Question about Dell PowerConnect 3548
Got a second hand dell powerconnect 3548. I can use it as a standalone switch with nothing else configure on it. Lights & booting seems normal. However, when I want to configure it thru console port using hyper-terminal 9600 8 1 NO flow control on XP machine using a DB9 female (both ends) cable , nothing else display on the hyper-term & even no response on keyboard. Is there any alternatives to configure this switch???? Any other serial cables or any (serial to usb adapters) can be used on this switch ??? Ps Help ??
    Dedicated:
    Visited the website for 20 consecutive days.
  • Dell Master
  • 278 Answers
SOURCE:
jeff_olymp24
  • 84 Answers
SOURCE: Problem with a dell computer..
You may try connecting a different usb keyboard to your system. Mostly, some keyboard converted from serial connection to a usb could cause this kind of problem. In some cases also, wireless keyboard and mouse won't work when u turned on your system if the driver is not properly install.
You may also try disconnecting any other usb devices from your computer. Disconnect also your power supply then push and hold the power button for 5 seconds. Plug back in the power cord then connect your keyboard. Turn on your computer. if it doesn't work, i suggest to call your computer manufacturer and check your warranty. This could be an issue with the motherboard of your computer.
Keep me posted.
Thanks.
Jeff
Posted on Oct 12, 2008
  • 166 Answers
SOURCE: OnBoard USB ports (both front and back) will not recognize any devices
When you reloaded the OS did you reload all the drivers? Sometimes if you do not reinstall the Intel driver the USB port will not be recognized. Happened on the last two DELL's I reloaded. Go to DELL's website and download all the drivers for your model.
Dell support website http://support.dell.com/support/downloads/
Look up your model by service tag, it is the alphanumeric code on the barcode label on the back of your DELL and also sometimes found on either the front or top of your DELL (sometimes it is hidden beneath the USB port cover that you flip up.
Try that and see if it fixes it. Also make sure that the connector did not come loose when you opened the case.
Posted on Apr 30, 2009
SOURCE: USB Keyboard and mouse wont work with PS2 KVM with adapter
Don't use USB-PS2 adapters if the keyboard/mouse doesn't support such adapters. They aren't universal, they work only with some "smart" (or chinese) keyboards that can detect the connection type and switch between USB and PS/2.
Posted on Nov 03, 2009
SOURCE: Dell Optiplex gx260 Keyboard Does Not
Under BIOS setup, turn USB Emulation on. I had the same problem. Turning the USB Emulation on fixed my problem.
Posted on Dec 17, 2009
AmerIHCan
  • 14 Answers
SOURCE: Dell PowerEdge 2900...USB Keyboard and USB mouse
Is it possible this is where the problem started? When updating the controller...
http://support.microsoft.com/kb/906690
I was going to suggest opening event viewer either through Administrative Tools or bye typing eventvwr in the Run dialogue box. You will see one column on the left and one on the right. The one on the right shows errors and performed operations alike, when you click on an area in the left column.
You'll see an "Event" tab if you scroll to the right after clicking on "System" in the left. Any red Xs mean error. Double click or right click & select "Properties" to read the error. Highlight and type Ctrl+C to copy the text in the Description area and search Google for an answer, careful where you click, reading the address for the location of the site, looking primarily for the support.microsoft.com website for solutions.
Go to the keyboard & mouse manufacturer's website and download any new drivers. You might also find legitimate drivers on the Dell site for the Host controller, USB controller & mouse/keyboard. Make sure they're for your system/model/components. Reboot if asked and allow divers to install.
My vote...
You can then/also try uninstalling the Keyboard & mouse drivers and rebooting to safe mode, then uninstall the Controllers themselves. Reinstall on reboot to normal Windows and try using only certified drivers... or drivers that came with the mouse/keyboard or that you downloaded as instructed earlier.
Uninstalling and then reinstalling iIMHO is the best method rather than updating. Sometimes drivers overwrite and become corrupt.
