Question about Epson PhotoPC L410 Digital Camera
The LCD screen is hard to see. What should I do?
    Master:
  • 542 Answers
If the LCD screen is too bright or too dark, adjust the LCD Brightness setting in the Setup Menu. If you are shooting photos outdoors in bright light, move the joystick to the icon showing the sun over shaowed area to turn on Outdoor mode and make the LCD screen easier to see in bright light.
Posted on Sep 12, 2005
    Master:
  • 542 Answers
6ya staff
SOURCE:
Acer all in one monitor has white bubbles
This type of behavior usually results from pushing on the screen too hard or "tapping" too hard.
The lcd screen in the device will need replaced to fix this issue.
Sep 06, 2014 | Acer AZ5610U9072 Allinone PC 23' Touch...
Cracked lcd hp g6 notebook screen
if you want to replace the screen i suggest to replace the whole unit.since its hard to find lcd screen only unless in the manufacturer.then i'm sure the price is like you buy new one.
Aug 29, 2012 | HP Nx7400 Notebook Pc 15.4-inch Wxga Tft...
I have a proyron 32
Shadow on screen that seems to be unchanged or permanent is typically called "bruising". Usually caused by hitting the lcd screen too hard with a object..or press to hard with your fingers. The only fix for it is replacing the LCD screen. If the screen just seems "dimmer" then this could be caused by a bad inverter board or blacklight. It's the LCD it's usually not cost effective to replace.. and new monitor should be purchased.. if it's the inverter board or backlight it may be worth fixing.
Nov 16, 2011 | Televison & Video
Screen on laptop advent 7102 very dull can hard use it hardly any brightness
The LCD screen for the Advent 7102 does not produce light. It needs an additional light source.
A Backlight is the additional light source.
A Backlight is a CCFL.
Cold Cathode Fluorescent Lamp
Similar to Fluorescent lighting used in homes, and businesses, but on a MUCH smaller scale.
An Inverter (Screen Inverter) converts electricity from the laptop, for the LCD screen, and the Backlight.
90 PERCENT OF THE TIME the fault is the Inverter.
The Inverter is a small circuit board located behind the Display Bezel, and under the LCD screen.
[ The Display Bezel is the thin plastic frame in front of the LCD screen. Resembles a picture frame ]
Example of a screen Inverter for an Advent 7102 Netbook PC,
http://www.laptoppowerjacks.co.uk/category-27/Acer12.html
Regards,
joecoolvette
Oct 17, 2011 | Advent Netbook
My compaq presario f557us hard drive is working butI have no screen any help please?
Replace the memory sticks one at a time in each slot one at a time. If that doesn't work, reseat the lcd cable from the back of the lcd and to where it connects to the motherboard.
If the hard drive light is still running like its loading up windows then at that point, replace the lcd screen and cable cause that means voltage isn't getting thru the cable to get to the screen.
Dec 30, 2009 | HP Compaq Presario 730US Notebook
Is it my lcd screen or my video card
Please try to connect the laptop to a different monitor or display output like LCD or a projector, in case u find the clear images then the issue is with your LCD otherwise the issue is with your video card. The replacement of the LCD depends on the type of warranty you have.
Jun 20, 2009 | Acer Aspire 5004WLMi Notebook
NEC MultiSync LCD 1560V+ 15 '' LCD Monitor touch-screen
How do you flip the screen on this lcd computer so it's side ways
Nov 21, 2008 | NEC 1560V+ 15" Flat Panel LCD Monitor
Lcd screens
just dry cloth will do, don't presse on it too hard
Jul 16, 2008 | Sanyo CLT1554 15 in. EDTV-Ready LCD...
Blank LCD Screen
Does it still take pictures and you can see them by downloading them to a PC? If so, your LCD screen is probably bad and will need to be replaced. I have replaced these before, its not hard to do if you can purchase a replacement screen.
- Jim
Feb 10, 2008 | Sony Cyber-shot DSC-W55 Digital Camera
Broken lcd screen
I have to tell you that swapping LCD screens are pretty hard especially for phones that you have to open up like this one. Just take the screen to some Cellphone store they might be able to do it. Good luck.
Jun 20, 2007 | Samsung SCH-a950 Cellular Phone
Epson PhotoPC L410 Digital Camera Logo
1,883 people viewed this question
Top Epson Cameras Experts
Steven Wander
Steven Wander
Terry Herrera
David Hoff
Are you an Epson Camera Expert? Answer questions, earn points and help others
