20 Most Recent Lionel Trains Classic Freight Train Set Questions & Answers
Check the door making sure it is closing properly
Lionel Trains... | Answered on Sep 25, 2017
If your sure the loco contacts/wheels are clean and the track is ok then remove the loco bodywork and check the motor. You can apply a 12v supply directly to the motor contacts to test if it's running ok. If it does run ok then suspect and clean the brushes and associated connections. If it does not run try moving the motor armature manually. If it is stuck it is probably time to replace it. If it moves apply a light machine oil and test again.
Lionel Trains... | Answered on Jun 16, 2014
Power wire to center rail and ground wire to either outside rail.
Lionel Trains... | Answered on Dec 04, 2013
Possibly in need of wheel/pickup cleaning or lubrication.
Also possible that your track need cleaning.
Lionel Trains... | Answered on Jan 19, 2013
ther will be four wires but they will ahve all colours
blue black negative red brown for posityve green yellow earth and white may be anothe r earth
any way try and see the colour on the tracks and join appropriate and each wires to them
maybe white and yellow can be joined together
it will not arise any problems by doing so
Lionel Trains... | Answered on Nov 20, 2011
Lionel Trains Classic Freight Train Set Logo
Popular Tags
30 questions posted
Top Lionel Crafts & Hobbies Experts
ray gallant
edoptician
Level 1 Expert
Kardoc
Are you a Lionel Craft and Hobby Expert? Answer questions, earn points and help others
View Most Popular
  • Lionel Crafts & Hobbies
Most Popular Question
lionel thomas friends train stop
  • Crafts & Hobbies
