Question about Apple iPad 32 GB WiFi Tablet PC
How do I download photos from my laptop (Toshiba Satellite) to my ipad?
    New Friend:
To transfer photos from your Toshiba laptop to your iPad:
Step 1: Connect your iPad to your Toshiba laptop using the USB data cable that came with your iPad.
Download Install and run iTunes and select your iPad device from left panel under "Devices" section.
Step 2: Click on Photos tab, Check the "Sync Photos from" checkbox and select "Choose Folder..." option from drop-down menu. Locate the folder with the photos you want to transfer on your computer and hit "Select Folder" button.
Step 3: When folder listed in iTunes, select all pictures that you want to copy to your iPad and hit Sync/Apply button from bottom right corner.
Posted on Aug 09, 2011
  • Rahul Mehta
    Rahul Mehta Sep 05, 2011
    Note:-
    Above said is the right option, note that alway you shoud use the same folder other wise it will erase and sync.
    New Friend:
  • 6 Answers
1. Turn your PC and iPad on.
2. Connect your iPad with your PC.
3. Open iTunes and select "Photos" under iPad.
4. Click and drag the desired photos to your desktop and it will be transferred to your PC
More Resource: Transfer photos from PC to iPad
Posted on Apr 26, 2013
6ya staff
SOURCE:
Want to transfer some photos from acer laptop, Windows 10, to my wife's Apple iPad.....???
You will need iTunes.
Plug your device into the computer and then when it pops up the summary of your iPad in iTunes (it will show your serial number and back up information) you will click on photos on the the left side.
You will then select "sync Photos" on the right side and you will be allowed to select what photo folder on your computer that you want to sync to the iPad.
It will make your life easier if you create a folder on your desktop with all the photos you want to sync.
Also, any photo that is synced to the iPad from the computer will not be able to be deleted off of the iPad. They will stay on there until you unsync them from the iPad via iTunes.
May 30, 2017 | Apple Tablets & eReaders
After connecting my ipad air to computer, the itunes can't recognize it. what happend? i want to transfer photos to ipad. please help.
iTunes should sync your computer with your iPad but sometimes it acts funny. Don't know why, but it does. So if you cant get it to sync, try Copy Trans Manager. It is a FREE application and it should let to manage the content of your iPad without iTunes. Actually, it uses some files of iTunes as a drives. Be caredul with Softonic's downloader. Use custom mode, go for Copy Trans Mnager and uncheck or skip anything elese offered free.
Jul 08, 2015 | Apple iPad (16 GB) WiFi Tablet PC
Transfer photos from my PC to my ipad mini. I have tried iTunes but I don't understand it
Try downloading an app called Shareit.
When attached to the same WiFi, you can transfer Photos directly from iPad to iPad and even between Windows and Andriod devices. You start Shareit on both devices and send from one and receive on the other.
Feb 16, 2015 | Apple iPad Mini
How to delete photos from the Ipad
If to have the iPad before the camera was added, you have the original iPad. If you synced the photos from your computer, you have to delete the photos by syncing with iTunes again, but you have to "uncheck" the albums or folders that you want to remove.
1.Connect the iPad to the computer and launch iTunes.
2.Click on the iPad name on the left side under devices.
3.Click on the Photos Tab on the right.
4.Uncheck all of the albums or folders that you want to delete from the iPad under the Sync Photos from heading.
5.If you want to delete all of the photos - uncheck the Sync Photos From heading
6.Click on Apply in the lower right corner of iTunes
Done.
If it can't work, you can refer to the article about Delete photos from iPad.
Good Luck!
Jun 25, 2012 | Apple iPad (16 GB) WiFi Tablet PC
Transfere photo from laptop to apple ipad
To transfer photo from laptop to iPad, follow this steps.
1. In the iPad management screen, click the "Photos" tab at the top.
2. Check the "Sync Photos" box at the top.
3. From the drop-down menu next to that, select the program or folder that contains your photo library.
4. Once all your settings are correct, click the "Apply" button at the bottom right corner of the iTunes window to sync again and add photos to your iPad.
5. Photos will consume space on your iPad, so keep that in mind as you select between syncing all photos and individual albums and videos.
May 09, 2012 | Apple iPad (16 GB) WiFi Tablet PC
How do you restore an ipad
You can use This iPhone&iTunes Data recovery to Recover iPhone Contacts, Messages,Photos,Videos, Camera Roll, Photo Stream, Photo Library, Message Attachments, Call History, Calendar, Notes, Voice Memos, Reminders and Safari Bookmarks
For iPad: Free download iPad Data Recovery
For iPhone 5 Data Recover: Free downoad iPhone 5 Data Recovery
Free download iPhone 4S Data Recovery
Free downoad iTunes Data Recovery
YouTube Video Teaching Use guides:
Dec 02, 2011 | Apple iPad 64 GB 3G Tablet PC
How do I download my photos from my computer to my new iPad2 ?
Add any photos you want synced to your iTunes. Then connect your iPad and click on the iPad management tab when it opens in iTunes. There, go to the Photos tab and check the box to sync your photos.
Apr 07, 2011 | Apple iPad 64 GB 3G Tablet PC
I want to transfer my pics from my computer to my I Pad but doing it by Email is slow, is there a better way?
Follow the steps to transfer pics from your computer to your iPad:
Step 1: Connect your iPad to your computer using the USB data cable that came with your iPad.
Feb 17, 2011 | Apple iPad 64 GB 3G Tablet PC
The PC on which I had itunes that synced with my ipad is no longer available. I want to transfer the music on my ipad to a new PC (with itunes). How do I do this transfer?
You can use iPad to PC Transfer, which can help you transfer from iPad to PC. iPad to PC Transfer is a professional sofeware, which can help you transfer Music, Movie, Photo, ePub, PDF, Audiobook, Podcast and TV Show from iPad to PC or iTunes library.
Dec 20, 2010 | Apple iPad 32 GB WiFi Tablet PC
Toshiba satellite pro l20 sound
my l20 cant play any sound can i download sound through this site
Dec 02, 2007 | Toshiba Satellite R10-S802TD Tablet PC
Apple iPad 32 GB WiFi Tablet PC Logo
2,095 people viewed this question
Top Apple Tablets & eReaders Experts
john smith
 Mike M
Mike M
Ian_C
Level 1 Expert
Are you an Apple Tablet and eReader Expert? Answer questions, earn points and help others
