Question about Garden
My lawn tractor pulls to the right when driving can i fix this?
    President:
  • 1,545 Answers
The Toe In/Toe Out will have to be adjusted (if the steering rods to each front wheel have sleeves), just like on a car.
Toe-in is the operating angle of front wheels on a riding tractor. If the front edge of the wheels point inward, towards each other, then the wheels have toe-in. If the front wheels point outward, the unit has toe-out (or negative toe-in). Adjustment of toe-in is necessary to maintain proper steering control.
Unlike automobiles, our tractors have pre-set camber and caster settings. Therefore no camber or caster adjustment is necessary.
Acceptable toe-in adjustment range for all of our lawn & garden tractors is anywhere between 1/16"-5/16". With 1/8" serving as the optimal range.
Detailed toe-in adjustment procedures for the various models of tractors are reviewed in the "Adjustments" section of the Operators Manual for the tractor.
If tires are not toed-in properly after adjustment, it is likely that other part(s) need service or adjustment. axles, wheel bushings, control arms and other steering components may be worn or damaged and will need inspection. Service these items as needed.
You haven't stated your make and model, so I can't send you the manual with the exact procedure for your machine.
Posted on Jun 12, 2011
  • 32 Answers
SOURCE: Craftsman lawn tractor mower,
The belt is probably slipping because it is not tight enough. look by the belt, inside there is a little spring, you may half to tighten it.
Posted on Jun 13, 2009
  • 95 Answers
SOURCE: Loss on drive on Poulan Lawn Tractor
Check to make sure the belt is not broken or did not come off the transaxle pulley, you can check by removing battery from under seat and pulling battery box out to examine top of transaxle,Pay close attention to the wire belt guide on the rh side of the transaxle pulley it should be close to the backside of the belt after it is reinstalled.If you recently may have removed the rear tire make sure the square key on the axle didn't drop out.Is the tractor a hydrostat drive? If so make sure brake is not stuck on,if it was it would make a grinding noise.
Posted on Jul 30, 2009
  • 95 Answers
SOURCE: I have a 20 hp craftsman lawn( hydro gear
It sounds like the oil in transaxle is degraded.The transaxle is supposed to be a sealed unit requiring no service but over time the oil will get dirty enough to cause problems like you are describing.Remove the back hitch plate and look at the transaxle it will have a rubber vent hose or a 1/4 alllen wrench fitting on top. You will need to purchase a battery suction bulb from sears automotive and use it to remove as much oil from transaxle as possible. Warm the transaxle up first by running it around,then suction the oil out.Refill with a good synthetic motor oil 15w-50 or 20w-50 like Amsoil or Mobil 1.Do not use transmission fluid or hydraulic fluid. When adding the new oil back fill it to within 1.5 in from the top,be sure to allow this amount of air space in top of transaxle for expansion.
Posted on Jul 31, 2009
canbruce75
  • 1776 Answers
SOURCE: need to know how to replace drive belt lawn tractor
Check out the video at the link that I am providing and see if it helps you with the drive belt replacement. Sure hope so and best wishes.
http://www.youtube.com/watch?v=YIRUAMSjGfg
Posted on Aug 31, 2009
SOURCE: Loss of drive in a Craftsman Lawn tractor
I also have a Craftsman tractor with the same problem. Sears repairman said it needed a new transmission and it would cost $1,400 to install. A new one is about $1,000. Anyway, if you remove the battery and the battery tray under the seat it will expose the transmission fill hole (hex). I opened the top and it looked empty. I had a bottle of 90 weight gear oil in my shop and filled the transmission to the top. I have not had any problems with it since. $4.00 bottle of oil verses a new tractor is worth a try.
