Question about Samsung ES28 Digital Camera
I have an ES28 digi camera i put new batteries in and now the lens won't close plus new batteries are now flashing i personally want to throw it up the wall but my partner won't let me
  • Samsung Master
  • 43,501 Answers
Here is a tip that I wrote about How toget a Digital Camera Lens to work again
Steps toRepair a Digital Camera Lens
heatman101
Posted on Aug 03, 2011
SOURCE:
My asahi pentax camera has a serial #6320891. Could you tell me the year? Plus have a 50 mm lens, a 49 mm close -up lens #1,2 and 4, a 67mm lens with a 67mm hase -1 lens and a vivitar auto 215 flash. Any...
these days second hand photo camera's with film, are not worth much. Some younger persons (really only a few) would like to try these camera's for a while, but they don't pay much. Not knowing what lenses you have it is impossible to guess what their value can be. A 50 mm f 1,2 would bring more than a f 2 or even a 2,8.
Then before you could put it on ebay, you should at least shoot one film, to see if the camera still works.
Lately I bought a Nikon F90 and a F50 with a zoom lens and one was 30 dollar the one with the zoom was 20 dollar. both are in excellent condition, making fine photos with different lenses.
You could try checking on ebay, what they ask for a camera like yours, but perhaps you won;t even find one.
Jul 22, 2014 | Cameras
Lens won't close
Lens may jammed or control board is bad. You may need to take it to a dealer or time to buy a new one.
Dec 17, 2017 | General Electric A735 Digital Camera
Lens won't close and On/Off button doesn't work
Even though the battery appears to be charging it may be shot. Some batteries if they run down too far can not be recharged. You need to try a new battery in the camera.
Jul 25, 2012 | Nikon COOLPIX S6000 Digital Camera
When i ON my digi camera its asking date n time every time???
You may continue using the camera without replacing the CMOS battery. You'll have to put up with the opening screen, and the photos you take won't have the proper date/time information if you don't set the clock, but otherwise the camera will operate fine.
May 21, 2012 | Sony DSC-W210 Digital Camera
I accidentally dropped my samsung S1070 while I was taking a photo, and the lens is now stuck out. It won't turn on, and we've tried replacing the batteries and taking them out. I've also tried...
Check whether your batteries are actually making contact with the battery posts, and that these posts are clean. If not, bend the posts up/down a little, and maybe clean them with a little rubbing alcohol on a Q-tip.The next thing to try is examine both the battery and flash card door. There's usually a little switch on both doors (note some SD card doors do not have this switch) that activates when the doors are closed. If they don't, the camera won't start to prevent damage to the flash card or camera startup sequence. For most cameras its usually a little piece of plastic on the door that pushes in on a pin switch when the door is closed. Closely examine both doors to try to identify these switches. A lot of times that little plastic nib wears down or breaks off, but can easily be jury rigged with a small glued-on replacement.
If you've tried all of the above and still no luck, the problem is then likely to be internal to the camera. One example would be that if your camera uses Compact Flash, check to make sure all pins are present and aligned in the card slot (if bent, simply unbend/straighten them with a skinny "jewelers" screwdriver, then insert the flash card for final realignment).
Thank you!
Sep 04, 2011 | Samsung S1070 Digital Camera
Some stupid person has dropped and then kicked my brand new Samsung camera and now it won't turn on and the lens is stuck out :( When I try to turn it on it makes a weird beep and won't turn on and...
You should try to get that stupid person to buy you a new camera if the following doesn't help. Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ... Here are some troubleshooting steps that you can try that may correct it. They only seem to work for less than 40% of the lens errors, but if the camera is out of warranty (or repair cost approaches that of the camera), they're worth that try. Some of the later steps do involve some risk to the camera, so carefully weigh your options before deciding to conduct them.
Jul 09, 2011 | Samsung Digimax S730 Digital Camera
I can't download photos from my Samsung ES28 camera to my computer. Do I need software to do this & where would I get that?
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program, such as iPhoto on Mac or Windows Photo Gallery or Picasa ( http://picasa.google.com ) on Windows.
Jul 05, 2011 | Samsung ES28 Digital Camera
Is my samsung es28 digi cam upgradable on firmware
no your digi cams firmware are not upgradable.
it is not updated time to time by the latest version.
thanks.
May 11, 2011 | Samsung ES28 Digital Camera
MY SAMSUNG ES28 REFUSES TO DOWNLOAD PHOTOS ONTO MY PC.
Consider NOT connecting your camera to your computer.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program, such as Picasa ( http://picasa.google.com ).
Apr 15, 2011 | Samsung ES28 Digital Camera
Samsung ES28 Digital Camera Logo
357 people viewed this question
Top Samsung Cameras Experts
FIKRET UNALIR
FIKRET UNALIR
Level 1 Expert
Anthony Ward
Anthony Ward
Are you a Samsung Camera Expert? Answer questions, earn points and help others
