Question about Amazon Kindle 2
My kindle won't wake up when i slide the power switch. help!
  • 1 more comment
  • hgbiker44 Jun 29, 2011
    It worked! THANK YOU!
  • Jas Barinaga
    Jas Barinaga Jun 03, 2012
    You're welcome!
  • Nadia Gato Epouse Loiseau
    bonjour
    pouvez vous me donner un manuel en FRANCAIS pour la machine janome quilter's companion
    merci
    loiseau.nadia@hotmail.fr
  • 844 Answers
Welcome to FixYa.
1. Make sure that your Kindle is charged properly.
2. Unplug it from the power source if it is plugged in.
3. Slide and hold the Power switch for 15 secs. then release.
4. Note that the Kindle screen will go blank for about 30 secs. while it restarts.
Thank you for using Fixya. Have a great day.
Posted on Jun 29, 2011
6ya staff
SOURCE:
My Kindle will not wake up when I slide and release my button to wake it up. I hve had this Kindle for several years. Is it time to purchase a new one. Arthur
Hello
If that did not work, let's try to force a reboot. If you have a leather cover on it, remove it. The battery charging circuits are controlled by the software as well. If the software isn't allowing the Kindle to accept a proper charge, it may cause the Kindle to malfunction too. Plug the Kindle into the charger for 10 minutes. After 10 minutes and while still plugged in, slide or press and hold the switch for one minute. Make sure you don't disconnect the power during this entire process. Allow 3 minutes afterward for the Kindle to reboot. If this doesn't correct the problem, let me know the approximate purchase date of your Kindle.
For any help & support visit us: www Kindle Com Support
Jan 22, 2017 | Amazon Kindle
My kindle fire won;t let me turn pages or change any thing
Soft Reset:
  1. Hold the power switch for twenty seconds. You will need to slide the power switch along and hold it for twenty seconds before releasing it. ...
  2. Your reboot screen should appear when you release the power switch.
  3. Give your device time to reboot for a minute or two.
  4. Turn the Kindle Fire HD back on.
kindle fire Google Search
Nov 30, 2016 | Tablets & eReaders
Kindle will not shut off-goes to shut off or cancel but wont move. doesnt charge well-doesnt always hold charge
Patricia, Using the power switch, you can forcibly reset your Kindle device. This reset will shut down the Kindle without accessing the shutdown command from within the Kindle's operating system, a particularly useful tool when dealing with a frozen Kindle. To initiate a hard shutdown, Kindle disconnect from its charger, slide and hold the power switch for about 20 seconds. This will force the Kindle to shut down, now it can be restarted normally.
Check links below for charging problems.
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Reset Kindle Fire When it Won Turn on or Charge
Troubleshooting Kindle Fire That Won Charge
Kindle Fire not charging
9 common problems with the Kindle Fire HD and how to fix them
Feb 25, 2016 | Amazon Kindle Fire HD
It will not power up. was on the charger most of the day.
To wake up or turn on your Kindle, slide and release the power switch again. If your Kindle does not power on or is unresponsive during use, try resetting the device by disconnecting your Kindle from any power source, and then sliding and holding the power switch for 15 seconds before releasing.
Mar 22, 2015 | Amazon Kindle Fire HD 8.9"
Kindle does not charge.
perhaps the internal battery needs replaced
Jan 26, 2015 | Amazon Kindle Wireless Reading Device
My kindle won t turn on
Her is a possible solution:
1. Plug into the original charger, hold the power down for a full 30 seconds, release. Let charge in this state for 12 hours.
2. Lease the device plugged into the charger, while you have the device plugged into power, press the power button for a full 40 seconds, release. Wait for 5 seconds and then press and release the power button. Did the device wake up? No, continue to step 3.
3. Plug the device into another charger, if you do not have an charger from another phone go to Staples or Radio Shack pick up a new Kindle or Universal charger, make sure you can return the charger.
4. Plug the Kindle into the new or alternate charger. Hold down the power button for 30 seconds release. Let charge for 12 full hours.
5. Unplug the Kindle from the charger.
6. Press the power button for 40 seconds - time it. Release the power button, wait for 5 seconds, then press and release the power button. The Kindle should wake up. If not, proceed to step 7.
7. If you can not wake up the Kindle from a 'hard reset' the Contact Amazon directly for a replacement.
May 25, 2013 | Amazon Kindle Fire HD
Kindle light is orange when I charge but even after of hours of charging continuous efforts to turn on Kindle, it won't turn on.
Try to slide and hold the on switch until after the power light blinks three times (should happen after a little more than 5 seconds). Release the switch after the blinks and the Kindle should start up.
This is only necessary if the Kindle was switched off by the same method before, or if the battery was completely drained. A short nudge of the power switch merely puts it in and out of a power-saving sleep mode, the prolonged hold really cuts / reinstates power.
Jul 16, 2011 | Amazon Kindle Wireless Reading Device
My kindle does not to turn on when i slide the power switch
Make sure that the kindle is fully charged. Plug your kindle into the wall charger, a yellow light will light up. When the yellow light turns green, your kindle is fully charged. Then try turning on your device. If the device still does not turn on, hold the power switch for 15 seconds, this will reboot the device.
Jan 22, 2011 | Amazon Kindle 3G
Cannot wake up kindle even after sliding power switch
Try to slide and hold the power switch for about five seconds, until after the power LED behind the power switch blinks three times.
Dec 31, 2010 | Amazon Kindle Wireless Reading Device
Amazon Kindle 2 Logo
2,791 people viewed this question
Top Amazon Tablets & eReaders Experts
Norman Worley
Miguel Luiz Martins
Poul Brinchs Larsen
Are you an Amazon Tablet and eReader Expert? Answer questions, earn points and help others
