Question about Xantrex Technology Heart Freedom 20 12 Inverter
Our trace legend series 1 model L 1512 inverter/ charger overcharges our coach batteries in our 2000 Monaco Diplomat . Any suggestions?
    Master:
  • 574 Answers
Is the inverter configured for correct type of batteries? Did inverter come with temperature sensor what should be connected to battery to prevent overheating? Are batteries in good condition, acid level, clean posts etc?
Posted on Sep 02, 2019
5 Suggested Answers
6ya staff
SOURCE:
nitrospawn
Ibe Chukwudi
  • 290 Answers
SOURCE: HEART 25 INVERTER
if the charger will not charge the batteries, it means the charger is bad or the fuse for the charger is broken
Posted on Feb 27, 2010
Anonymous
SOURCE: Xantrex Freedom 458 Combi inverter/charger 2000 watt
OK my 2000 Discovery does the same thing. Try and hit the inverter charger with your fist 3-4 times, then listen and see if the charger fan starts up. I will be bringing my inverter to Portland this week to have the tech look at it. The other thing is it could be the transfer switch. Will let you know.
Posted on Sep 08, 2009
Anonymous
SOURCE: overcharging batteries on freedom 20 inverter charger
Go to the Xantrex website and run through the support section. Then look up the closest service center.
mwoodring1
mark woodring
  • 496 Answers
SOURCE: I have a xantrex 2000 watt freedom 458 freedom
this isn't an answer but i would like to just clear the water a little. how old is the unit? you say it the inverter works when on shore power ( 110v A.C. wall plug or 220 ) but it will not charge the batteries while hooked up to shore power? are you trying to use a generator to run the inverter and charge the batteries? I just need to a little more so i can better understand you problem and help you better
Looking forward to hearing back from you.
M.Woodring
Posted on Jun 21, 2011
My coach battery isn't transferring voltage to the coach.It has a TS30 Power switch and an inverter. It is a Class C 1999 Jayco Eagle. Any suggestions? Thanks in advance!!
Check the fuse panels. If you are not hearing the "clunk" when you cycle the power switch on and off then it's probably a blown 10A fuse for the battery power solenoids.
Feb 25, 2015 | RVs
I need a Control Board for my TR2424.
why do you need control aboard where are you fitting it and to what i have one on my coach its wired straight from my batteries
Nov 18, 2014 | Xantrex Trace Series TR2424-120-60...
Trace, no power from line one from either gen set or shore power. Have rebooted, and when I invert the coach works normal. Charge system to house and coach batts perfec
If a normal install, the shore power and generator will go through a transfer switch then to the inverter. If when inverting 120 VAC circuits are OK, then the problem must be before the inverter. I would suspect that it is the transfer switch.
Disconnect shore power, make sure generator in NOT running then take a look at the transfer switch these are in a boat or RV but either can lead to vibration problems which can lead to loosening wire connections which can lead to heating and burning. It may be something as simple as a wire coming loose. (Which could be dangerous!)
Whether or not the contacts in the relays are OK, check and/or tighten all electrical connections. It's a good idea to check and tighten all electrical connections regularly.
Some transfer switches can be repaired by replacing just the relays. Other units (like mine this year!) will need to be replaced entirely.
Nov 11, 2013 | Xantrex Technology Trace Series Inverter /...
Inverting side working fine but charger is not
I had a similar problem at work yesterday.when your charger switches of it assumes that the battery is fully charged, while it is not.this is the solution , switch on you inverter machine and allow it to run, while it is running use a direct current "dc" multi meter a test the voltages of the batteries any one that drops like 3 volts below the normal voltage is bad. Change it and you will notice that the problem will stop. Note that when a battery is bad it takes little time to get it charged than when it is in a good condition .
May 26, 2010 | Xantrex Technology Xantrex Trace Series...
I have a trace inverter DR 1512, I am having a problem with my system, which includes a 5000 watt gen, and solar power. When I am dry docked and have solar, system functions fine, when I lose solar and go...
the solar panel is just to charge your inverter,if it is charging and the inverter is on it will drain the current the solar panel is supplying to the batteries,this makes it look like it is not charging ,so i advice you to switch off you inverter when charging it,get another set of batteries connected to your solar panel then charge both, let them be separated so that the new one is not in use so that when solar is out you can switch to the other set of batteries
Nov 25, 2009 | Xantrex Technology Trace Series Inverter /...
Overcharging batteries on freedom 20 inverter charger
Aug 15, 2009 | Xantrex Technology Heart Freedom 20 12...
My tram 2512 is stuck in waiting for AC mode, ac is clearly reaching the unit, both by shore power and genset. What could the problem be?
If you are referring to a Trace 2412 inverter, which series is it? An SW or a DR series? In either case, if it won't accept generator power, but the AC input indicator is flashing, the problem is most likely the generator output power is off frequency or voltage. Trace inverters will only connect when the AC input is within certain limits. I'd suggest checking the frequency and voltage output of the generator. If it won't connect to shore power, check the voltage from that source. Make the voltage checks at the inverter input terminals.
May 11, 2009 | Xantrex Technology Trace Series Inverter /...
HEART 25 INVERTER
Mar 18, 2009 | Xantrex Technology Heart Freedom 25...
I have a motor home with a Trace inverter/charger. When the unit is connected to shore power the system will recarge the battery pack fine. When they are charged the remote meter will switch from bulk...
More than likely you may a a relay that is stuck or not energizing which should switch the charging mode over automatically. Trace back from the generator to the charging circuit for the batteries. I'm not sure where the relay (or solinoid) would be located but you can be assured it is something in the charger sensing/switching circuit.
Good Luck! Gary
Mar 12, 2009 | Xantrex Technology Trace Series Inverter /...
Xantrex Technology Heart Freedom 20 12 Inverter Logo
509 people viewed this question
Top Xantrex Technology Boating Experts
vince
ray gallant
ray gallant
Are you a Xantrex Technology Boating Expert? Answer questions, earn points and help others