Posted on Nov 30, 2009
I need help putting rear end back together on a 10 hp30 Murray riding lawnmower
Safety and Preparation Serious injury can occur if the engine or mower blades accidentally start while you are working with lawn tractors. To prevent this, drive the Murray lawn tractor onto a flat work surface and disengage the mowing deck cutting blades. Engage the parking brake to keep the mower from moving; chock the wheels with a wooden block or brick. Adjust the mowing deck to the lowest position. Turn off the engine and remove the key from the ignition. While not necessary, you may even wish to disconnect the spark plug wire from the spark plug. Mowing Deck Removal You must remove the mowing deck on a Murray lawn tractor to gain access to the belts. Remove the adjustment rod hairpins, followed by the adjustment rod pins from the front left and right sides of the mowing deck. At the rear on the left and right sides, pull out the retaining hairpins and slide the mowing deck suspension links from the adjuster plates to separate the rear mowing deck from the frame. Remove the blade control rod stud, including the hairpin and washer, from the top of the blade control lever shift linkage at the left rear of the deck. Remove the front hanger rod, including the hairpin and flat washer that hold the rod in place. Loosen the belt guide retaining bolts with a socket wrench and remove the engine stack pulley belt so you can slide the mower deck out from under the tractor Transmission Drive Belt Installation Slide the new transmission drive belt between the engine stack pulley belt guides, over the belt guide plate and under the engine stack pulley. Fit the transmission drive belt around the top engine stack pulley. Push the free end of the transmission drive belt up through the transmission shifter hole in the lawn tractor floorboard. Slip the transmission drive belt loop over the transmission shifter. Pull the transmission drive belt down through the transmission shifter hole. Fit the transmission drive belt around the transmission drive pulley and tighten the transmission drive pulley belt guide retaining bolts to hold it in place. Fit the transmission drive belt flat side around the idler pulley. Slide the idler pulley onto the idler pulley stud while holding the belt in place. Tighten the transmission idler pulley retaining nut with a socket wrench to secure the idler pulley to the idler pulley stud. Mowing Deck Drive Belt Installation Pull back on the right side mowing deck mandrel pulley spring-tensioned belt retainer. Guide the new mowing deck drive belt around the right side mandrel pulley and release the belt retainer. Pull the drive belt spring-tensioned retainer away from the mowing deck idler pulley, guiding the deck drive belt around the idler pulley. Fit the mowing deck drive belt around the left side mandrel pulley and under the rear mowing deck cross link rod between the right and left side mandrel pulley. Slide the mowing deck under the right side lawn tractor frame, reconnecting the deck to the frame in reverse order of removal. Engage and disengage the mower deck while driving the mower to test the belt for proper operation.
Sep 28, 2016 | Murray Garden
Craftsman 56" lawn tractor auto trans dose not drive forward or revers. tryed purging trans no go checked engagment rod ok, belt seems good. I can push the mower by hand as if the trans were not connected...
somehow did the little freewheel lever get pulled in the rear of the tractor to disengage transmission?..usually out is disengage and in is engaged. look around the back panel behind the rear axle for a small lever you can pull or push in.
Aug 18, 2013 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
Husqvarn lgt2654 wont pull
Make sure the drive belt is routed right. Go to partstree.com click on
husqvarna and put in your model number and click on the drive scematic and it will show the routing of the belt.
Jun 23, 2012 | Husqvarna Lawn Tractor - 54in. Deck, 26...
Why wont my lawn mower move?
is the belt on right?is the release lever pulled out that allows you to **** the unit when its not running?
Apr 07, 2012 | John Deere 420,1020,2010,2020,2510,2520...
Lawn tractor does not move repl. both belts pull
What brand of mower? You most likely have a broken return spring on the drive system.
Apr 11, 2011 | Craftsman 20 Hp 42" Deck Lawn Tractor
Lawn tractor forward movement problem
Check the adjustment from the lever to the transaxle, if the linkage is ok the transaxle may be suffering from age and has leaking internal seals.
Jun 03, 2010 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Steering has let go on my craftsman 17.5 lawn tractor
take it in it should be fixxed & ask them if its covered under warrenty
Jun 07, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Garden Logo
769 people viewed this question
Top Garden Experts
roeb
john h
Marvin
Marvin
