I have a hoover elite 1210 washer. A wonderful washer , had no problems but the lid has discoloured. Wondering if i can obtain a new lid?
    Brigadier General:
  • 6,277 Answers
Spares Suppliers
You will need to type into your search engine/web browser '(make model number) washer spares' and you should be presented with a number of sources from which you can order. Alternately you could try telephone directories for spares suppliers but I would think the former would be more successful.
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C.
Posted on Jun 06, 2011
SOURCE:
My Hoover elite 920 goes through it's cycle put
the pump is bad. not worth the repair bill. get a new washer
Nov 03, 2011 | Hoover Washing Machines
Hi there, i have a hoover elite 1220 i think 7.5kgs i brought it second hand of ebay and it has been a good machine but it has started to play up lately. It washes all on the normal cycles and stuff i...
Following will be the causes for water not draining properly
1.There is a motor/Pump which operates to to drain the water check whether that motor is working.
2.Check filter and clean it
3.Check the drain pipeline whether it clear
4.Check the inlet valve of the machine Sometimes the drain works properly but the inlet solenoid valve will not hold and the water keeps coming in and fills the drum
Thank You
Sep 02, 2010 | Hoover HTC243 Top Load Washer
Hi i was wondering if you help.my hoover hd vision
my hover washer dryer 1200 spin will not spin water comes into the drum and will not spin
May 12, 2010 | Hoover H160E Front Load Washer
Hoover elite 1210 won't progress to the final 'spray and spin dry cycle'.
Hoping to be of help after the spin dry wouldnt work on our hoover elite 1210.
It would do the wash cycle fine but as soon as it needed to drain, it wouldn't.
My handy man (Husband) is great at fixing things and opened the front panel by undoing the screws.
Near the motor on the bottom left, there is a wheel/fan looking thing.
(Turn the machine off first)
He tried to spin the wheel but it would only move clockwise and not anti-clockwise like it is supposed to.
So he gave the fan a few spins clockwise before giving it a gentle pull outwards in which it loosened the wheel and was able to move anticlockwise again.
We then turned the machine on and it started spinning and draining the machine.
This machine is a work horse and I refuse to get another. They don't make them like they used to!!
Mine has a leak and we use a drip tray underneath at the moment. So long as it works. I am happy.
Hope this helps someone else with the same problem.
Sep 21, 2008 | Hoover Washing Machines
Kenmore elite he (5t)
You can wash Shoes in it... But the manufacturer does not recomened it.. I would suggest that you remove the laces and you should be just fine
good luck
May 27, 2008 | Kenmore Elite 45986 Front Load Washer
Hoover Elite 1205 washing machine
Does an Hoover elite 920 gearbox fit the hoover elite 1205 thanks
Sep 18, 2007 | Washing Machines
My washer doesn't open...
The instruction manual suggests running the "drain & spin" cycle, because there is most likely water left in the machine.
Dec 15, 2006 | Kenmore Elite 45986 Front Load Washer
Washing Machines Logo
57 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
Marvin
Marvin
