20 Most Recent
Acer Aspire 4520-5141 Notebook Questions & Answers
Www acersupport com manual
That sounds like you have an external monitor hooked up. Powering it on will not start the laptop. You'll need to start the laptop with the laptop power button first. Then try turning on the monitor to see if you get an image there.
Factory reset
'Factor reset' implies a clean re-install which wipes EVERYTHING out on the HDD. this process is called RECOVERY == not to be confused with restore system.
It can be done using the recovery partition or a set of recovery discs.
If u didn't create them u can purchase from Acer. If the system is still functional u may be able to create them before u try the recovery.
How can i connect my tv to my dvd?
Tv to a DVD player?? If you have a hd tv and a hd dvd player a "hdmi cable" can be used, if not then just a "scart lead"
Hope this helps
Aspire 4520 manual
Just open and download your required manual.I hope it will be very helpful for you.http://www.manualowl.com/p/Acer%20Computers/Aspire-4520/Manual/65480Good Luck
