Question about Husqvarna Lawn Tractor  25 HP 54in Deck Model YTH2454
The front wheels toe out about an equal amount and ther doesn't appear to be a way to adjust the toe in. The steel steering rodsdo not have adjusters. Any help would be appreciated.
I have a YTH2348 that had Toeing Out issues with both tires. After digging deep into the entire Front Axle/Steering Assembly, I learned that the Front Axle Bushings internal bolt hole diameters had increased due to friction and usage (it's a non-greasable assembly) thus because of the friction and the weight of the mower itself, the 7/16 14 3 Bolt, reamed out the Bushings holes. The excessive hole diameter was allowing the axle to flex back and forth, messing up the Toe Setting, along with a bent Left Drag Link. I SHIMMED the Axle removing the ability for it to flex. I also re-straightened the Left Drag Link back to its proper shape and length.(it doesn't take much bending of the Drag Links to mess of the Toe Setting)
Posted on May 20, 2018
I have the same problem on my YTH2348. I changed both linkage rods and still have the problem. Not sure what is going on. I don't think it is the axle as these are cast iron and would take alot to bend it. Anybody have a clue what I could do to fix it!!!
Posted on Sep 11, 2012
2 Suggested Answers
  • 12 Answers
SOURCE: adjust steering on riding mower 42 inch
If this is your front end, I'd say you probably bent the linkage rods. 61 & 62.
Most alignments start with the steering wheel centered, bring the closest wheel in to alignment, then work the other one in. Again, on these the links often get bent.
Posted on Jul 02, 2012
Front Wheel Allignment
On these LH body cars, camber is not adjustable. Neither is caster. Those angles are preset by the suspension geometry. However, specifications for them ARE published. Generally, if either of those two parameters are out of spec, then it's likely something is worn or damaged and needs to be replaced.
The only adjustable parameters are to the front and rear toe but specified as "Total Toe" - see note below.
The alignment specs are as follows ...
ALIGNMENT SPECIFICATIONS AT VEHICLE CURB HEIGHT
A. FRONT WHEELS
  1. CAMBER
    Acceptable -0.6° to +0.6°
    Preferred +0.0°
    Side to Side Differential
    Acceptable 0.7° or less
    Preferred 0.0°
  2. TOTAL TOE - Specified in degrees. See Note Below
    Acceptable 0.4° in -to- 0.0° out
    Preferred 0.2° in
  3. CASTER* (reference angle)
    Acceptable +2.0° -to- +4.0°
    Preferred +3.0°
    *Side to Side Caster Difference not to exceed
    Acceptable 1.0° or less
    Preferred 0.0°
B. REAR WHEELS
  1. CAMBER
    Acceptable -0.6° -to- +0.4°
    Preferred +0.1°
  2. TOTAL TOE** - Specified in degrees. See Note Below.
    Acceptable 0.2° out -to- 0.4° in
    Preferred -0.1° in
    **TOE OUT when backed onto alignment rack is TOE IN when driving.
  3. THRUST ANGLE
    Acceptable -0.15° -to- +0.15°
Note: "Total Toe" is the arithmetic sum of the left and right Toe settings. Positive is Toe-in. Negative is Toe-out. Total Toe must be equally split between left and right wheels. Left and Right Toe must be equal to within 0.02° (2 one hundredths of a degree).
Courtesy RJK & Concorde Shop Manual
Mar 08, 2014 | 1994 Chrysler Concorde
Driver's side wheel bearings, greased
That depends on what type of vehicle you drive. If the noise is on turns it’s more than likely a bad ball joint or toe rod end
Sep 27, 2017 | 2005 Pontiac Sunfire
My lawn tractor pulls to the right when driving can i fix this?
The Toe In/Toe Out will have to be adjusted (if the steering rods to each front wheel have sleeves), just like on a car.
Toe-in is the operating angle of front wheels on a riding tractor. If the front edge of the wheels point inward, towards each other, then the wheels have toe-in. If the front wheels point outward, the unit has toe-out (or negative toe-in). Adjustment of toe-in is necessary to maintain proper steering control.
Unlike automobiles, our tractors have pre-set camber and caster settings. Therefore no camber or caster adjustment is necessary.
Acceptable toe-in adjustment range for all of our lawn & garden tractors is anywhere between 1/16"-5/16". With 1/8" serving as the optimal range.
Detailed toe-in adjustment procedures for the various models of tractors are reviewed in the "Adjustments" section of the Operators Manual for the tractor.
If tires are not toed-in properly after adjustment, it is likely that other part(s) need service or adjustment. axles, wheel bushings, control arms and other steering components may be worn or damaged and will need inspection. Service these items as needed.
You haven't stated your make and model, so I can't send you the manual with the exact procedure for your machine.
Jun 12, 2011 | Garden
How do i align a steering wheel on a 2002 astro van
If the steering wheel hasn't been removed and is just off center then the front end may need alignment to correctly get the steering wheel at center.