Try to only stick with microsoft & Dell (your manufacturer) for driver updates. Programs that connect to sites and download new drivers for your system often install incorrect updates. Even if your system has a say, Toshiba AB-01234-YX, the driver for the component might not be written the exact same way Dell/the computer manufacturer has written it. You also do not know the programmer and cannot honestly say you can trust them when installing and asked "are you sure" if it is not digitally signed.
HTH.
Posted on Apr 23, 2010
How do i configure the switch to allow web access through the serial port
If you can't find the manual on the Dell web site, there is a copy at: http://www.manualowl.com/m/Dell/PowerConnect-3548/Manual/188907
Did you use the command: ip http server ? See page 501 in the manual.
I would not recommend setting up a network switch with password-free access to the internet. You should at the very least limit access to a small subset of IP addresses (e.g. your network group's machines). The best practice is to use ssh communications or https with the web browser, otherwise anyone with a well-placed sniffer can read your clear-text traffic.
Sep 19, 2012 | Dell PowerConnect 3548
I have a Dell router(?) 2224. I want to go wireless in the house. Can I use this piece of equipment somehow or do I need to buy a real wireless router. Also att says i have to buy a motorola wi-fi...
if you product in the picture Dell PowerConnect 2224 that's a switch. att gives you a modem which you connect to router (wired or wireless) any brand you don't need theirs. then connect to switch (for wired connections) your will have to configure the router they might not help if you don't buy theirs
Feb 26, 2018 | Dell PowerConnect 2224 (0M4575)
How do I get into a terminal session on a dell power connect 2124 switch?
Hello Jlhambric.
The Dell PowerConnect 2124 is an unmanaged switch. Plug and play with no interface.
Feb 25, 2011 | Dell PowerConnect 2124 Networking Switch
Dell powerconnect 2016 seems to have stopped working
most likly a failed power supply on the switch
look at the front of the switch look for leds,.......
if you see nothing and the power cable is plugged into a hot outlet than
go down to your neerest comp store and buy a new one
Apr 26, 2010 | Dell PowerConnect 2016 (pct2016)...
Problem Dell PowerConnect 6248
go to the web interface and disble storm control and flow control
Dec 08, 2009 | Computers & Internet
Seems to have lost the existing firmware and will
you need to interupt the boot process, by using a console cable and interupt boot. Then do a serial download of a new image.
Oct 26, 2009 | Cisco Catalyst 3548XL Enterprise Edition...
Static ip address to dell powerconnect switchport for backbone
try for 195.9.200.00 - 195.9.200.32 series hope it will works
Mar 23, 2009 | Dell PowerConnect 6024F (p624fnp)...
Performance Issue
thats not a big diffrence if you use a 24 port switch or if you use 48 port switch actually switch is used to a number of connection not for a internet speed that is use for a networking if you want to upgrade your configuration then you upgrade your ram and our hard dives configuration
Dec 19, 2008 | Dell PowerConnect 2224 (0M4575)
Dell Powerconnect 2016 All leds are on, solid no blinking.
Had same problem with my Dell Pwoerconnect 2016, power it on and all LEDs light up but nothing works.
The problem was traced to one or both output capacitors ( 10v 680uf ) on the ( tiny ) power supply.
Capacitor symptoms include bulging or rounded tops instead of flat like new one and the rubber plug in base of capacitor protruding.
Capacitors need to be replaced.
I have successfully replaced with 10v 1000uf and 10v 1200uf, both Rubycon and Sanyo brands.
Power to the switch board is now restored and the switch is able to function just fine.
Give it a go and see if it works for your Powerconnect.
BigAl
Jan 24, 2008 | Dell PowerConnect 2016 (pct2016)...
Open Questions:
See all Dell PowerConnect 3548 Questions
Dell PowerConnect 3548 Logo
141 people viewed this question
Ekse
Clive
Clive
