Question about Mitsubishi WD-Y57 57" Projection HDTV
I have Mitsubishi WDY57. When I turn on the tv it says "TV will shut down in a few seconds. Please check if the air flow is blocked" TV then shuts off. Any suggestions?
    New Friend:
Susie, try removing the lamp assembly, and blowing out the ventilated area on the lamp assembly housing. i had this issue on my wd-y57 recently and that solved it.(mine was really packed with dust...) i made sure to hold in the system reset button after doing this (located in the controls panel on the front of the tv) but not sure if that is necessary.
Posted on Jul 16, 2011
  • guessartist Jul 16, 2011
    if that does not resolve the issue, you may have a bad thermal sensor (from what i have been reading on this tv, its not uncommon) if this is the case i recommend a qualified technician to repair the issue.
SOURCE:
TV will shut down in a few seconds. Please check if the air flow is blocked, and then the TV shuts off.
We had that problem for the first year we had the TV. When looking for a new bulb I had found on the mitsubishi site that there was a problem with the sensor and for a certain amount of time they would fix it. Of course we were beyond that time, but hubby was able to do something where we split the cost. No problem since and haven't vacuumed it once. It has been at least a couple years now.
Sep 04, 2011 | Mitsubishi WD-57732 Projection Television
"TV will shut-down in afew seconds. Please check
Thia is a indication that the unit is overheating. Now the causes of this can be a cople things... the fan may have slowed or may be cloged.. In the past there have been instances were a faulty temperture sensor or thermal switch might cause this. I have replace many of these sensors at the shop. Mitsubishi has issued service bulletens on this problem. THere not difficult to get replace and are about 75 dollars to replace(at our shop)
Mar 06, 2011 | Mitsubishi WD-52525 52" Rear Projection...
Area around TV is clear, nothing is blocking TV or air flow. When we use the TV we frequently get this message: The TV will shut off in one minute. Check to see if air flow is blocked. Happening more...
you need a new power supply unit these after some time get old and start over heating causing the tv to heat up intermediately if you take it to a repair shop and have that replaced it will be like new again
Feb 25, 2011 | Mitsubishi WD-52525 52" Rear Projection...
My tv monitor says "TV
YOU NEED TO REPLACE THE THERMOSTAT ON YOUR SET TO CORRECT THIS ISSUE .
Dec 14, 2010 | Mitsubishi WD-57732 Projection Television
Error / problem message
these are on mitsubishi's recall list you need to get in touch with mitsubishi and have them find a authorized servicer in your area to come put a thermal sensor in your set.
Aug 12, 2009 | Mitsubishi WD-57732 Projection Television
Air flow blocked...turning off in a few seconds message
"air flow blocked" means its getting too hot. or it thinks it is. it is quit common on these set that the thermal sensor has malfunction replaceing this sensor is your solution. since this is service bulliteen item at service centers of mitsubidshi products this may be an item covered under warrenty. so i would first check with you local service shop too see before
Jun 04, 2009 | Mitsubishi WD-65731 65" HDTV
52' DLP Mitsubishi HD T.V. gets an error message on the bottom of the screen ''T.V. will shut down. Check that air flow is not blocked'' T.V. is in the open and air flow is not blocked. There is also a...
most rear projectors will turn themselves off whenever the lamp is dead. what we call protective mode. in this case the yellow light may be for the lamp. otherwise check if all the fan are working properly.
But MAKE SURE you let sufficient time for the tv to cool off before unplugging the main.
hope this helps
please rate me!
Mar 19, 2009 | Mitsubishi WD-52525 52" Rear Projection...
Mitsubishi wd 52525 dlp shuts down
mitsubish has issued a service bullietin about the problem. which means ussally they will pay for its repair. the reson it says airflow bock is that there is a temperture sensor that is at fault... it needs replaced.
Dec 13, 2007 | Mitsubishi WD-52525 52" Rear Projection...
Mitsubishi WD-Y57 57" Projection HDTV Logo
214 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