May 15, 2011 | 2002 Chevrolet Astro
I want to know how to fix the alignment on my 1995 honda accord ex.
Before making wheel alignment adjustment, perform the following checks:
  1. Tires should be equal in size and runout must not be excessive. Tires and wheels should be in balance, and inflated to manufacturer's specifications.
  2. Wheel bearings must be properly adjusted. Steering linkage and suspension must not have excessive looseness. Check for wear in tie rod ends and ball joints.
  3. Steering gear box must not have excessive play. Check and adjust to manufacturer's specifications.
  4. Vehicle must be at curb height with full fuel load and spare tire in vehicle. No extra load should be on vehicle.
  5. Vehicle must be level with floor and with suspension settled. Jounce front and rear of vehicle several times and allow it to settle to normal curb height.
  6. If steering wheel is not centered with front wheels in straight-ahead position, correct by shortening one tie rod adjusting sleeve and lengthening opposite sleeve equal amounts.
  7. Ensure wheel lug nuts are tightened to torque specifications
Ride Height Adjustment
Before adjusting alignment, check riding height. Riding height must be checked with vehicle on level floor and tires properly inflated. Passenger and luggage compartments must be unloaded. Bounce vehicle several times, and allow suspension to settle. Visually inspect vehicle from front to rear and from side to side for signs of abnormal height.
Measure riding height. See figure. Riding height between left and right sides of vehicle should vary less than 1′ (25.4 mm). If riding height is not within specification, check suspension components and repair or replace them as necessary.
Wheel Alignment Procedures
Honda recommends using commercially available computerized 4-wheel alignment equipment. Follow equipment manufacturer instructions to obtain vehicle alignment settings. Use following procedures for necessary adjustments.
Civic Camber Adjustment
Compare camber settings with vehicle manufacturer recommendations. If camber is incorrect, check for bent or damaged front suspension components. Replace faulty components. Recheck camber.
Civic Caster Adjustment
DO NOT use more than 2 shims. If more than 2 shims are required to adjust caster angle, check for bent or damaged suspension components.
Compare caster settings with vehicle manufacturer recommendations. If caster is incorrect, check for bent or damaged front suspension components. Replace faulty components. Recheck caster.
Civic Toe-In Adjustment
  1. Secure steering wheel in straight-ahead position. Measure front wheel toe-in. If adjustment is needed, loosen tie rod lock nuts. Turn both tie rods equally in the same direction until front wheels are in straight-ahead position and toe-in reading is correct. Tighten tie rod lock nuts. Reposition tie rod boots if twisted.
  2. Ensure parking brake is released. Check rear wheel toe-in. If adjustment is needed, hold adjusting bolt on rear compensator arm and loosen lock nut. See figure. Adjust rear toe-in by sliding rear control arm until rear toe-in is correct. Install NEW lock nut, and tighten it while holding adjusting bolt.
Wheel Alignment Specifications
  • Camber - Measurement in degrees.
    • Front: 0 (range -1 to 1)
    • Rear: 0.33 (range -1.33 to 0.67)
  • Caster - Measurement in degrees.
    • 1.17 (range 0.17 to 2.17)
  • Toe-In - Measurement in inches (mm).
    • Front: -0 (0)
    • Rear: 0.08 (2.0)
  • Toe-In - Measurement in degrees.
    • Front: 0.00 (range - 0.16 to 0.16)
  • Toe-Out On Turns - Measurement in degrees.
    • Inner: 41.00
    • Outer: 33.50
Torque Specifications Ft. Lbs (N.m)
  • Rear Control Arm Adjusting Bolt: 48 (65)
  • Spindle Nut: 136 (185)
  • Tie Rod Lock Nut: 41 (55)
  • Wheel Lug Nuts: 80 (108)
hope this helps you out.
May 09, 2011 | 1995 Honda Accord
I keep having to replace wheels on my car.... the wheels are wearing unevenly i took it to a guy and he says the that there is a bar under there that keeps the wheels strait up and that bar is bent so my...
was your car in a wreck since you have own it?
that would be the only way anyone could bend steering or suspension parts.if your tires are leaning out on top,
it would be a part called"lower control arm assembly",
if you stand in front of your car with the steering wheel straight,and your tires are pointing in on each side,or pointed out instead of straight,that would be a "tie rod "
there is an inner tie rod and an outer tie rod end.
you need to take your car to a shop that does alignments,and have them tell you exactly what is wrong,you can even get lower control arm assemblies
from a salvage yard.but do yourself a favor and don't take your car to a MONROE or MIDAS type shop,they are only there to sell and make commissions! Find a normal shop that the owner is the mechanic.
Nov 26, 2009 | 1998 Chevrolet Monte Carlo
Front tires last 1 or 2 weeks before showing steel on inside
No full 4 wheel alighnment. The struts you have replace are how the front camber is adjusted. After camber has been adjusted then toe will be set.
