset the TV. There is a small button in the front input compartment. Use a pen to push that in and wait for the green light to stop blinking. Then try the TV.
If that does not work you probably need a new lamp. Apparently the lamps only last for a couple years on average. Having to replace them can really add to the cost of buying/owning one of these TV's
Nov 21, 2009 | Mitsubishi WD-Y57 57" Projection HDTV
No picture with sound
yes , u need a new lamp shop around , cost less
May 08, 2009 | Mitsubishi WD-Y57 57" Projection HDTV
Mitsubishi WD-Y57 57" Projection HDTV Logo
192 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
