20 Most Recent
Tissot T-Touch T33759851 Questions & Answers
My Tissot touch will no
In this watch the battery should be changed after one year, depending on how often the features are used. After changing the battery the all reset should be done. Best to take it to an authorized service, and not any non authorized place to change the battery. Get in touch with Tissot for the info about where to bring the watch.
Battery Change on T-Touch
there usually is an AC contact point to reset digital watches. Touching the + and the ac point with a conductive wire usually resets the watch. Not sure about the spring- I'm not going to open my Tissot up unless I have to.
T-touch dont display altimeter, meteo and thermo.
I have the same problem with my t touch one, the first model with round push button, after take it to a battery replacement and service, and ask a tissot representative store, I receive two answers and both says that I have to change the movement... means ... the machine, and if is under warranty will be free, is maybe 6 or more years old so no more warranty, sad but true, I let it be. I will not spend at least 400 USD. to do it, so, try to enjoy the rest of functions left and a nice looking watch.
Tissot t-touch analog time is out of sync with
This is the tried and tested solution from this very nice gentleman. Many thanks to him (Ha Bi):
- Press and hold on to the T button until it beeps
- Touch the middle of the screen to change digital display to unit selection
- Press and hold the T-button until "Synchronize" comes up in the digital display
- Use the + button and - button to align the hour and minute hand to 12:00.
- Click on the T-button again. Congrats, you're done!
- Enjoy~
Must see blog for all T-touch users
http://myhabi.blogspot.com/2008/10/tissot-t-touch-battery-change.html
Synchronizing the manual and digital clocks
Push the middle button then touch the centre screen selecting the "nits" mode(24 C m), then push the middle button again for 5 seconds."Synchro" will appear on the display. By using pushers + and -, bring the two hands pre-cisely to 12 o'clock
Incrementation of the minute hand(3 steps=1 minute)
Incrementattion of the hour hand(3 steps=1 minute)
Press the middle button to validate the setting.
Haw to reset tissot t tuch
If you syncro you must touch the center until the option look open the press the middle button for 5 sec and you see the function Synchro.You must set the 2 hands at 12 exactly.greekdimis.blog spot.
Replace Battery on a Tissot Touch
When you need frequent re.Syncronizing of your Touch or after 2-3 year
maybe you need to replace the battery.
you need:
a CR1632 3V Battery (about 2€)
a very tiny screw driver
a very sharp knife
With the knife remove the bottom of yout Tissot, (you do not need to unscrew) it's just a cover to pull up like in this imaged
Now you can clean with a soft brush & remove the dust.
Use the screw drive to replace the battery,
put back the cover & enjoy
Name and battery number
Renata CR1632
http://www.renata.com/pdf/3vlithium/CR1632_v06.pdf
To replace battery you need to have very small screwdriver and some knife to open back cover.
My Tissot T-Touch Altimeter does not function.
Mine did the same thing; I read in other blogs that this could happen due to humidity. I heat up my watch with my wife's blower for about 5 minutes on high. After 5 min I couldn't even touch it! The screen went blank. After a few minutes when it cooled down the screen came back up and to my amazement all the function came back. it is risky but So far... it works well.
Showing 6ae on my Tissot T touch. Also cannot
Press the center button marked "T". The watch should beep once;- Touch the center of the touch-sensitive face until 24H Cm appears in the digital LCD display;
- Press and hold the center button marked "T" for approx. 5 seconds. The watch will beep once and then again a second time, after 5 seconds have passed. The digital LCD display should now read SYNCHRO;
- Press the upper button marked "+" to move the minute hand until it is positioned exactly at 12:00;
- Press the lower button marked "-" to move the hour hand until it is also positioned exactly at 12:00;
- When both hands are aligned together and pointing directly at 12:00, press the center button marked "T" to save your settings.
- Your watch is now synchronized, so no expensive repair work is required!
Need to replace battery on
This can be difficult(read dangerous to your watches health) to do if you don't know how. I paid 700 for mine and would not try to save 10 bucks doing it myself versus destroying my own watch, take it to a legitemate watchmaker. He will also inspect gaskets and will have the proper tools and most importantly will know what he is doing.
My T touch is not responding
Even I see the same. But I got this repeatedly to the Authorised Service Personnel of TIssot in India. But this never got fixed. Anyways thanks for the guidance. CheersMadhu
Why would a tissot t-touch need an overhaul to replace a dead battery
These babies are notorious for going down the tubes with a battery change. I bet if you get it back it won't work with a new battery. Twice I have replaced batteries and the watch didn't work when I finished. One of them was my own watch, I think $450 is about half the price of a new watch and that is sad. Cool watch just not very long life
Fix the hands correct with the dejital
Sometimes a watch will be off center due to shock, dead battery etc. Symptoms are;
hands don’t line up, digital and analog time doesn’t match, Compass function doesn’t
have the hands exactly opposite etc. This can all be fixed. The Synchronization
function can be used:
1. Activate Crystal
2. Tap center until you are the unit’s screen (12h or 24h, F ft or C m).
3. Push and hold (at least five seconds) the center crown
4. Watch will beep and word (SYNCHRO) will appear in the display.
5. Use the top + button to line up the minute hand right on the 12.
6. Use the bottom – button to line up the hour hand right on the 12.
7. When finished, press crown and you will go back to time.