Oct 11, 2009 | 2002 Pontiac Sunfire
Wheel alignment
The main cause of steering wheel off-center is toe misalignment or rear axle misalignment. Toe can fall out of adjustment fairly easily as a result of daily driving, so you can imagine the effects of pounding it through 4WD trails on a regular basis.
Toe is designed to preload the steering linkage to remove play in the system. You can visualize toe angle from above; toe-in, or positive toe, is displayed when the leading edges of the tires are closer together than in the rear. Toe-out, or negative toe, is when the leading edges are farther apart. Zero toe is when wheels are pointed straight ahead and are parallel to each other. A slight amount of positive toe is preferred for most vehicles.
Improper toe angle isn't the only reason a steering wheel won't center. This phenomenon can also be caused by the steering linkage not being centered when toe was adjusted in the first place. This can be corrected by recentering the steering wheel and readjusting toe to proper specs. A bent steering arm or linkage component can also cause the steering wheel to be off-center. I've also seen this occur due to loose steering arm bolts. An off-center steering wheel contributes to tire wear because as the wheels are turned off dead center they turn toe out and increase tire scrubbing.
Sometimes an off-center steering wheel is accompanied by a wheel pull to one direction or the other and could be the result of a damaged component somewhere in the vehicle - a bent axlehousing could be throwing off the rear toe setting (rear toe setting is often overlooked). A bent frame or overly worn suspension bushings can also be the cause. If your wheel is off-center and also pulling, it can be as simple as incorrect tire pressure from side to side. Memory steer is another effect that is usually associated with an off-center steering wheel. This is when the steering wheel returns to an off-center position and can result in steering pull or drift after completing a turn. This can be caused by binding in the steering linkage as well as power steering system issues such as leaks or improper hydraulic pressure. Steering linkage bind occurs when proper geometry is not maintained in lifted vehicles.
Many 4x4s don't have factory provisions for adjusting caster and camber and rear toe and camber, but the front toe setting is easily adjusted. Toe is controlled by the steering linkage. By loosening the adjusters on the tie rod and shortening or lengthening the tie rod by turning the ends, toe angle can be adjusted. This should not be a substitute for regular professional wheel alignment jobs and is simply a tip that can be used to put off frequent trips to the alignment shop due to regular trips to the trail.
Before determining toe angle and/or performing adjustments, it's a good idea to start the engine and turn the steering wheel side to side to relieve pressure in the system. Then, turn the wheels straight and shut off the engine. You should also roll the vehicle back and forth a few times between measurements.
Get someone to hold the other end of the measuring tape and measure the leading toe distance. This is the distance between the leading edges of the front tires. You'll compare the results to the distance between the trailing edges of the tires directly opposite from where you took the first measurement.
The higher number will indicate toe direction: higher number in leading edge indicates toe out; higher number at trailing edge displays toe in. Larger-than-stock tires require more positive toe for best results.
Once the necessary measurements are performed to determine what the current toe setting is, you can loosen the bolts on the tie-rod adjuster sleeve so that the tie-rod ends can be rotated. Don't forgot to tighten the adjusters when you're done as damage or injury could result.
The tie-rod ends thread into the tie rod. The ends can be threaded in or out of the tie rod to make the assembly longer or shorter. Longer creates more toe out; shorter toe in. Don't make huge adjustments all at once. It's best to adjust and measure a few times to achieve appropriate setting.
I hope this helps you if you were looking to do a toe alignment yourself if you have decent knowledge of component location on a jeep.
Jan 30, 2009 | 1995 Jeep Grand Cherokee
How can the rear suspension be adjusted?
REAR WHEEL ALIGNMENT
TOE-IN : 0±2 mm (0±0.08 in.)
note_icon.gif 1. The rear suspension lower arm mounting cam bolt should be turned an equal amount on both sides during adjustment. Right wheel : Clockwise direction : toe-in Left wheel : Clockwise direction : ton-out Maximum difference between LH and RH : 3mm 2. The cam bolt should be adjusted within a 90° range left or right from the center position. CAMBER Standard value : 0°±30´ Maximum difference between LH and RH : 3mm : 0±2 mm (0±0.08 in.) note_icon.gif 1. The rear suspension upper arm mounting cam bolt should be turned an equal amount on both sides during adjustment. 2. Install the left and right springs which have the same identification color. 3. The cam bolt should be adjusted within a 90° range left and right from the center position.e55b100.gif TIRE WEAR 1. Measure the tread depth of the tires. Tread depth of tire [Limit] : 1.6 mm (0.06 in.) 2. If the remaining tread depth is less than the limit, replace the tire. note_icon.gif When the tread depth of the tire is reduced to 1.6 mm (0.06 in.) or less, the wear indicators will appear.
Jun 16, 2008 | 2004 Hyundai Santa Fe
Husqvarna Lawn Tractor  25 HP 54in Deck Model YTH2454 Logo
1,763 people viewed this question
Top Husqvarna Garden Experts
Jim Parker
Jim Parker
Jay Finke
Jay Finke
lnbn1975
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
